    Insert scene under object
    5 Posts 3 Posters 1.3k Views 2 Watching
    • ROMANR Offline
      ROMAN
      Hello guys! I know how to merge a scene with a current project. But i have no idea how to insert scene under parent with coordinats of this parent.
      I want to create custom nulls thats why i want to it. What should i add in this code if i want insert scene under object?
          doc.StartUndo() # Start recording undos
          path = "C:\Users\Jamaletdinov.r\Desktop\ArrowR.c4d"
          flags = c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS | c4d.SCENEFILTER_MERGESCENE
          c4d.documents.MergeDocument(doc, path, flags)
          doc.EndUndo()
        There's no direct way of doing that. I see two possibilities:
        • Create an Xref as a child of the object, define the imported document as the document for the xref, make the xref editable.
        • Open your document and clone all objects one by one. You could end up with lofs of issues if the document has a lot of links. (material, effectors etc etc)
        The problem is, as you can see on this thread, that some parameters of the xref are not accessible with python.
        The problem with links can be handle with AliasTrans.
        • mikeudinM Offline
          mikeudin
          1. Set active scene first object to, for example, variable MyFirstObject.
          2. Merge another scene to active document. All new objects will be pasted on the top of all in hierarchy.
          3. Put all objects before MyFirstObject to null.
          4. Place the null where you need.
          https://mikeudin.net
          ManuelM 1 Reply Last reply Reply Quote 1
            Manuel @mikeudin
            hoo thanks a lot @mikeudin I somehow didn't though about this one xD
            • ROMANR Offline
              ROMAN
              Mike, thank you a lot!
