    Adding an Icon to a GeDialog Menu Group
    pythonsdkwindows
    13 Posts 3 Posters 1.5k Views 3 Watching
    • ? Offline
      A Former User
      Hello!
      Is it possible to add an icon next to a GeDialog Menu Group as in the File > Export menu? I didn't see anything in the Python or C++ documentation. Thank you!
      What I have so far...
      self.MenuSubBegin("Export...")
      self.MenuAddString(ALEMBIC_ID,"Alembic (*.abc)")
      self.MenuSubEnd()
        unfortunately string menu definitions with an icon are not being recognised by dialogs (unlike in pop up menus). If you want to have a menu item with an icon, you will have to use GeDialog.MenuAddCommand, which will display their icon next to them. Clicking on these will however immediately execute said command. So this:
        self.MenuAddCommand(c4d.Ocube)
        will add a the string "Cube" to the menu, display the cube object icon next to it and add a cube object to your scene when clicked. If you want anything custom, you will have to implement a dedicated CommandData plugin for it.
        • ? Offline
          A Former User
          Hello MAXON SDK Specialist 😄 ! Congrats again.
          I had tried your suggestion already: creating a dedicated CommandData for my command, but I couldn't get a submenu working with it. Do you know if it's possible to have a submenu for a dedicated CommandData plugin?
          Thank you!
            I hadn't any problems regarding your problem. At least in my understanding of it. Below you will find an example for two CommandData plugins, where one does reference the other in the dialog it displays. Feel free to ask further questions if anything remains unclear 😉
            PS: I ran this on R23 and R21 Win. I know from your screenshots that you are on Win (if I am not mixing something up here), but please add OS tags and version tags in the future, as they can be important.
            """Demonstrates the usage of icons in a dialog menu.
            # Please use unique plugin IDs obtained from PluginCafe.com.
            ID_CMD_ICON = 1053528
            ID_CMD_MENU = 1053529
            class IconMenueDialog(c4d.gui.GeDialog):
                """The dialog opend by MenuCommandData.
                References IconCommandData in its menu.
                def CreateLayout(self):
                    """Creates the menu of the dialog.
                    self.MenuFlushAll()
                    self.MenuSubBegin("Stuff")
                    # You can also pass in some of the node types. Thhis here will
                    # act like clicking on the cube object in the menus of Cinema.
                    # Our little CommandData plugin.
                    self.MenuAddCommand(ID_CMD_ICON)
                    self.MenuSubEnd()
                    self.MenuFinished()
                    self.AddStaticText(2000, c4d.BFH_CENTER, name="Blah")
                def InitValues(self):
                def Command(self, id, msg):
            class IconCommandData(c4d.plugins.CommandData):
                """Just a plugin that acts as command to be executed.
                def Execute(self, doc):
                    """Just prints something to the console.
                    print("IconCommandData is being executed.")
            class MenuCommandData(c4d.plugins.CommandData):
                """The plugin that opens the menu.
                def __init__(self):
                    self._dialog = None
                    """Just opens IconMenueDialog.
                    if self._dialog is None:
                        self._dialog = IconMenueDialog()
                    self._dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC,
                                      pluginid=ID_CMD_MENU,
                                      xpos=- 1,
                                      ypos=- 1)
                def RestoreLayout(self, sec_ref):
                    """Retores the dialog on layout changes.
                    # Restores the layout
                    return self._dialog.Restore(pluginid=ID_CMD_MENU, secret=sec_ref)
            def register():
                """Regissters the plugins.
                # A makeshift icon.
                icon = c4d.bitmaps.BaseBitmap()
                icon.Init(32, 32)
                # Registration.
                # The plugin with a icon.
                c4d.plugins.RegisterCommandPlugin(id=ID_CMD_ICON,
                                                  str="IconCommand",
                                                  info=0,
                                                  icon=icon,
                                                  help="The command to call.",
                                                  dat=IconCommandData())
                # The menu command that does not have an icon.
                c4d.plugins.RegisterCommandPlugin(id=ID_CMD_MENU,
                                                  str="MenuCommand",
                                                  info=0,
                                                  icon=None,
                                                  help="Opens the dialog with a menu.",
                                                  dat=MenuCommandData())
                register()
            • ? Offline
              A Former User @ferdinand
              @zipit Hi!
