    create a cube that disappears when you return?
    10 Posts 4 Posters 1.5k Views 2 Watching
    • JH23J Offline
      JH23
      I have a question, this is that every time I use this type of script, when I try to return it stays there, and it is somewhat annoying, I do not know how to fix it, I would be very grateful if you could help me
      from c4d import gui
          cube = c4d.BaseObject(c4d.Ocube)
          doc.InsertObject(cube)
        Hi @JH23 your question is not clear for use what do you mean that disappears? Do you mean from the scene?
        You are inserting it into the document so the owner is the document.
        If you want to remove an object from the scene you need to call GeListNode.Remove.
        • JH23J Offline
          JH23
          Hi @m_adam I mean that when creating an Object with BaseObject, when going back it remains in the environment.
          • CairynC Offline
            Cairyn @JH23
            @jh23 I guess you mean undo by "return". But you have no undo functionality in your code at all, so undoing has no effect.
            To support Undo functionality, you need to include the commands StartUndo, EndUndo, and AddUndo, which you can look up in the official API documentation.
            • JH23J Offline
              JH23
              @Cairyn Thanks, I'll check it
                ferdinand @JH23
                Hello @JH23,
                thank you @Cairyn for answering this. Here is a brief snippet illustrating the use of the undo logic in Cinema 4D SDK.
                """Example for pushing modifications onto the undo stack.
                As discussed in:
                    https://developers.maxon.net/forum/topic/13366
                References:
                    [1] https://developers.maxon.net/docs/py/2023_2/modules/
                     c4d.documents/BaseDocument/index.html#BaseDocument.AddUndo
                    # Create a cube object.
                    # An undo block can contain multiple modifications, e.g., changing the
                    # position and rotation of an object. Most undo operations have to be
                    # invoked before the changes have been carried out on an object, e.g.,
                    # renaming it, changing its position, etc.
                    # The only exception to that is the operation for inserting a new node
                    # into the scene graph, e.g., inserting a cube object into the document.
                    # Here AddUndo has to be called after the operation is being carried out.
                    # For details see c4d.documents.BaseDocument.AddUndo()[1].
                    # Start an undo block.
                    doc.StartUndo()
                    # Insert the cube.
                    # Add the undo for inserting the cube.
                    doc.AddUndo(c4d.UNDOTYPE_NEW, cube)
                    # Close the undo block.
                    doc.EndUndo()
                    # Notify Cinema 4D of the changes made by us.
                ferdinandF CairynC 2 Replies Last reply Reply Quote 0
                  ferdinand @ferdinand
                  Hello @JH23,
                  without further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
                  • CairynC Offline
                    Cairyn @ferdinand
                    @ferdinand said in create a cube that disappears when you return?:
                    waitwaitwait...
                    According to the documentation (AddUndo), it's the other way round:
                    Always has to be called before a change is made.
                    In the case of the creation of a new object the call is done afterwards, after insertion into the document/object/track/sequence but before calling subsequent functions like BaseDocument.SetActiveObject() which creates another undo:
                    Also makes more sense that way round, because in a standard case (insertion being the exception), the Undo system has to store the state before the script makes the change, otherwise the original state would already be overwritten.
                      Hey @Cairyn,
                      good catch and my bad. I fixed the code above to not cause any confusion. Thank you for taking the time to point it out.
                        Hello @JH23,
                        without any further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly.
