    Finding name/handle to last object merged into scene
    3 Posts 3 Posters 716 Views 2 Watching
    • N Offline
      nicholas_yue
      After calling MergeDocument()
      merge_status = c4d.documents.MergeDocument(doc, path,
                                                 c4d.SCENEFILTER_MERGESCENE | c4d.SCENEFILTER_OBJECTS)
      I check merge_status to be true and wish to find some handle/name to the object associated with the call to MergeDocument(), how do I do that ?
      I tried the following on an empty scene
              ao = doc.GetActiveObject()
      that works if I am calling MergeDocument for a single path but if I am calling MergeDocument (in a loop) for a collection of paths, GetActiveObject() points to the same object, not the next one corresponding to the next path I am merging into the scene
        there's no direct way of doing it. You must store the different object. Either you can store the original object's list and select/inverse the selection to retrieve all the objects that were not in the original document. Or you can store the object in a list each time you import a document.
        import os
        from c4d import gui
        def GetNextObject(op):
            if op==None:
                return None
            if op.GetDown():
                return op.GetDown()
            while not op.GetNext() and op.GetUp():
                op = op.GetUp()
            return op.GetNext()
        def GetOriginalObjectList():
            originalObjects = list()
            child = doc.GetFirstObject()
            if child is None:
                return originalObjects
            while child:
                originalObjects.append(child)
                child = GetNextObject(child)
            # Store the original object in a list
            originalObjects = GetOriginalObjectList()
            mergedObject = list()
            path="D:\\MAXON\\temp\\merging_doc"
            for root, dirs, files in os.walk(path):
                for name in files:
                    filePath = os.path.join(path,name)
                    merge_status = c4d.documents.MergeDocument(doc, filePath, c4d.SCENEFILTER_MERGESCENE | c4d.SCENEFILTER_OBJECTS)
                    if merge_status:
                        mergedObject.append(doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN))
            c4d.CallCommand(100004767) # Deselect All object
            # select all object that were on the orignal document
            for obj in originalObjects:
                obj.SetBit(c4d.BIT_ACTIVE)
            c4d.CallCommand(100004794) # Invert Selection
            #Print all the object list we gather during the import.
            for objList in  mergedObject:
                print (objList)
        # Execute main()
          Hello @nicholas_yue,
          without any further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
