    Best way to display a bitmap in the viewport background
    5 Posts 4 Posters 914 Views 2 Watching
    • R Offline
      rui_mac
      I would like to create an Object plugin and I would like the code to be able to show a bitmap, with optional alpha (transparency) adjustment, in the background of the viewports (perspective and orthogonal views).
      What is the best way do do it?
      I don't need actual code. Just what methods to override and what must I make to be sure it displays below all viewport objects.
      Thank you very much in advance for any reply.
      Rui Batista
      • kbarK Offline
        kbar
        You can draw into the viewport using a scene hook and render a quad containing a bitmap texture. These may help you get started.
        [URL-REMOVED]
        [URL-REMOVED]
        https://www.plugins4d.com
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          rui_mac @kbar
          @kbar, thank you for the reply.
          The problem with the Scene Hook is that it requires C++.
          I'm coding in python.
            Hi sorry for the late reply, I overlooked your topic.
            You will need to override the Draw method of your ObjectData and then use BaseDraw.DrawTexture.
              Hello @rui_mac,
              without any further questions or replies, we will consider this thread as solved by Monday the 20th and flag it accordingly.
