    Edge To Spline Modeling Command
    sdkr20c++
    3 Posts 2 Posters 925 Views 1 Watching
    • J Offline
      JohnThomas
      I have a polygon object with an Edge Selection tag associated with it that has a selection of edges. Independently browsing through the selection tag I know that it contains the edges that it should.
      When I try to use SendModelingCommand to have Cinema return the spline of these selected edges it always fails with SendModelingCommand returning false.
      if (op->GetDown() != nullptr)
      	PolygonObject *poly = (PolygonObject*)op->GetDown();
      	if (poly == nullptr)
      		return nullptr;
      	PolygonObject *clonePoly = (PolygonObject*)poly->GetClone(COPYFLAGS::NONE, nullptr);
      	if (clonePoly == nullptr)
      		return FALSE;
      	if (neighbor.Init(clonePoly->GetPointCount(), polyArray, clonePoly->GetPolygonCount(), nullptr))
      		clonePoly->SetSelectedEdges(&neighbor, edgeselectionTag, EDGESELECTIONTYPE::SELECTION);
      		AutoAlloc<BaseDocument> tempDoc;
      		ModelingCommandData cd;
      		BaseContainer bc = BaseContainer();
      		cd.doc = tempDoc;
      		cd.bc = &bc;
      		cd.op = clonePoly;
      		if (!SendModelingCommand(ID_MODELING_EDGE_SPLINE_COMMAND, cd))
      			return FALSE;
      I looked through some forums posts and through the sdk and I don't understand why the SendModelingCommand is always returning false.
      Any help would be greatly appreciated.
      John Thomas
        you should use the command ID MCOMMAND_EDGE_TO_SPLINE and not ID_MODELING_EDGE_SPLINE_COMMAND
        One remark to your code, you are returning both nullptr and FALSE.
        That's kind of strange.
        You should have a look at our error handling system. It's a bit scary at the beginning but it's really powerful and useful for debugging.
        static maxon::Result<BaseObject*> pc12903(BaseDocument* doc)
        	iferr_scope;
        	CheckArgument(doc != nullptr);
        	BaseObject* op = doc->GetActiveObject();
        	if (op == nullptr)
        		return nullptr; // not an error for me.
        	PolygonObject* clonePoly = static_cast<PolygonObject*>(op->GetClone(COPYFLAGS::NONE, nullptr));
        		return maxon::NullptrError(MAXON_SOURCE_LOCATION);
        	cd.doc = nullptr; // this command in particular doesn't need any document.
        	cd.bc = &bc;
        	cd.op = clonePoly;
        	if (!SendModelingCommand(MCOMMAND_EDGE_TO_SPLINE, cd))
        		return maxon::UnknownError(MAXON_SOURCE_LOCATION);
        	BaseObject* spline = clonePoly->GetDown();
        	if (spline == nullptr)
        	spline->Remove(); // just to be sure
        	return spline;
        • J Offline
          JohnThomas
          Thanks for the response, that was exactly what I needed.
          John Thomas
          • i_mazlovI i_mazlov referenced this topic on
