    BaseLinkArray looses link? (was: Refreshing a nested BaseShader)
    r20r21s22r23c++
    19 Posts 4 Posters 2.6k Views 3 Watching
    • fwilleke80F Offline
      fwilleke80
      this is related to: https://developers.maxon.net/forum/topic/12823/shader-that-gets-data-from-an-object-refresh/6
      My ShaderData uses data from an ObjectData to generate its output. It requests the data from the object during InitRender(). Using the pattern shown in the above linked thread, the ObjectData sets the Shader dirty (DIRTYFLAGS::DATA) and also sends an MSG_UPDATE to it, once the ObjectData has finished computing its data. So, after, every change to the ObjectData's attributes, the ShaderData should be dirty and is told to update.
      This works flawlessly, if the shader sits directly e.g. in a material's Color channel (even without the MSG_UPDATE). However, if I put it into another shader, e.g. a Colorizer, the shader's result is not updated until I change any of the shader's attributes. What can do I have to do with the shader to make sure it is updated, and the material preview is re-rendered, even if it's located somewhere deep down in other shaders in the material?
      EDIT: I found out what the reason is! Just don't know the solution.
      As shown in the above linked thread, I am using a BaseLinkArray to keep a list of observers. Initially, this works fine. The ObjectData holds an Observable object, and the ShaderData nicely subscribes to it. Calling const Int32 observerCount = _observers.GetRealCount(doc); on the BaseLinkArray returns 1. Setting the ShaderData dirty from within the ObjectData works.
      But after I put the shader into a Colorizer, _observers.GetRealCount(doc) returns 0, while _observers.GetCount() still returns 1. Therefore, using _observers.GetIndex() to get the link to the shader from the array returns nullptr. It seems the BaseLink in the array is broken after putting the linked shader into another one.
      Why? Well, probably because the BaseShader that now sits inside the Colorizer is not the same object as the one that was there before, right? But shouldn't that be updated automatically by Cinema, when the shader is placed inside the Colorizer? Isn't that what BaseLinks are meant for?
      Thanks & greetings,
      Frank
      www.frankwilleke.de
        fwilleke80
        My first idea would be, to catch a specific message that is maybe sent to the shader when it is being put into the Colorizer.
        However, the only message that comes in when this happens, is 1001071 (MSG_MULTI_RENDERNOTIFICATION). I guess I could use it to update the BaseLink in the observable. But it seems that message comes in very often, simply when clicking through the material editor. Does not sound like a good idea.
        www.frankwilleke.de
          one question / suggestion :
          is there any difference if you change the order of creating your shader ?
          for example
          add your shader -> add colorizer (that will move your shader inside the colorizer)
          add colorizer-> go inside and add your shader.
          If there's any change, that could mean that your shader is "copied" and not only moved.
          I would check if the CopyTo function is used in the process. That would allow you to update the object's array.
          I would need a bit of time to recreate an example and see if i can find a solution.
          (you can probably test it before me)
            fwilleke80
            Hi Manuel,
            thanks for the hint! This does in deed sound promising.
            And yes, the shader is copied when put into the Colorizer. As far as I remember, almost nothing in Cinema is ever moved, it's all copied.
            I added CopyTo() to my shader class, and implemented it like this:
            Bool MyShader::CopyTo(NodeData *dest, GeListNode *snode, GeListNode *dnode, COPYFLAGS flags, AliasTrans *trn)
            	iferr_scope_handler
            		GePrint(err.GetMessage());
            		return false;
            	// Get document of destination node
            	// Note: When CopyTo() is called because the shader is moved into another shader (e.g. Colorizer), this is always nullptr.
