    storage.WriteHyperFile() and storage.ReadHyperFile() (Rooky Question)
    windowspythonr23
    7 Posts 2 Posters 898 Views 1 Watching
    • ThomasBT Offline
      ThomasB
      I discovered the WriteHyperFile and ReadHyperFile functions in class c4d.storage
      It says, that it saves a GeListNode to a HyperFile and also that it can read a HyperFile and replace the actual Node.
      Does this function Write completely write an object to a hyperfile?
      Because the writing worked , it has written the file, but when I want to read , Cinema freezes.
      I mean the write function says, it replaces the actual node with that one , which is saved in the HyperFile.
      I'm sure I got it totally wrong 😌
      Here is the small code snippet of the Save Script, which saves the selected object into a hyperfile on disc
      path = c4d.storage.SaveDialog(force_suffix="file")
      c4d.storage.WriteHyperFile(doc,doc.GetActiveObject(),path,100)
      and here is the code snippet for the Load script , which should load and replace the actual node with the saved one
      path=c4d.storage.LoadDialog()
      c4d.storage.ReadHyperFile(doc, doc.GetActiveObject(), path, 100)
      So when I was younger everything was a lot easier
      T.B
        This was a bug that have been fixed with the release 23 service pack one. It was "kind of working" with generators.
        You have flagged this thread with R23, but did you update it?
        • ThomasBT Offline
          ThomasB
          yes sorry , I have version 23.110 , i only bought in november, so cinema was already updated.
          So my question about this function is basically, can I save a complete object with all itΒ΄s settings with this WriteHyperFile(). So when I have for instance a modeled polygon object, does it write also the points and polygons etc...?
          T.B
            ok, that was monday...after a bit more test on R23.110 and our last version
            generator replaced by a generator -> OK
            generator replaced by a polygonObject -> KO --> crash
            PolygonObject replaced by a PolygonObject -> OK
            PolygonObject replaced by a generator -> object disappear if you select it. --> KO
            this is still a bug. I will open a new bug entry for that.
            it should be possible to do it by yourself.
            ThomasBT 1 Reply Last reply Reply Quote 0
            • ThomasBT Offline
              ThomasB @Manuel
              @m_magalhaes
              πŸ˜‚ what in particular do you mean.....
              but so far thanks for your time and effort
              T.B
                The issue occurs when you are trying to override a generator by a polygonObject
                But you can, instead of replacing the generator, create a temporary object and read your hyperfile to that object. Then, you need to replace the existing one. You need to insert the imported object, move it to the same position of the selected object, move the children if they exist, the texture tags etc etc.
                    node = c4d.BaseObject(c4d.Opolygon)
                    c4d.storage.ReadHyperFile(doc, node, path, 100)
                    doc.InsertObject(node)
                    # ..... move the child from the selected object to this one and remove the selected one.
                • ThomasBT Offline
                  ThomasB @Manuel
                  @m_magalhaes
                  yes thanks that was my idea, too , I created a temporary object, in my case a spline with 0 points and 0 segments and simply exchanged it, thanks.....
                  T.B
