    Adding Keyboard Message: KEY_ENTER & KEY_TAB
    4 Posts 3 Posters 660 Views 2 Watching
    • ? Offline
      A Former User
      I would like to request that KEY_ENTER and KEY_TAB are added to the Keyboard Message's Channel.
      This issue has come up several times in the forum. There are some workarounds, it seems, but they aren't nearly as straightforward as checking the Channel's value:
      • [key in dialog [SOLVED]](https://developers.maxon.net/forum/topic/8455
      • GetInputEvent - Enter Key
      • Unnecessary Executions Under BFM_INPUT_VALUE
      I'm sure there are reasons those two keys weren't included, but it would be very helpful if this implementation could be revisited.
      For anyone facing this issue, here are some workarounds in a script:
      from c4d import gui
      GROUP_ID1=1000
      TEXT_FIELD=1001
      class KeyDlg(gui.GeDialog):
          def CreateLayout(self):
              self.SetTitle("Key Test")
              if self.GroupBegin(GROUP_ID1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 1, 1):
                  self.GroupBorderNoTitle(c4d.BORDER_THIN_IN)
                  self.AddStaticText(TEXT_FIELD, c4d.BFH_CENTER | \
                  c4d.BFH_SCALE | c4d.BFV_CENTER | c4d.BFV_SCALE, 0, \
                  0, "Press the Enter Key")
              self.GroupEnd()
          def Message (self, msg, result):
              if msg.GetId() == c4d.BFM_INTERACTSTART:
                  bc = c4d.BaseContainer()
                  if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_TAB, bc):
                      if bc[c4d.BFM_INPUT_VALUE] == 1:
                          print(c4d.KEY_TAB,"Tab")
                          self.SetString(TEXT_FIELD,"Tab")
                          self.LayoutChanged(TEXT_FIELD)
                  if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ENTER, bc):
                          print(c4d.KEY_ENTER,"Enter")
                          self.SetString(TEXT_FIELD,"Enter")
              if msg.GetId() == c4d.BFM_INPUT:
                  if msg.GetInt32(c4d.BFM_INPUT_DEVICE) == c4d.BFM_INPUT_KEYBOARD:
                      channel = msg.GetInt32(c4d.BFM_INPUT_CHANNEL)
                      txt = msg.GetString(c4d.BFM_INPUT_ASC)
                      if channel == c4d.KEY_SPACE:
                          txt = "Space"
                      elif channel == c4d.KEY_LEFT:
                          txt = "Left"
                      elif channel == c4d.KEY_RIGHT:
                          txt = "Right"
                      elif channel == c4d.KEY_UP:
                          txt = "Up"
                      elif channel == c4d.KEY_DOWN:
                          txt = "Down"
                      print(channel,txt)
                      self.SetString(TEXT_FIELD,txt)
              return gui.GeDialog.Message(self, msg, result)
      dlg = KeyDlg()
      dlg.Open(c4d.DLG_TYPE_MODAL, defaultw=300, defaulth=50)
      Thank you!
      • indexofrefractionI Offline
        indexofrefraction
        thats a nice one, thank you!
        enter and tab works!
        can't get the last part to work here, tough (c4d.BFM_INPUT)
        • ? Offline
          A Former User
          @indexofrefraction I just tested and it works with my setup. Most of the code comes from former SDK team member Andreas' post here. Perhaps test that? If it doesn't work, I would open a new thread.
          I'd prefer to keep this topic on the KEY_ENTER & KEY_TAB request please.
            @indexofrefraction, as @blastframe said, let's keep that thread clean and ask your question in another thread, this is working on my system.
            @blastframe , we will take into consideration your request.
