    HOW TO BIND KEYBOARD SHORTCUT TO PLUGIN
    pythonr21
    3 Posts 2 Posters 501 Views 1 Watching
    • gheyretG Offline
      gheyret
      Hi~
      How can i binding a keyboard shortcut to my CommandData plugin.
      I find c4d.gui.AddShortcut() in sdk , but it's add shortcut every time of start c4d.
      I'm not clear exactly what's wrong.
      here is the simple code:
      from c4d import gui, plugins
      class CMDData(plugins.CommandData):
          def Execute(self, doc):
              print "Hello Cinema"
      def set_shortcut():
          bc = c4d.BaseContainer()
          bc.SetInt32(c4d.SHORTCUT_PLUGINID, 121212)
          bc.SetLong(c4d.SHORTCUT_ADDRESS, 0)
          bc.SetLong(c4d.SHORTCUT_OPTIONMODE, 0)
          bc.SetLong(0,0)
          bc.SetLong(1,c4d.KEY_F11)
          return gui.AddShortcut(bc)
          plugins.RegisterCommandPlugin( 121212, "Shortcut Test", 0, None, "", CMDData())
          set_shortcut()
      www.boghma.com
        you should want to check if the shortcut already exist and is assign to your command plugins.
        You will found information on that thread
        If you have any more question, please ask.
        gheyretG 1 Reply Last reply Reply Quote 0
        • gheyretG Offline
          gheyret @Manuel
          @m_magalhaes
          Now i know how to solve my problem!
          Thank you for your reply.
          Cheers!
          www.boghma.com
