    [Python] LayerShader.AddLayer() -> Defining Shader
    4 Posts 5 Posters 7.3k Views 2 Watching
    • P Offline
      PdZ 1
      Hello all,
      I tried everything to figure out how to use the newly added Python-Command "LayerShader.AddLayer()" in S24.
      As far as I know it only adds the "Type" of Layer. For Example I want to add a certain shader to the Layer I first use AddLayer(c4d.TypeShader) and this will give me an empty "Shader". But how can I define this shader to a specific Shader then?
      (https://developers.maxon.net/docs/py/2023_2/modules/c4d/C4DAtom/GeListNode/BaseList2D/BaseShader/LayerShader/index.html?highlight=addlayer#LayerShader.AddLayer)
      I tried everything but I dont get it... does someone know how to do it?
      Thx in advance!
      • M Online
        NOTE ( @ferdinand ) : The here provided code example contains an error, please refer to How to Create and Populate a Layer Shader? instead.
        Hi @PdZ-1 welcome in plugincafe.
        The type need to be one of the LayerType.
        So to have a regular BaseShader you first need to create a TypeShader layer and then set the link.
        Find a code snippet
        # Main function
            # Retrieveh teh Layer Shader
            mat = doc.GetFirstMaterial()
            sha_xlayer = mat.GetFirstShader()
            # Create an HSL layer
            hsl = sha_xlayer.AddLayer(c4d.TypeHSL)
            # Create a Shader Layer
            shader_layer = sha_xlayer.AddLayer(c4d.TypeShader)
            # Create a Gradient Shader
            gradient_shader = c4d.BaseShader(c4d.Xgradient)
            # Insert this gradient to the material (so the material become the owner of this shader too)
            mat.InsertShader(gradient_shader, sha_xlayer)
            # Finally set the Shader Layer link to the Gradient Shader
            shader_layer.SetParameter(c4d.LAYER_S_PARAM_SHADER_LINK, gradient_shader)
        # Execute main()
          Hello @PdZ-1,
          without further questions or replies, we will consider this topic as solved by Monday, the 30th and flag it accordingly.
          • indexofrefractionI Offline
            indexofrefraction
            Hi... I'm trying to figure out how to handle nested LayerShaders
            mat.InsertShader(gradient_shader, sha_xlayer) inserts gradient_shader as a child of sha_xlayer ?
            Would sha_xlayer.InsertShader(gradient_shader) do exactly the same thing ?
            If yes, does mat.InsertShader(sha_xlayer) have to be done first as well,
            or can you set up a shader tree first and then add it to the material?
            best, index