            	BaseDocument *destDoc = dnode->GetDocument();
            	// Get container of source node
            	const BaseContainer &dataRef = static_cast<BaseShader*>(snode)->GetDataInstanceRef();
            	// Get linked object from source node's container
            	BaseObject *linkedObject = dataRef.GetObjectLink(XTERRAINOPERATORSHADER_OPERATORLINK, snode->GetDocument());
            	// If we have a linked object, and if the destination node has a document
            	if (linkedObject && destDoc)
            		// Get the node's ObjectData
            		MyObjectData *linkedNodeData = linkedObject->GetNodeData<MyObjectData>();
            		if (! linkedNodeData)
            			return false;
            		// Get ref to the Observable object
            		MyObservable &observable = linkedNodeData->GetObservableRef();
            		// Subscribe to shader to observable
            		observable.Subscribe(dnode, destDoc) iferr_return;
            	return SUPER::CopyTo(dest, snode, dnode, flags, trn);
            It changes nothing. Still doesn't work. _observers.GetIndex() still returns nullptr, even though _observers.GetCount() returns 1.
            What I noticed:
            • MyShader::CopyTo() is called numerous times, even if I just navigate through the material manager. When I put my shader into a Colorizer, CopyTo() is called 10 times!
            • When CopyTo()is called because I move the shader into a Colorizer, dnode->GetDocument() returns nullptr. I tried using snode->GetDocument() instead. Now, after creating my shader, then moving it into a Colorizer, and then changing the Colorizer's gradient once, I have 25(!) subscribers in the observable. And all the BaseLinks are broken!! Not a single one can be retrieved with GetIndex().
            I still ask myself why I even have to do all this. Isn't the purpose of BaseLinks to have stable links to nodes even if they're moved and change pointer address? All in all, I'm starting to wonder if a hidden InExcludeList in MyObject's description wouldn't be easier. Incredibly clumsy, yes, but it might just work...
            Frank
            www.frankwilleke.de
              About the hidden include list, yes it should work. Note that even if you store the baselink inside the basecontainer of your object, they should be updated by an aliastrans.
              That would be a bit better than an hidden in/exclude list.
                fwilleke80
                Aha, that's interesting!
                So, if I got this right, the problem is that my BaseLinkArray is hidden inside my NodeData where it can't be found by Cinema, hence can't be updated by the AliasTrans?
                If it was just one BaseLink it would be easy. But I have an arbitrary number of BaseLinks in a BaseLinkArray. Can that somehow be stored in the BaseContainer? Or is there any other way to make my BaseLinkArray known to Cinema, so it can be updated? Or a way to update it myself?
                In the SDK docs, it says about AliasTrans::Translate(): "Translates the links in all objects that the translator has come across.". Can I make it "come across" my BaseLinkArray? πŸ˜„
                @kbar: In the other thread you mentioned that you also implemented an observer pattern. Did you run into this problem, too?
                Thanks & greetings,
                Frank
                www.frankwilleke.de
                  when you Init your aliastrans, it trying to find all it can everywhere. So every BaseContainer are scanned.
                  That also include the document's BaseContainer.
                  As you can't say aliastrans where to look, you have to place your data where it can find them.
                  (but the hidden in/exclude should work)
                    fwilleke80
                    Thank you πŸ™‚
                    Frank
                    www.frankwilleke.de
                      fwilleke80
                      Just a little follow-up on this:
                      It would be very much appreciated if there was like a Message() coming in, or a callback, or some other way to simply present any BaseLink members of the NodeData to an AliasTrans.
                      Frank
                      www.frankwilleke.de
                        fwilleke80
                        It's a never-ending story...
                        InExcludeList does not seem to be the answer.
                        I have changed my Observable code to use an InExcludeList in the description of the Observable (the BaseObject that is to be observed). When that object is linked in the Observer (the BaseShader that links to the BaseObject via a LINK description element), I catch SetDParameter(), remove the Shader from the previously linked Observable's InExcludeList, and add it to the newly linked Observable's InExcludeList.
                        So far, that works just fine.
                        However, when nesting the BaseShader in another shader, e.g. a Colorizer, the shader's CopyTo() is called. Here, I am trying to add the destination shader to the Observable's InExcludeList. It does not work.
                        Bool MyShaderData::CopyTo(NodeData *dest, GeListNode *snode, GeListNode *dnode, COPYFLAGS flags, AliasTrans *trn)
                        	iferr_scope_handler
                        		return false;
                        	// Get everything we need
                        	BaseDocument *sourceDoc = snode->GetDocument();
                        	BaseDocument *destDoc = dnode->GetDocument(); // This is always NULL!
