    key in dialog [SOLVED]
    Scheduled Pinned Locked Moved PYTHON Development
    3 Posts 0 Posters 416 Views
    • H Offline
      Helper
      On 18/01/2015 at 05:51, xxxxxxxx wrote:
      I try to get Keys within a dialog - with out success
      def CreateLayout(self) :
              self.SetTitle('Stage - Command Line')
              self.GroupBegin(GROUP, c4d.BFH_SCALEFIT, cols=1, title="Generator",)
              self.AddEditText(1001, c4d.BFH_SCALEFIT, editflags=c4d.EDITTEXT_HELPTEXT)
              self.SetString(id = 1001,value  = "enter a Stage command",flags = c4d.EDITTEXT_HELPTEXT)
             self.GroupEnd()
       def Command(self, id_, msg) :
              if id_ == 1001:
                  resultBaseContainer = c4d.BaseContainer()
                  self.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_ENTER,resultBaseContainer)
                  if resultBaseContainer[c4d.BFM_INPUT_VALUE]:
                      print self.GetString(1001)
              bc = c4d.BaseContainer()
              ok = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_TAB, bc)
              if bc[c4d.BFM_INPUT_VALUE] == 1:
                  print "tab key"
              ok = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_ESC, bc)
                  self.Close()
      • H Offline
        Helper
        On 20/01/2015 at 03:02, xxxxxxxx wrote:
        Hi conner,
        I have demonstrated two ways in the following Message function.
        Please be careful!
        By default you need to call gui.GeDialog.Message(self, msg, result). If you fail to do so, C4D will probably freeze.
        If you detect a keyboard input, you may return True, to avoid further processing of the key.
        BUT, again be careful, especially with keys like Enter or Tab. The user expects certain behavior and may be disappointed, if he is no longer able to use the Tab key to switch between dialog elements.
        def Message ( self, msg, result ) :
                # Method A, querying a special key
                ok = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_TAB, bc)
                if ok:
                        print "tab key"
                        return True # if you don't return here, the Tab key will still have the default influence on your dialog
                        # This can get really confusing...
                ok = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ENTER, bc)
                if ok:
                        print "enter"
                # Method B - processing the input message, works nicely for normal keys
                if msg.GetId() == c4d.BFM_INPUT:
                    if msg.GetInt32(c4d.BFM_INPUT_DEVICE) == c4d.BFM_INPUT_KEYBOARD:
                        print "KEYBOARD: "
                        print msg.GetString(c4d.BFM_INPUT_ASC)
                        return True  # return True ONLY on keys you want to process, otherwise standard commands won't work anymore, as long as your dialog is active
                return gui.GeDialog.Message(self, msg, result)
        • H Offline
          Helper
          On 21/01/2015 at 01:57, xxxxxxxx wrote:
          Many Thanks for the solution
