    Using "config" plugins to modify the loading queue in R19
    r19c++
    4 Posts 3 Posters 1.5k Views 1 Watching
      hazzzel
      Hi all,
      I want to use a "config" plugins to read the loading queue in R19. A QueryStartupOrder() function works well in R20 and R21, but it seems like that it is not supported in R19. So, is there a way around it? Thanks!
      • kbarK Offline
        kbar
        You can use SetPluginPriority to tell your plugins to load in a specific order. IE tell some plugins to load after others have been loaded. Useful in cases where one of your plugins may register a library that your other plugins need to access as they start up.
        https://www.plugins4d.com
          hazzzel
          Problem solved! Thank you!
          • r_giganteR Offline
            r_gigante
            Hi @hazzzel, thanks for reaching out us.
            The QueryStartupOrder() has been introduced in R20 and there's no way to call it on previous releases.
            As suggested by @kbar , you're instead supposed to make use of the SetPluginPriority() as shown in the Plugin Functions Manual / Priority section to properly specify the plugin priority and control the loading time.
            Cheers, R