                        	BaseShader *sourceShader = static_cast<BaseShader*>(snode);
                        	BaseShader *destShader = static_cast<BaseShader*>(dnode);
                        	// Get linked object from the shader's LINK
                        	const BaseContainer &dataRef = sourceShader->GetDataInstanceRef();
                        	BaseObject *linkedObject = dataRef.GetObjectLink(MYSHADER_OPERATORLINK, snode->GetDocument());
                        	if (linkedObject && sourceDoc/*destDoc*/) // Can't check destDoc, as it's always NULL
                        		// Get linked object's Observable instance
                        		MyObjectData *linkedObjectData = linkedObject->GetNodeData<MyObjectData>();
                        		if (!linkedObjectData)
                        			return false;
                        		MyObservable &observable = linkedObjectData->GetObservableRef();
                        		// Add destShader as new observer to the linked object's Observable
                        		observable.Subscribe(destShader, linkedObject, MYOBJECT_OBSERVERLIST, sourceDoc) iferr_return;
                        	// Translate (doesn't seem to make a difference)
                        	if (trn)
                        		trn->Translate(true);
                        I am looking at the InExcludeList in the linked object. After MyShader::CopyTo()was called, the list always appears empty. observable.Subscribe() is called, but the new copy of the shader does not show up in it.
                        So, my question remains:
                        How can I maintain a BaseLink to my shader in an object, after the shader has been copied?
                        Frank
                        ADDITION:
                        Interesting. If I add an InExcludeList to any object, just for a test, and not actually handle it anywhere in my code, it also looses the link to any BaseShader I add to the list, when that BaseShader is then nested in another shader. I just added a useless InExcludeList to some object, linked a Noise shader in it, and then nested the Noise Shader in a Colorizer. Whoops, the InEcludeList is empty 😢
                        So, it seems, the reason for this not working isn't even in my code. Is this a bug in Cinema, or a general problem, or does the object that holds the InExcludeList have to do something in order to make it work? Catch some message, or something like that?
                        www.frankwilleke.de
                          fwilleke80
                          Any news on this one?
                          A heads-up about how to maintain a reliable list of BaseLinks to BaseShaders in the scene would be most welcome! πŸ˜‰
                          Greetings,
                          Frank
                          www.frankwilleke.de
                            ferdinand @fwilleke80
                            @fwilleke80 said in BaseLinkArray looses link? (was: Refreshing a nested BaseShader):
                            I tried this in Python and was not able to reproduce it. Which does not mean that it odes not exist, but you might want to provide more details on what leads to this described behaviour. Below you will find a Python script which does what I did read into the quoted paragraph of yours above.
                            zipit
                            """Will mimic the steps you described to invoke a faulty InEx behavior.
                            You can run this without any prerequisites in the Script Manager, it will
                            create a null object and a material with three shaders which are linked in
                            the null as described by you.
                            I was not able to reproduce the behavior described by you in the posting,
                            specifically this paragraph:
                                "I just added a useless InExcludeList to some object, linked a Noise
                                the InEcludeList is empty [...]"
                            I interpreted your statement as such, as you want to link the shaders BEFORE
                            they are actually a part of the scene graph. At least this is the only way
                            your sentence does make sense to me. But as far as I can tell, everything
                            just seems to work fine?
                            Are you sure, that your shader graph is actually valid? Because if it isn't,
                            obviously also the InEx will fail.
                                """Will create a setup as described by you.
                                # A null with an InEx user data element.
                                null = c4d.BaseList2D(c4d.Onull)
                                bc = c4d.GetCustomDataTypeDefault(c4d.CUSTOMDATATYPE_INEXCLUDE_LIST)
                                bc[c4d.DESC_NAME] = "shaders"
                                null.AddUserData(bc)
                                inex = null[c4d.ID_USERDATA, 1]
                                # A material and three shaders as described by you.
                                material = c4d.BaseList2D(c4d.Mmaterial)
                                shader_colorizer = c4d.BaseList2D(c4d.Xcolorizer)
                                shader_noise = c4d.BaseList2D(c4d.Xnoise)
                                shader_noise.SetName("noise")
                                shader_noise_nested = c4d.BaseList2D(c4d.Xnoise)
                                shader_noise_nested.SetName("noise_nested")
