    GeDialog AddEditText how to achieves the Dynamically adjust the position of the block
    r21python
    5 Posts 3 Posters 664 Views 2 Watching
    • chuanzhenC Offline
      chuanzhen
      How c4d GeDialog achieves the effect of gif, I only know how to control the position of the cursorexample.gif
      Thanks for any help!
      相信我,可以的!
        I'm not sure to understand the question, the block isn't adjusting its position, if you keep the mouse on the first a, you will see that the first x is at the very same place. The problem is the font used and its tracking, the last a and x aren't at the same place.
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @Manuel
          Hi ,@m_magalhaes
          When I set the string for AddEditText , for example, set the string "walker_aaa", I want to mark "_aaa", but I don't know how to mark it.
          I only found "BFM_EDITFIELD_GETBLOCKSTART" "BFM_EDITFIELD_GETCURSORPOS" in the document.
          相信我,可以的!
            Hi, unfortually this is not possible.
            I added the idea to our backlog.
              chuanzhen @m_adam
              @m_adam Thanks
              相信我,可以的!
