    Xcode warnings about internationalization and language
    Cinema 4D SDK
    macos c++
    1.3k
    • fwilleke80F
      fwilleke80
      I'm sure this has been asked before somewhere, but is there a way to suppress all these nonsense warnings? I remember I had been getting them earlier before, and somehow managed to suppress them. Now, after updating to Xcode 12.3, they're back, they're many, they're persistent, and they're annoying.
      Thanks in advance for help!
      Frank
      www.frankwilleke.de
      • ManuelM
        while you can click each warning to enabling and migrating, i didn't found a solution to update all project at once. (in xcode at least)
        I've asked our tech team if you can safely migrate and enable that option and if they can come with a new kernel_app.
        I will be back with the answer 🙂
        Manuel.
        • ManuelM
          this will be fixed with a futur release of the project tools.
          • fwilleke80F
            fwilleke80
            Thanks, that's nice to know!
            So, if it can be fixed in the Project Tool, it can also be fixed in the project files I already have. Do you know what I'd have to change?
            Frank
            www.frankwilleke.de
            • ManuelM
              @fwilleke80 said in Xcode warnings about internationalization and language:
              As i said, i didn't found any solution to update all the projects at once inside Xcode. You need to update them one by one.
              But you can also do it for one project and make a difference between two xcode project (.xcodeproj) and create a script to modify the files. That could maybe work.
              • fwilleke80F
                fwilleke80
                Of course, I’d have to do it one by one.
                But I don’t know what to do. How do I make it go away?
                www.frankwilleke.de
                • ManuelM
                  @m_magalhaes said in Xcode warnings about internationalization and language:
                  When you click the warning itself, it should ask you to enable the option of Base Internationalization and if you click the other one, it should ask you to Migrate the project.
                  Isn't that the case ?
                  • fwilleke80F
                    fwilleke80
                    Oh, ok 😂
                    I didn’t know if it’s ok to migrate, and simple didn’t try... the whole time I was looking for a way to suppress the warnings 😳
                    Erm, thanks!
                    www.frankwilleke.de
                    • r_giganteR
                      r_gigante
                      The updated version of the projecttool is available at this link[URL-REMOVED].
                      • fwilleke80F
                        fwilleke80
                        Thank you!
                        www.frankwilleke.de
