    R23 plugin windows 10 error
    Cinema 4D SDK
    r23 c++ windows
    1.3k
    • mikeudinM
      mikeudin
      I am currently trying to complete a plugin for R23 in Windows 10. After compiling the code I distributed the plugin to several people and they were able to successfully run the plugin with the exception of one person. The one exception gave this error.
      WARNING: Error loading file:///C:/Users/MyUser/AppData/Roaming/Maxon/Maxon Cinema 4D R23_DBA5903C/plugins/MyPlugin/R23/MyPlugin.xdl64: Could not load dll because of
        Could not load MSVCP140D.dll due to Windows System Error #126: The specified module could not be found. [win_dll.cpp(302)].
        Could not load VCRUNTIME140D.dll due to Windows System Error #126: The specified module could not be found. [win_dll.cpp(302)].
        Could not load ucrtbased.dll due to Windows System Error #126: The specified module could not be found. [win_dll.cpp(302)].. (file:///C:/Users/MyUser/AppData/Roaming/Maxon/Maxon Cinema 4D R23_DBA5903C/plugins/MyPlugin/R23/MyPlugin.xdl64) [win_dll.cpp(322)]
        Cause: Windows System Error #126: The specified module could not be found. [win_dll.cpp(316)] [general.cpp(401)]
      How can i fix that?
      https://mikeudin.net
      • r_giganteR
        r_gigante
        Hi @mikeudin , it's likely, looking at the log, you've compiled it in Debug mode. Please compile it in Release mode and see if it works on your customers machines.
        Best, R
        mikeudinM 1 Reply Last reply Reply Quote 0
        • mikeudinM
          mikeudin @r_gigante
          @r_gigante Ouch! thank you!
          • A
            adam_k_garner
            Hello @mikeudin! Did this happen to solve your issue?
            I have been working with Insydium on an xparticles load error on several Windows 10 machines, Even a basic maxon plug-in file will not load on my windows machines, and produces a similar error. Ticket escalated, but any info you have might be really helpful!
            Thanks!
            • mikeudinM
              mikeudin
              @adam_k_garner sure it solved my issue
              • A
                adam_k_garner
                Awesome @mikeudin! Thanks for the info. Any idea why this ONE person had the issue on Windows 10?
                • ManuelM
                  @adam_k_garner said in R23 plugin windows 10 error:
                  I've move your other question to a new post. Let's try to fix your issue there if we can help
