    Cutome Render Token do not update Filename each Frame
    11 Posts 4 Posters 2.3k Views 2 Watching
      your xpresso is working for me using R25. I got in result 3 frames rendered with the frame number.
      About the token, special characters are not allowed in tokens. They are replaced by an underscore. The Path d:\render\temp will be changed to d__render_temp.
      # list of special character
      Otherwise it should work.
      One point, you are always returning filename, but if your object doesn't have a userdata called the right name, you should return "None".
      • N Offline
        nason
        Hi Manuel,
        thank you for your quick reply.
        I prepared a new test scene according your hints and did some tests but my filename won't be updated. For some reason it don´t work. Maybe I have to work completely different.
        the new token code:
        def PythonUserdataToken(data):
            obj = data[0].SearchObject('Output')
            if obj == None:
                return None
                if obj.GetName() == 'Output':
                    for ids, bc in obj.GetUserDataContainer():
                        if bc.GetString(c4d.DESC_NAME) == "Filename":
                            filename = obj[c4d.ID_USERDATA, ids[1].id]
                            return filename
                            return None
        if __name__=="__main__":
            for registeredToken in c4d.modules.tokensystem.GetAllTokenEntries():
                if registeredToken.get("_token") in ["PythonUserdataToken"]:
                    exit()
            c4d.plugins.RegisterToken("PythonUserdataToken", "get userdata of Listcontrol", "UserData", PythonUserdataToken)
        maybe you can look again...
        Christian
        • N Offline
          nason
          c4d-R25-token example.c4d
            Sorry i wasn't clear. Your idea was to retrieve a data from a userdata and use it as a token. This works.
            Unfortunately, using specials characters is not allowed. As a path contain specials characters (: \ /), they will be removed.
            Your xpresso setup is working on my R25.
            • N Offline
              nason
              Hi Manuel,
              did you see the new testfile c4d-R25-token example.c4d without using XPresso and specials characters like 🙂 \ /)?
              I don't use any special characters any longer but nevertheless it don´t update the filenames. Each frame are named like the first on. In this example Red0000.tif, Red0001.tif, Red0002.tif
              The expected output should be Red0000.tif, Green0000.tif, Blue0000.tif ... possibly I misunderstood something or it's not possible to realize it like my thought. Maybe you could look over again?
              Much obliged Christian
                Hello @nason,
                you are right, this is not solved. I have reset the topic to 'unsolved'. I had a brief look at this, and the render token is indeed being interpreted incorrectly, all output files end on the state the user data were in when the rendering was launched, e.g., 'red'. I have modified your plugin example and Python Programing Tag a bit, which shows that this works in principle, but that there is something going wrong in the way Cinema 4D handles the render document (documents get cloned for rendering). @m_magalhaes is currently on vacation and will only come back on Monday. I unfortunately do not have the time to start a debugging session on that with Cinema 4D, you will have to wait for Manuel.
                The plugin:
                    doc = data[0]
                    if not isinstance(doc, c4d.documents.BaseDocument):
                        print ("No document.")
                    obj = doc.SearchObject("Output")
                    if obj is None:
                        print ("No object.")
                    for descId, bc in obj.GetUserDataContainer():
                            filename = obj[c4d.ID_USERDATA, descId[1].id]
                            print ("Resolved Token:", filename)
                            return filename
                    print ("Fail.")
                    doRegister = True
                        if registeredToken.get("_token") == "PythonUserdataToken":
                            doRegister = False
                    if doRegister:
                                                  "UserData",
                The tag:
                    obj = op.GetObject()
                    doc = op.GetDocument()
                    frame = doc.GetTime().GetFrame(doc.GetFps())
                    filename = ['Red','Green','Blue', 'Yellow']
                    obj[c4d.ID_USERDATA, 1] = filename[frame]
                    print (filename[frame])
                Example output when starting a render (which does not necessarily have to be in order of execution due to threading):
                Set name: Green
                Resolved Token: Green
                Set name: Red
                Set name: Red
                Set name: Red
                Resolved Token: Red
                Resolved Token: Red
                Resolved Token: Red
                Resolved Token: Red
                Resolved Token: Red
                Set name: Green
                Set name: Green
                Set name: Green
                Set name: Blue
                Set name: Blue
                Set name: Blue
                Resolved Token: Blue
                • N Offline
                  nason
                  Hello Ferdinand,
                  thank you for answering me and deal with the topic. It's true it isn't solved yet. The console output is quite interesting. I'll waiting for Manuel and hopefully he has an idea or having some time for debugging. After his vacation he'll build up new energy.
                  Cheers and many thanks,
                  Christian
                    To "fix" that, you can use the field data[4] to check if the frame number is set or not.
                    the problem is that the frame will still have a number after the name....
                        if data[4] == c4d.NOTOK:
                            return None
                        if obj == None:
                            return None
                                        print (filename)
                                        return filename
                                        return None
                                exit()
                    I will probably need more time to check why you must do this.
                    But at least the filename are named correctly.
                    • N Offline
                      nason
                      Hi Manuel,
                      thanks a lot for helping me in this case. It's quite interesting for me and maybe also helpful for someone in this forum.
                      I'm absolutely satisfied with this solution, it works like a charm...
                      Greetings and best wishes
                      Christian
                        Hello @nason,
                        without any further questions we will consider this topic as solved by Friday, December the 17th.
