    FieldList Modifiers
    r20sdkc++
    6 Posts 3 Posters 1.2k Views 1 Watching
    • J Offline
      JohnTerenece
      I am working on a plugin that utilize Fields to affect the position of points in a spline. With the code listed below that I took from the FieldList Manual I am able to retrieve the falloff value from the positions I feed into the Fields.
      However, the returned value does no give the effects of the Delay/Smooth/Spring/Decay Modifiers within the Field. How can I get the modified value?
      Here is a video for clarity of
      				GeData data;
      				Matrix opMat = op->GetMg();
      				const DescID fieldParameterID(idFieldList);
      				if (!op->GetParameter(fieldParameterID, data, DESCFLAGS_GET::NONE))
      					return returnArray;
      				CustomDataType* const customData = data.GetCustomDataType(CUSTOMDATATYPE_FIELDLIST);
      				FieldList* const  fieldList = static_cast<FieldList*>(customData);
      				if (!fieldList)
      					return returnArray;
      				Int32 fieldListCount = 0;
      				if (fieldList)
      					fieldListCount = fieldList->GetCount();
      				if (fieldListCount > 0)
      					maxon::BaseArray<maxon::Vector> positions;
      					maxon::BaseArray<maxon::Vector> uvws;
      					maxon::BaseArray<maxon::Vector> directions;
      					resultVoid = positions.Resize(vectorArray.GetCount());
      					resultVoid = uvws.Resize(vectorArray.GetCount());
      					resultVoid = directions.Resize(vectorArray.GetCount());
      					Int32 pointIndex = 0;
      					for (maxon::Vector& pos : positions)
      						pos = opMat * vectorArray[pointIndex];
      						pointIndex++;
      					FieldInput points(positions.GetFirst(), directions.GetFirst(), uvws.GetFirst(), pointIndex, Matrix());
      					FieldOutput results = fieldList->SampleListSimple(*op, points) iferr_return;
      					Bool valid = FALSE;
      					for (Int32 index = 0; index < positions.GetCount(); index++)
      							// Retreive falloff value to use
      							results._value[index];
      Any help would be greatly appreciated.
      John Terenece
      • F Offline
        Fritz
        Hi John,
        important for field "memory" effects that depend of previous frames is the correct "caller" in the FieldInfo. This is important for the list to know whom to store the previous frame data for, as many sources can sample the same field list. The SampleListSimple you are using does not require passing a FieldInfo and I would assume that should still work as you are passing the caller (*op) to the Sample call, but maybe maybe something is broken :D. It might be worth trying the longer route by creating a FieldInfo and calling the general Sample function.:
        maxon::Result< void > SampleList (const FieldInfo &info, const FieldInput &inputs, FieldOutput &outputs)
        https://developers.maxon.net/docs/cpp/2023_2/struct_field_info.html
        Regards
        Fritz
        • J Offline
          JohnTerenece
          @fritz
          Thank you for the response Fritz.
          I tried swapping my code from using SampleListSimple to SampleList and I am still getting the same results as before. My code for sampling now looks like this.
          const FieldInfo info = FieldInfo::Create(op, points, FIELDSAMPLE_FLAG::VALUE) iferr_return;
          FieldOutput results;
          results.Resize(vectorArray.GetCount(), FIELDSAMPLE_FLAG::VALUE) iferr_return;
          fieldList->SampleList(info, points, results);
          John Terenece
            Our DropEffector have a falloff and it seems to work nicely with the Time and Delay you could maybe have a look at it. I don't see the use of CalcFields in your code that could be something to check.
            • J Offline
              JohnTerenece
              Thanks for the response Manuel, I got it working.
              John Terenece
                Would be nice to share the solution.
