    Python plugin and Linux CLR arguments
    pythons24r23
    5 Posts 2 Posters 1.1k Views 1 Watching
    • V Offline
      vtq
      I am currently trying to export the render settings from a .c4d file with python on Linux. If I'm not mistaken the only way to achieve this on Linux is to write a .pyp plugin that reads commandline arguments as explained here and use a special flag to activate a settings exporting script.
      However I couldn't get any output in the console with that type of plugin, even with the example from the docs. Is it possible to use such a plugin on the Linux CLR version of c4d ?
      I tried the plugins with both S24 and R23 versions in a docker container based on Ubuntu 18.04. Rendering (with Arnold or Redshift) works fine.
      Any help would be greatly appreciated.
      Best regards,
        while with c4dpy you can execute a python script, the command-line render doesn't.
        if you try to create a plugin, PluginMessage will be called before your document is loaded, so you will only have access to the default document.
        The workaround is to load yourself the document in the PluginMessage:
        The problem I see is that if your project has plugins, you are not guarantee that they will be already loaded.
        import sys
        from datetime import datetime
        from contextlib import redirect_stdout
        import os.path
        def PluginMessage(id, data):
            if id==c4d.C4DPL_COMMANDLINEARGS:
                # react to command line arguments
                # redirect the print to a file
                with open('d:\\log.txt', 'w') as f:
                    with redirect_stdout(f):
                        # now we can use print to directly print to the file
                        print(datetime.now(), sys.argv) #print arguments
                        fileName = sys.argv[0]
                        if os.path.isfile(fileName):
                            flags = c4d.SCENEFILTER_OBJECTS
                            # open the document
                            doc = c4d.documents.LoadDocument(fileName, flags)
                            if doc is None:
                                print (datetime.now(), "file {} not loaded".format(fileName))
                            print (datetime.now(), "file {} loaded".format(fileName))
                            # retrieve the active render settings
                            rd = doc.GetActiveRenderData()
                            if rd is None:
                                print (datetime.now(), "can't retrieve the render settings")
                            # access render settings
                            print (datetime.now(), "Resolution of the current file ", rd[c4d.RDATA_XRES], rd[c4d.RDATA_YRES])
                            # close the document
                            c4d.documents.KillDocument(doc)
                        print (datetime.now(), "finished")
            return False
        If you still want to render the document, you can get inspired by our c++ example
        What's the issue you are facing? there's maybe another way of doing it.
        • V Offline
          vtq
          Thanks for the answer and the example.
          The goal is to get the render settings and a few other parameters from a file without rendering it. I have to do it on linux so the ways to achieve it are limited.
          With your plugin code I had the same results I had with the example from the documentation, nothing happened and I had the message Warning! Unknown arguments: right before C4D END.
          I install these plugins by putting the .pyp file in /opt/maxon/cinema4dr23.110/bin/plugins but they don't seem to load. On the other hand rendering plugins seem to load and work just fine. I also had to export the envvar g_modulePath=/opt/maxon/cinema4dr23.110/bin for the rendering plugins to load.
          Am I missing any step when adding a python plugin ?
          Best regards,
            I also have that bad argument, but the plugin is working fine using g_additionalModulePath=/media/val/empty/cmd_plugin/
            the above code but with a correct path for my linux virtual machine.
             with open('/media/val/empty/log.txt', 'w') as f:
            ./Commandline /media/val/empty/test.c4d g_additionalModulePath=/media/val/empty/cmd_plugin/
            1- The render works and the log.txt is created. Just to be sure, did you execute bin/setup_c4d_env?
            2 - If you just use the commandline to render a file, it works?
            In any case the command line render isn't created to gather information about files. Wine/c4dpy could be a better solution for that case, but you could have some issue with some rendering modules.
            • V Offline
              vtq
              Adding the path to the plugin in g_additionalModulePath fixed the issue.
              Thank you very much for your help.