              Thank you for the example. This is not what I am seeking unfortunately.
              As in the initial post's screenshot, I'm looking to add an icon next to the menu group (where the green star is in this screenshot):
              Is it possible?
              Thanks!
                execute MenuCommand, it will do what you want.
                • ? Offline
                  @zipit I think we're not understanding each other. I want to put an icon to the left of a menu command that has a sub menu. Your GeDialog example's menu commands with icons do not have sub menus. If you go to File > Export and look at the disk icon next to Export (which has a sub menu), THAT is what I want to create in a GeDialog. I hope it's clearer.
                  Thank you!
                    Hi @blastframe,
                    sorry for taking so long to answer. I do understand your problem now. You want to display the icon on the sub menu header. I have been working on your problem, but my initial solution did not work. I now had a look on how Cinema does it internally, and will try to do this on Monday in Python (with unfortunately no guarantee that this will be possible) .
                    Sorry again for the delay, but I had mostly to settle in here at Maxon this week. Have a nice weekend.
                      Hi @blastframe,
                      I am sorry to inform you, that this is currently not possible. Because the procedures used by Cinema internally cannot be reflected to Python at the moment. We will continue to track this topic internally and inform you here if there are going to be changes and/or we did find an alternative route.
                      • ? Offline
                        @zipit Thank you, Ferdinand, for looking into it!
                          mogh
                          Any updates on this ?
                          if yes would be nice to incorporate this into your nice "menue example":
                          https://developers.maxon.net/forum/topic/14276/building-menus-with-c4dpl_buildmenu-in-s26/3?_=1785138165926
                            ferdinand @mogh
                            Hey @mogh,
                            It depends a bit on what you mean with 'this'. Loading menu resources still does not seem to work in Python. I just tried, and while loading for example the main menu resource in your plugin just works fine, I cannot make it work with a locally defined plugin resource. Below you can see me loading M_EDITOR, i.e., the main menu resource, into the py-cmd_gui_resources_2024 example.
                            That is probably what I was referring to a bit fuzzily with 'I am sorry to inform you, that this is currently not possible. Because the procedures used by Cinema internally cannot be reflected to Python at the moment.' six years ago. I would have to sit down and debug this piece by piece to see what is going wrong with loading locally defined menu resources (or if I just made a mistake in the resource files). Resources in Cinema 4D are a bit different from plugin resources, and menu resources have never been publicly documented or demonstrated, neither in C++ nor in Python. So, this being broken is not impossible.
                            What you can do right now, is define a string menu item with an icon. But you will not be able to use this to create submenus with an icon as the original question was about. You can only create a string menu item with an icon, but not a submenu with an icon.
                            class IconMenuDialog(c4d.gui.GeDialog):
                                def CreateLayout(self) -> bool:
                                    """Called by Cinema 4D when the GUI of the dialog is being built.
                                    self.GroupBorderSpace(5, 5, 5, 5)
                                    # Add a menu called "Items".
                                    self.MenuSubBegin("Items")
                                    # And a submenu called "Objects".
                                    self.MenuSubBegin("Objects")
                                    # Here we use string menu items with the &i icon embed code. This only works for items and
                                    # not for submenus, therefore resources are currently the only way to define icons for submenus.
                                    self.MenuAddString(1000, f"Item 1&i{c4d.Ocube}&")
                                    self.MenuAddString(1001, f"Item 2&i{c4d.Osphere}&")
                                    self.MenuSubEnd()
                                    # Same thing, but here we use commands instead of string menu items. This will automatically
                                    # add the icon and label of the command to the menu item. When invoked, this will execute also
                                    # the command without us having to implement this ourself.
                                    self.MenuSubBegin("Splines")
                                    self.MenuAddCommand(c4d.Osplinecircle)
                                    self.MenuAddCommand(c4d.Osplinerectangle)
                                    self.MenuSubEnd()
                                    self.MenuSubEnd()
                                dialog: IconMenuDialog = IconMenuDialog()
                                dialog.Open(c4d.DLG_TYPE_ASYNC, defaultw=200, defaulth=100)
                              mogh
                              Yes I wanted submenu with Icon, thanks for Up to Date clarification.