                                # Trying to fulfill your condition of linking the shaders BEFORE they
                                # are bing nested.
                                inex.InsertObject(shader_noise, 0)
                                inex.InsertObject(shader_noise_nested, 0)
                                null[c4d.ID_USERDATA, 1] = inex
                                # Compose the material, i.e. do the nesting.
                                material[c4d.MATERIAL_USE_DIFFUSION] = True
                                material[c4d.MATERIAL_USE_REFLECTION] = False
                                material[c4d.MATERIAL_COLOR_SHADER] = shader_noise
                                material[c4d.MATERIAL_DIFFUSION_SHADER] = shader_colorizer
                                shader_colorizer[c4d.SLA_COLORIZER_TEXTURE] = shader_noise_nested
                                # Insert the nodes into the scene graph.
                                material.InsertShader(shader_colorizer)
                                material.InsertShader(shader_noise)
                                shader_colorizer.InsertShader(shader_noise_nested)
                                doc.InsertObject(null)
                                doc.InsertMaterial(material)
                                # Update stuff
                                material.Message(c4d.MSG_UPDATE)
                                material.Update(True, True)
                              fwilleke80
                              Hi @zipit,
                              thank you for investing the time to try this out!
                              I don't know why it works for you, but it certainly does not for me.
                              Take a look at this video, where I reproduce the problem completely without writing any custom plugin code. Loosing the BaseLink to a BaseShader when that shader is nested into another shader seems to be default behaviour in Cinema 4D, and I find that highly unsatisfying πŸ˜‰
                              I wish the SDK Team would say something about this, or even present a workaround.
                              Video:
                              https://frankwilleke.de/misc/C4D_looses_link_to_nested_shader.mov
                              In this video, you can see that, for a test, I added an IN_EXCLUDE and a LINK element to the description of the standard Cube object. Then I create a material, and in that material I create a Noise shader. That shader I link in the IN_EXCLUDE and the LINK elements. Works as expected. Then I nest the Noise shader in a Colorizer shader, and both links are gone. Since none of my plugin code is contributing to this behaviour, I don't think that the issue is anywhere in my code.
                              Since both, the IN_EXCLUDE and the LINK element, are using BaseLinks, I think the BaseLink itself is the culprit here.
                              Frank
                              Edit:
                              Found a way to demonstrate this without even touching any .h/.res files to add elements:
                              Video:
                              https://frankwilleke.de/misc/C4D_looses_link_to_nested_shader_2.mov
                              When linking a BaseShader inside an XPresso Object Node, the link is also lost when the linked shader is being nested.
                              www.frankwilleke.de
                                sorry for the delay (i was on vacation last week), I'm on it.
                                  fwilleke80
                                  No worries πŸ˜‰
                                  www.frankwilleke.de
                                  • a_blockA Offline
                                    a_block
                                    I only briefly scanned this topic, but I have a few thoughts and questions. Simply ignore me, if I talk rubbish as usual...
                                    Does this problem occur with every shader that supports subshaders or only a few? Does it happen with the layer shader as well, for example?
                                    If I remember correctly BaseLinks work only correctly (especially in AliasTrans context), if the linked object is a valid member of a document (e.g. in a NodeData for example via branch. Now, if my mind doesn't trick me, there are certain shaders, which do not properly hold there subshaders in the shader tree. Which caused me all kinds of issues, when trying to initiate shader updates from a NodeData and I ended up with special code for certain shaders (I think, it were mainly those stemming from good ol' Smells Like Almonds shaders), basically extracting the subshaders from their parameters.
                                    And another thought, maybe you already tried and I overlooked it in this thread: Does using ForceGetLink() change anything for you, when trying to resolve those links? If I'm not mistaken, C4D also resolves links beyond a document's context with this.
                                    Andreas
                                      fwilleke80
                                      Hi Andreas,
                                      Well, I didn't try ALL the shaders there are, but it does happen with shaders that are not my plugin shader. So far, with all shaders I have tried.
                                      In my example videos, I do have the LINK and IN_EXCLUDE elements on an object in the scene, and in an XPresso node, both loose the link.
