Using "config" plugins to modify the loading queue in R19
Hi all,
I want to use a "config" plugins to read the loading queue in R19. A QueryStartupOrder() function works well in R20 and R21, but it seems like that it is not supported in R19. So, is there a way around it? Thanks!
You can use SetPluginPriority to tell your plugins to load in a specific order. IE tell some plugins to load after others have been loaded. Useful in cases where one of your plugins may register a library that your other plugins need to access as they start up.
Problem solved! Thank you!
Hi @hazzzel, thanks for reaching out us.
The
QueryStartupOrder()has been introduced in R20 and there's no way to call it on previous releases.
As suggested by @kbar , you're instead supposed to make use of theSetPluginPriority()as shown in the Plugin Functions Manual / Priority section to properly specify the plugin priority and control the loading time.Cheers, R
