    Add a GUI button
    4 Posts 2 Posters 872 Views 1 Watching
    • S Offline
      stereo_stan
      Hi everyone. I am trying to learn Python and I have been trying to modify scripts from the official C4D Github page.
      I want to see how I could possibly add a GUI button to this code that copies an animation curve from one object to another.
      I have tried combining two different scripts here.
      I am trying to get when the user clicks the ok button it copies the curve and adds to the other object. Right now the script will do that but only when you click execute.
      Please let me know if you have any thoughts, thank you!
      Copyright: MAXON Computer GmbH
      Author: Manuel Magalhaes
      Description:
          - Copies the position, rotation and animation Tracks (so all Keyframes) from obj1 to obj2.
      Notes:
          - If obj2 already have some animation data for its position, rotation, and animation these data will be lost.
      Class/method highlighted:
          - BaseObject.GetCTracks()
          - CTracks.GetDescriptionID()
          - CTracks.FindCTrack()
          - C4DAtom.GetClone()
          - CTracks.InsertTrackSorted()
          - BaseDocument.AnimateObject()
      class ExampleDialog(c4d.gui.GeDialog):
          def CreateLayout(self):
              This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
              # Defines the title of the Dialog
              self.SetTitle("This is an example Dialog")
              # Creates a Ok and Cancel Button
              self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL)
          def Command(self, messageId, bc):
              This Method is called automatically when the user clicks on a gadget and/or changes its value this function will be called.
              It is also called when a string menu item is selected.
              :param messageId: The ID of the gadget that triggered the event.
              :param bc: The original message container
              :return: False if there was an error, otherwise True.
              # User click on Ok button
              if messageId == c4d.DLG_OK:
                  print("User Click on Ok")
              # User click on Cancel button
              elif messageId == c4d.DLG_CANCEL:
                  print("User Click on Cancel")
                  # Close the Dialog
                  self.Close()
           # Creates a new instance of the GeDialog
          dlg = ExampleDialog()
          # Opens the GeDialog, since it's open it as Modal, it block Cinema 4D
          dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300, defaulth=50)
          # Retrieves the object called obj1 from the active document.
          animatedBox = doc.SearchObject("obj1")
          if animatedBox is None:
              raise RuntimeError("Failed to retrieve obj1 in document.")
          # Retrieves the object called obj2 from the active document.
          fixedBox = doc.SearchObject("obj2")
          if fixedBox is None:
              raise RuntimeError("Failed to retrieve obj2 in document.")
          # Retrieves all the CTrack of obj1. CTracks contains all keyframes information of a parameter.
          tracks = animatedBox.GetCTracks()
          if not tracks:
              raise ValueError("Failed to retrieve animated tracks information for obj1.")
          # Defines a list that will contains the ID of parameters we want to copy.
          # Such ID can be found by drag-and-drop a parameter into the python console.
          trackListToCopy = [c4d.ID_BASEOBJECT_POSITION, c4d.ID_BASEOBJECT_ROTATION, c4d.ID_BASEOBJECT_SCALE]
          # Start the Undo process.
          doc.StartUndo()
          # Iterates overs the CTracks of obj1.
          for track in tracks:
              # Retrieves the full parameter ID (DescID) describing a parameter.
              did = track.GetDescriptionID()
              # If the Parameter ID of the current CTracks is not on the trackListToCopy we go to the next one.
              if not did[0].id in trackListToCopy:
                  continue
              # Find if our static object already got an animation track for this parameter ID.
              foundTrack = fixedBox.FindCTrack(did)
              if foundTrack:
                  # Removes the track if found.
                  doc.AddUndo(c4d.UNDOTYPE_DELETE, foundTrack)
                  foundTrack.Remove()
              # Copies the initial CTrack in memory. All CCurve and CKey are kept in this CTrack.
              clone = track.GetClone()
              # Inserts the copied CTrack to the static object.
              #fixedBox.InsertTrackSorted(clone)
              doc.AddUndo(c4d.UNDOTYPE_NEW, clone)
          # Ends the Undo Process.
          doc.EndUndo()
          # Updates fixedBox Geometry taking in account previously created keyframes
          animateFlag = c4d.ANIMATEFLAGS_NONE if c4d.GetC4DVersion() > 20000 else c4d.ANIMATEFLAGS_0
          doc.AnimateObject(fixedBox, doc.GetTime(), animateFlag)
          # Pushes an update event to Cinema 4D
        ferdinand @stereo_stan
        Hello @stereo_stan,
        welcome to the forum and thank you for reaching out to us. Please make sure to read for further posting the forum guidelines. Your posting is missing tags for the programming environment, the version of Cinema 4D and your operating system environment.
        You can add a button with GeDialog.AddButton(). For further details, please refer to the GeDialog documentation or have a look at our GeDialog code examples at GitHub when you are stuck on a more general level.
        L 1 Reply Last reply Reply Quote 0
        • S Offline
          stereo_stan
          Thank you Ferdinand, sorry for not posting correctly-I will work on making sure to understand the correct way to interact on the forum as I move forward.
            Hello @stereo_stan,
            without further questions or replies, we will consider this topic as solved by Monday, the 30th and flag it accordingly.
