    How to change the EXR compression method via python
    Scheduled Pinned Locked Moved Cineware SDK
    7 Posts 3 Posters 3.1k Views 1 Watching
    • P Offline
      pyr
      I need to change my exr compression to one scanline at a time but beside using a c4d default document is there any other way to change it directly in a script?
        mp5gosu
        Here you go: https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/762c9d505e0ed2f09dafdd8c6cef972a82d084e8/scripts/04_3d_concepts/rendering/render_settings_openexr_data_r20.py
        • P Offline
          pyr
          The script change the compression method to zip not to Zips or what i expected: RLE because rle was the given value.
            mp5gosu
            Oh yes, you are right. The SDK example doesn't work at all.
            Problem is, maxon.Id is wrong. maxon.InternedId would be the correct way for setting the save options. Here's the correct code:
            Copyright: MAXON Computer GmbH
            Author: Maxime Adam
            Description:
                - Configures OpenEXR output render format with SetImageSettingsDictionary() then reads these with GetImageSettingsDictionary().
            Class/method highlighted:
                - c4d.bitmaps.SetImageSettingsDictionary()
                - c4d.bitmaps.GetImageSettingsDictionary()
            Compatible:
                - Win / Mac
                - R20, R21, S22, R23
            import maxon
                # Retrieves render data and its container
                renderData = doc.GetActiveRenderData()
                bc = renderData.GetDataInstance()
                # Gets image filters options
                saveOptions = bc.GetContainerInstance(c4d.RDATA_SAVEOPTIONS)
                # Sets OpenEXR output format
                bc[c4d.RDATA_FORMAT] = c4d.FILTER_EXR
                # Defines OpenEXR settings
                compressionmethodID = maxon.InternedId('net.maxon.mediasession.openexr.export.compressionmethod')
                halffloatID = maxon.InternedId('net.maxon.mediasession.openexr.export.halffloat')
                layernumberingID = maxon.InternedId('net.maxon.mediasession.openexr.export.layernumbering')
                # Configures OpenEXR format options with a maxon.DataDictionary
                exportSettings = maxon.DataDictionary()
                exportSettings.Set(compressionmethodID, maxon.Id("rle"))
                exportSettings.Set(halffloatID, True)
                exportSettings.Set(layernumberingID, True)
                # Stores settings in render data container
                c4d.bitmaps.SetImageSettingsDictionary(exportSettings, saveOptions, c4d.FILTER_EXR)
                # Pushes an update event to Cinema 4D
                # Retrieves OpenEXR images settings
                settings = c4d.bitmaps.GetImageSettingsDictionary(saveOptions, c4d.FILTER_EXR)
                # Reads and prints OpenEXR format options
                print("openexr.export.compressionmethod: " + str(settings.Get(compressionmethodID)))
                print("openexr.export.halffloat: " + str(settings.Get(halffloatID)))
                print("openexr.export.layernumbering: " + str(settings.Get(layernumberingID)))
              mp5gosu
              @m_adam maybe the code example in the repo should be updated. 😉
              • P Offline
                pyr
                <3<3<3<3
                  Thanks a lot for the update and yes maxon.InternedId should be used instead of maxon.Id.
                  I will take care of updating the example in Github.
