    What are the AES specifications for the AES encryption in C4D SDK ?
    c++
    7 Posts 4 Posters 1.4k Views 2 Watching
    • C Offline
      C5D
      Hi
      I'm developing a plugin that will AES encryption / decryption, I am planning to use the C4D AES class
      referenced in this link : https://developers.maxon.net/docs/cpp/2023_2/class_a_e_s.html#ac4796420dbb7d8f2c3b1305f131762cc
      but I need to know the specifications of the AES encryption / decryption in C4D SDK, this is because the data will be processed later on a server that uses AES from a 3rd party library, I want to make sure that what I encrypt in C4D sdk can be decrypted on the server and to achieve that I have to know the specifications of the AES class in order to use them on the server too.
      I couldn't find any useful information on the web.
      • C Offline
        C5D
        any body ?
        • kbarK Offline
          kbar
          Does this post help?
          https://developers.maxon.net/forum/topic/10043/13512_aes-what-specification?_=1642384126994
          The AES library in our SDK uses ECB, which does not seem to need an init vector, and we don't provide one.
          https://www.plugins4d.com
            Hi @C5D first of all welcome in the PluginCafe community 🙂
            This is the old way of doing and may be removed in the future, instead you should use the maxon::StreamConversions::AesEncoder() as demonstrated in ZipFile OpenEncrypted for read not working
            • C Offline
              C5D
              Thanks guys.
              I just have some results that can't be decrypted back so I assumed there is some missing step.
                Hi without more information from your side it's very hard to help you. Would it be possible to share some code?
                  ferdinand @C5D
                  Hello @c5d,
                  without any further activity before Wednesday, the 16.03.2022, we will consider this topic as solved and remove the "unsolved" state of this topic.
