    R25 Json Parser Usage
    3 Posts 2 Posters 870 Views 1 Watching
    • Danchyg1337D Offline
      Danchyg1337
      Hello! I'm currently trying to transfer S24 plugin code into R25. As i see in changelog, parser_json.h is replaced with parser.h. But the usage is not clear. In the code, i was reading the string with
      jsonParser.Read(result, maxon::JSONPARSERFLAGS::NONE, dd) iferr_return;
      and jsonParser is
      maxon::JsonParserRef jsonParser;
      created like this
      auto jsonCRes = maxon::JsonParserRef::Create();
      if (jsonCRes == maxon::FAILED)
      	MessageDialog("JSON parser create fail"_s);
      jsonParser = jsonCRes.GetValue();
      I couldn't find anything similar to such creation in the new parser. Could you breafly explain how to create a valid ParserRef and call ReadString to convert string into dictionary?
      Thanks!
        the parser interface has been changed, you have more parser, and the process is the same for each parser. Create a reference and use it.
        Parsers are declared in ParserClasses we have now json, jwt and csv parser.
        /// Parse a given JSON string and return the JSON data in a maxon::DataDictionary.
        /// @param[in] in_string				The string containing a JSON representation.
        /// @return											Error code if fail else the DataDictionary.
        static maxon::Result<maxon::DataDictionary> ImportJSONFromString(const maxon::String &in_string)
        	iferr_scope;
        	// check passed argument
        	if (in_string.IsEmpty())
        		return maxon::IllegalArgumentError(MAXON_SOURCE_LOCATION, "Passed string is empty."_s);
        	// create a JSONParser reference
        	const maxon::ParserRef jsonParser = maxon::ParserClasses::JsonParser().Create() iferr_return;
        	// allocate a SingleValueReceiver to store the data read from the JSONParser;
        	maxon::SingleValueReceiver<const maxon::DataDictionary&> readData;
        	// parse the string  and check it's containing a valid JSON structure
        	iferr (jsonParser.ReadString(in_string, maxon::PARSERFLAGS::NONE, maxon::GetUtf8DefaultDecoder(), readData))
        		// provided string is not containing a valid JSON structure
        		DiagnosticOutput("BLW >> Invalid JSON string [@]");
        		iferr_throw(err);
        	// return the data
        	return readData.Get().GetValue();
        Danchyg1337D 1 Reply Last reply Reply Quote 0
          Danchyg1337 @Manuel
          @m_magalhaes Thank you!
