    EnchanceMenu Questions
    c++sdk
    15 Posts 3 Posters 2.3k Views 2 Watching
      well it's not really possible. The pluginMenu (Extension menu since S22) is dynamic.
      It is possible to insert your plugin before the plugin list like so.
      But if you pop out the menu, it will appear like so:
      you have to search for a command that have the following string IDM_PLUGINS
      auto GetLastItem = [&pluginTitle, &GetTileFromContainer](const BaseContainer* bc) -> GeData*
      	iferr_scope_handler
      		return nullptr;
      	Int32						id;
      	GeData* dat;
      	GeData* res = nullptr;
      	BrowseContainer browse(bc);
      	// Int32 countToThree = 0;
      	while (browse.GetNext(&id, &dat))
      		if (id == MENURESOURCE_COMMAND)
      			const String commandString = dat->GetString();
      			if (commandString.Compare("IDM_PLUGINS"_s) == maxon::COMPARERESULT::EQUAL)
      				return res;
      		else
      			res = dat;
      	return nullptr;
      D 1 Reply Last reply Reply Quote 0
      • D Offline
        d_schmidt @Manuel
        Hi @m_magalhaes, I think I understand that part, but the limitation seems to harsh.
        To go back to a more clear example, there is the Arnold plugin folder.
        alt text
        So just so I completely understand I have two questions. How is this structure done? I know if you have multiple plugins than the top level folder is created, but if this isn't being done in EnhanceMainMenu fashion I don't get it.
        Second, would it be possible to do this same sort of layout, but across multiple complies. Imagine if the Arnold Light tools came out later. Would it be possible to put it in this layout?
        Thanks for sticking through this so far!
        Dan
          I don't have the code of how they are doing it, but it seems those are CommandData using GetSubcontainer and ExecuteSubID to execute the proper command. This will create a menu for each entry that you define in the GetSubcontainer function. (note that this doesn't work currently in python)
          You could maybe use the Message function to react and build an private data stored in your command. But it seems not possible to send a message to a CommandData.
          If you want your user to "group" your plugins, they can just create a parent directory for all of them.
          plugins>parent>plugin1Folder
          plugins>parent>plugin2Folder
          That will Create a submenu called "parent" to the Extension menu.
          I don't think what you are trying to do is possible.
          • D Offline
            d_schmidt @Manuel
            Hi @m_magalhaes, I was running a bunch of different tests and trying to figure some stuff out on my own, but I'm back with what I think are my last three questions on this topic.
            alt text
            I was able to create this, and it seems to be working pretty well, but I have to have two plugins registered.
            Bool PluginStart()
               if(!RegisterCommandTest1())//empty, not doing anything
                   return FALSE;
                if(!RegisterCommandTest2())// making the menu
                   return FALSE;
            Even though the RegisterCommandTest1() plugin is doing nothing if I doubt register two plugins in the complile the menu isn't created. Even if I use PLUGINFLAG_HIDE on RegisterCommandTest1() the menu still isn't created.
            alt text
            Is there a way to create the menu with only one plugin being registered?
            My other question is with how I'm making the Cube entry in the first picture using
             bc.InsData(Ocube, "CMD");
            This seems like the easiest way to create entries for plugins, but if the plugin is hidden with PLUGINFLAG_HIDE, it also doesn't sure up in this menu, is there a way around this?
            And if not, how is an icon attached to an entry? I find some posts about the issue and some information in the Python SDK, but I wasn't able to get any of it working in C++.
            Thank you so much for the help through this!
            Dan
            • D Offline
              d_schmidt
              I was doing more testing and I realized I should be using PLUGINFLAG_HIDEPLUGINMENU not PLUGINFLAG_HIDE, so ignore the part about that, sorry!
                no, you need to register two plugins to be sure to have the folder in the menu and none have to be hidden of course. The "problem" you will not be able to detach this submenu. (by clicking the doted line on the top of the menu)
                The icon will be the icon registered when you register the plugin itself, it's automatic. This is the way you add it to your menu
                bc.InsData(MENURESOURCE_COMMAND, maxon::String("PLUGIN_CMD_1021433")); // character
                bc.InsData(MENURESOURCE_COMMAND, maxon::String("PLUGIN_CMD_5159")); // cube
                Do you want to display another icon than the one you register your plugin with ?
                yes, use PLUGINFLAG_HIDEPLUGINMENU 🙂
                • D Offline
                  d_schmidt @Manuel
                  I was mostly just curious to how you would do it.
                  Although would the case be that if you want an icon you do it as a command and make a plugin?
                  And if you don't want an icon you could just react to it via ExecuteSubID?
                  Dan
                    in both case you need to add an action in ExecuteSubID. If you register the command you will just call it, otherwise you have to execute some code.
                    I would say that it's better to register your own CommandData, it will be icon ready and easier if you want to move it to another plugins package.
                      Hello @d_schmidt,
                      without any further questions, we will consider this topic as solved by Monday and flag it accordingly.
                      • D Offline
                        d_schmidt
                        Hi! Sorry about not replying and closing the topic. This has been solved. Thank you for all the help!