                                      ForceGetLink() does not change anything, unfortunately. It just returns nullptr.
                                      Frank
                                      www.frankwilleke.de
                                        fwilleke80
                                        I suspect I won't get an answer here... πŸ˜•
                                        I have figured out a way on my own now. It's pretty cumbersome, requires too much code in too many places to post it here, and seems to work flawlessly though it looks fishy.
                                        It is based on keeping BaseLinks to the BaseMaterials that own the BaseShaders. Then, when I need to notify the Observers, I go through all the materials in the list, then iterate all their child BaseShaders until I find the ones that have a link to my Observable object, and then I notify these. Plus, some extra measures to make sure the Observer re-subscribes when specific things happen to it.
                                        It is, like we say in German, from behind through the chest into the eye, but it actually works. Hooray.
                                        Frank
                                        www.frankwilleke.de
                                          never say never. Sorry for the delay, this is a "unusual" case ^^
                                          I did try several options (observable, notification, message etc)
                                          I finished using the function AddEventNotification witch is private. (so i had to figure out how it was working)
                                          The shader and the viewport is updated but with a small latency.
                                          We can try to improve that solution if you want or you can go with your own.
                                          Below the code for both the ObjectData and the Shader.
                                          The shader need to register to be notified. (this is automatic, nothing to add on the ObjectData's side)
                                          Than you need to check the message in Message
                                          I feel that the important part is to remove the notification and re/add it. (not sure what it can do if you don't do it ^^)
                                          class pc12019_object : public ObjectData
                                          	INSTANCEOF(pc12019_object, ObjectData);
                                          	static NodeData* Alloc() { return NewObjClear(pc12019_object); }
                                          	BaseObject* GetVirtualObjects(BaseObject* op, HierarchyHelp* hh) override
                                          		return BaseObject::Alloc(Ocube);
                                          	Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags) override
                                          		if (!description->LoadDescription(Obase))
                                          			return false;
                                          		const DescID* singleid = description->GetSingleDescID();
                                          		const DescID cid = DescLevel(OBJ_COLOR, DTYPE_COLOR, 0);
                                          		if (!singleid || cid.IsPartOf(*singleid, nullptr))
                                          			BaseContainer bc = GetCustomDataTypeDefault(DTYPE_COLOR);
                                          			bc.SetString(DESC_NAME, "Color"_s);
                                          			bc.SetData(DESC_GUIOPEN, true);
                                          			description->SetParameter(cid, bc, DescLevel(ID_OBJECTPROPERTIES));
                                          		flags |= DESCFLAGS_DESC::LOADED;
                                          		return SUPER::GetDDescription(node, description, flags);
                                          class pc12019_shader : public ShaderData
                                          	INSTANCEOF(pc12019_shader, ShaderData);
                                          	static NodeData* Alloc() { return NewObjClear(pc12019_shader); }
                                          	Vector Output(BaseShader* sh, ChannelData* cd) override
                                          		return color;
                                          	Bool Read(GeListNode* node, HyperFile* hf, Int32 level) override
                                          		// need to read the color
                                          		return true;
                                          	Bool Write(GeListNode* node, HyperFile* hf) override
                                          		// need to write the color
                                          		return true;
                                          	Bool CopyTo(NodeData* dest, GeListNode* snode, GeListNode* dnode, COPYFLAGS flags, AliasTrans* trn) override
                                          		pc12019_shader* destShader = static_cast<pc12019_shader*>(dest);
                                          		destShader->color = color;
                                          		return true;
                                          		if (!description->LoadDescription(Xbase))
                                          			return false;
                                          		DescID cid = DescLevel(SH_OBJECTLINK, DTYPE_BASELISTLINK, 0);
                                          			BaseContainer bc = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                                          			bc.SetString(DESC_NAME, "Link"_s);
                                          			bc.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_LINKBOX);
                                          			BaseContainer ac;
                                          			ac.SetInt32(Obase, 1);
                                          			bc.SetContainer(DESC_ACCEPT, ac);
                                          			description->SetParameter(cid, bc, DescLevel(ID_SHADERPROPERTIES));
