    RDATA_PATH not working with Render Settings
    Cinema 4D SDK
    r23 python
      A Former User
      I'm trying to set the RDATA_PATH of the active RenderData, but it's not working. It prints the correct path and sets all of the other data, but it doesn't set the File... path in the Render Settings dialog. Am I missing anything? Thank you!
      import c4d,os
      from c4d import storage
      def main(doc):
          activeRenderData = doc.GetActiveRenderData()
          rd = activeRenderData.GetData()
          rd[c4d.RDATA_XRES] = 2048
          rd[c4d.RDATA_YRES] = 1080
          rd[c4d.RDATA_FORMAT] = c4d.FILTER_MOVIE
          rd[c4d.RDATA_LOCKRATIO] = True
          docName = doc.GetDocumentName()
          fileName, ext = os.path.splitext(docName)
          fileName = "%s.mp4"%fileName
          fileName = os.path.join(storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP),fileName)
          rd[c4d.RDATA_PATH] = fileName
          print(rd[c4d.RDATA_PATH])
          doc.GetActiveRenderData().SetData(rd)
          main(doc)
        A Former User
        I found success using the BaseContainer.SetFilename method instead of using the = assignment operator.
        rd.SetFilename(c4d.RDATA_PATH, str(fileName))
        • M
          Hi @blastframe as demonstrated in tokensystem_render_r17.py you should always operate on the BaseContainer.
