    Selecting Different components but in Different modes
    14 Posts 4 Posters 3.3k Views 2 Watching
    • N Offline
      noseman
      thank you so much for the detailed reply, and helping me save a lot of time by not doing it that way after all 🙂
      I am trying to come up with a "shortcut" method for something I'm doing a tutorial on.
      All the functionality is already possible inside C4D, but to set it up you need to do a bunch of things and set a bunch of settings.
      The "manual" way is:
      1. Use Axis Center to align and Center the Object Axis to the Selected Edge.
      2. Set the Modeling Axis to "Object"
      3. Change Component mode to Polygons
      4. Select your Polygons
      5. Use Quantizing to Move or Rotate the said Polygons.
        All this could be possible via a script, instead of doing Matrix math 🙂
        Thank you very much again for your input!
        you lost me a bit in your workflow description, sorry. I am not really a Cinema user (anymore). But if I understand you correctly, you basically only want to to swizzle the modelling axis, which is pretty easy (the hard part of your request was all the interaction stuff). Below is an example on how you could do that.
        For your exact use case you would have to select an edge and then execute the script, the modelling axis of the selected object will then be swizzled. By executing the script multiple times you can cycle through the three possible configurations. The script is neither bound to a specific document mode nor number of selected elements.
        zipit
        """Script Manager script.
        Swizzles the modeling axis of the selected polygon object when run. As a
        side effect the active tool is changed to the LiveSelection tool and set
        into "Free" mode. You will have to pretty up the script yourself if you
        want a more streamlined experience.
        def swizzle_modelling_axis(doc, op):
            """Swizzles the modeling axis of the passed object.
            Args:
                doc (c4d.documents.BaseDocument): The active document.
                op (c4d.PolygonObject): A node in the active document.
            Raises:
                TypeError: When op is not a PolygonObject.
            def swizzle_matrix(m):
                """Swizzles a matrix, pushing in numerical and looping order of
                its components (e.g. v1, v2, v3 becomes v3, v1, v2).
                return c4d.Matrix(off=m.off, v1=m.v3, v2=m.v1, v3=m.v2)
            # Sort out non-polygon-objects.
            if not isinstance(op, c4d.PolygonObject):
                msg = ("swizzle_modelling_axis() requires a polygon object. "
                      "Received: {type}.")
                raise TypeError(msg.format(type=type(op)))
            # We need the axis to be free in order to be able to modify the axis.
            # For that we select the live selection tool and set it to free mode.
            doc.SetAction(c4d.ID_MODELING_LIVESELECTION)
            plugin = c4d.plugins.FindPlugin(c4d.ID_MODELING_LIVESELECTION,
                                            c4d.PLUGINTYPE_TOOL)
            if plugin is None:
                plugin[c4d.MDATA_AXIS_MODE] = c4d.MDATA_AXIS_MODE_FREE
            # Get the modeling axis, swizzle it and write it back.
            axis = swizzle_matrix(op.GetModelingAxis(doc))
            op.SetModelingAxis(axis)
            op.Message(c4d.MSG_UPDATE)
            """Entry point.
        • N Offline
          noseman
          Thank you very much.
          The "swizzling" can be achieved with the Axis Center:
          using these settings.
          BUT the code you posted is very valuable for me to evolve my spaghetti coding... copy from here, and paste there 🙂
          Thanks Again!
          • N Offline
            noseman
            Full disclosure, I just realized that in "Axis Modification" Tool, when in Polygon mode, if you hover over an edge and click, it places the Axis there...
            I guess most of what I was trying to do is already there...
            "The path to wisdom, is paved with errors..."
            [just made that up...] Noseman
              I was not aware that Cinema can do this and I thought that was what you were going for, given your statement '[..] and the modeling Z Axis to align to that edge [...]'. Also: Swizzling is just computer graphics slang for creating a new vector or matrix by shuffling the components of an existing vector or matrix.
              Since I do not really understand what you are trying to do, I cannot really point you into the right direction. I can only point out that the 'matrix maths' that comes up with transforms in Computer Graphics is not all that scary. I made post here and recently here on the topic. Feel free to come back if you have any problems.
              zipit
                @noseman said in Selecting Different components but in Different modes:
                yes, the only thing that doesn't answer your question it that you want the Z axis to be align with the edge.
                The "L" shortcut come really useful if you keep that shortcut pressed while clicking on the polygon/edge/point you want to move to your axis. Than when you release the shortcut, is disable that command.
                Don't be afraid of math, it's like cos, sin, tan, for some artist out there, it's really useful and not so complicated. (sometimes it's just function that you need to apply, not to understand like going from local to global and global to local)
                • X Offline
                  x_nerve
                  Hi:
                  This is a very old post, but it's very helpful.
                  I have found the algorithm for the Z axis to be align with the edge, but the sample script from the post does not restore the modeling axis. Can you provide a method to restore the original default modeling axis?
                    To "save" the current modeling axis matrix, as you are (i think) using a script, you need to save the matrix inside the document's BaseContainer
                    Of course you have to retrieve your own unique ID (the icon on the top of this page)
                    from c4d import gui
                    # this ID have to be unique
                    myownID = 123456
                    # Main function
                        if op is None:
                        if doc is None:
                            raise ValueError("doc isn't initialized !!!")
                        # retrieves the modeling axis
                        mmt = op.GetModelingAxis(doc)
                        # saves the modeling axis inside the document's BaseContainer'
                        doc[myownID] = mmt
                        # swaps the axis
                        temp = mmt.v1
                        mmt.v1 = mmt.v3
                        mmt.v3 = temp * -1.0
                        # Sets the modeling axis
                        op.SetModelingAxis(mmt)
                        # Pushes an update event to Cinema 4D
                    # Execute main()
                    to restore the previous modeling axis's position:
                    from c4d import gui
                    myownID = 123456
                    # Main function
                        if op is None:
                        if doc is None:
                        #retrieves the stored matrix inside the document's BaseContainer
                        mmt = doc[myownID]
                        # sets the current modeling axis matrix
                    # Execute main()
                    But I'm not sure if it's this position you want to restore.
                    • X Offline
                      x_nerve
                      Hi:
                      Unfortunately, once the modeling axis is set, there is no way to recover.If I click on any point, the coordinates are the same.Even if you create a new polygon object and click on any point, the coordinates are the same.The coordinates of the entire file will not be refreshed unless a new document is created, but the script will still be able to retrieve the coordinate data normally。
                      Coordinates are no longer refreshed and are consistent.
                        Do you mean with the code i provided ?
                        Do you have some step procedure / code to reproduce this behavior ?
                        Witch version of Cinema4D are you using ?
                        • X Offline
                          x_nerve
                          HI:
                          The modeling axis cannot be restored to its default state using the following sample code.Create a new cube object, collapse, and select any point.The world coordinates of points are all 0.
                              Args:
                              Raises:
                              if plugin is None:
                              """Entry point.
                            I can't reproduce that, what version are you using ?
                            the only moment where a coordinates could be 0 is if the point and the object's pivot are sharing the same coordinates AND you have the "Enable Axis" enable.
                            (or you are in object's rel or abs coordinate and the point is at the same position of the pivot's object.
                            As if you were at the same time in object's mode and in point mode. (moving the object's pivot point and the modeling axis at the same time)
                            So this look like a bug.
                            by the way, what do you call the "default state" ? The last modeling axis position ? the position when you selected the polygon ?