                                          	INITRENDERRESULT InitRender(BaseShader* sh, const InitRenderStruct& irs) override
                                          		iferr_scope_handler
                                          			err.DiagOutput();
                                          			return INITRENDERRESULT::UNKNOWNERROR;
                                          		if (irs.doc == nullptr)
                                          			return INITRENDERRESULT::OK;
                                          		BaseContainer* bcShader = sh->GetDataInstance();
                                          		if (bcShader == nullptr)
                                          		BaseObject * linkedObject = bcShader->GetObjectLink(SH_OBJECTLINK, irs.doc);
                                          		if (linkedObject == nullptr)
                                          		RemoveNotification(sh, linkedObject);
                                          		AddNotification(sh, linkedObject);
                                          		GeData data;
                                          		linkedObject->GetParameter(OBJ_COLOR, data, DESCFLAGS_GET::NONE);
                                          		color = data.GetVector();
                                          		Bool Init(GeListNode* node) override
                                          			BaseMaterial* mat = static_cast<BaseMaterial*>(node);
                                          			BaseContainer* bc = mat->GetDataInstance();
                                          			bc->SetLink(SH_OBJECTLINK, nullptr);
                                          			return true;
                                          		void Free(GeListNode* node) override
                                          			GeData data;
                                          			BaseObject* op = static_cast<BaseObject*>(node);
                                          			if (op == nullptr)
                                          				return;
                                          			BaseDocument* doc = node->GetDocument();
                                          			if (doc == nullptr)
                                          				return;
                                          			op->GetParameter(SH_OBJECTLINK, data, DESCFLAGS_GET::NONE);
                                          			BaseList2D* linkedObject = data.GetLink(doc);
                                          			RemoveNotification(node, linkedObject);
                                          		Bool RemoveNotification(GeListNode* node, BaseList2D* linkedObject)
                                          			if ((node == nullptr) || (linkedObject == nullptr))
                                          				return false;
                                          			if (op == nullptr)
                                          				return false;
                                          			BaseDocument* doc = op->GetDocument();
                                          			if (doc == nullptr)
                                          				return false;
                                          			if (linkedObject->FindEventNotification(doc, op, NOTIFY_EVENT::CACHE))
                                          				return linkedObject->RemoveEventNotification(doc, op, NOTIFY_EVENT::CACHE);
                                          			return true;
                                          		Bool AddNotification(GeListNode* node, BaseList2D* linkedObject)
                                          			if (op == nullptr)
                                          				return false;
                                          			if (doc == nullptr)
                                          				return false;
                                          			if (!linkedObject->FindEventNotification(doc, op, NOTIFY_EVENT::MESSAGE))
                                          				return linkedObject->AddEventNotification(op, NOTIFY_EVENT::MESSAGE, NOTIFY_EVENT_FLAG::NONE, nullptr);
                                          			return true;
                                          		Bool Message(GeListNode* node, Int32 type, void* data) override
                                          			if (type == MSG_NOTIFY_EVENT)
                                          				NotifyEventData *eventData = static_cast<NotifyEventData*>(data);
                                          				// as we can add several notification we check if we received the right one
                                          				if (eventData->eventid == NOTIFY_EVENT::MESSAGE)
                                          					NotifyEventMsg* eventMsg = static_cast<NotifyEventMsg*>(eventData->event_data);
                                          					// Checks if the message that the object is fowarding us if the right one. (MSG_DESCRIPTION_POSTSETPARAMETER)
                                          					if (eventMsg->msg_id == MSG_DESCRIPTION_POSTSETPARAMETER)
                                          						DescriptionPostSetValue* dpsv = static_cast<DescriptionPostSetValue*>(eventMsg->msg_data);
                                          						const Int32 id  = dpsv->descid[0][0].id;
                                          						// Checks if the parameter that have been change is part of the message.
                                          						if (id == OBJ_COLOR)
                                          							// ask the shader to update itself.
                                          							node->SetDirty(DIRTYFLAGS::ALL);
                                          							node->Message(MSG_DESCRIPTION_POSTSETPARAMETER); // this will trigger the mat update and the viewport update. (with a small delay)
                                          					return true;
                                          			return SUPER::Message(node, type, data);
                                          private:
                                          		Vector color = Vector(1);
