    Apply Substance Preset with no User Input.
    5 Posts 3 Posters 749 Views 2 Watching
    • J Offline
      janine.mcmaster
      I would like to apply a substance preset (.sbsprs) using the python API. I can use c4d.CallCommand(1038417) to open the Substance asset manager but it just opens up file explorer to allow me to select and apply a .sbsprs file. I want to be able to run my script with no user input (just a hardcoded filepath to the substance preset file). Is it possible to apply the substance preset using just python?
      I am using Cinema 4D R23.110 and Redshift. Thanks!
      • J Offline
        janine.mcmaster
        Sorry forgot to say I'm using the Script Manager and Windows 10 Pro 2004.
          Please use our guidelines and use the forum functionalities to mark your thread as a question. Thanks for tagging your post 🙂
          while we have a module for substance available in python it is not possible to apply presets with it (without dialog). Even with C++ it's not possible
          But Substance asset are BaseList2D so you can change the parameters:
              substance = c4d.modules.substance.GetFirstSubstance(doc)
              if substance is None:
                  raise RuntimeError("Failed to retrieve the first substance (most likely there is no substance).")
              #change the resolution to 16x16
              substance[10000] = 4
              substance[10001] = 4
          • J Offline
            janine.mcmaster
            Thank you for letting me know 😞
              Hello @janine-mcmaster,
              without further questions or replies, we will consider this topic as solved by Monday, the 30th and flag it accordingly.
