    get bitmap of shader in r20
    Scheduled Pinned Locked Moved Cineware SDK
    r20c++
    4 Posts 4 Posters 2.1k Views 2 Watching
      hazzzel
      I'm working on r20, and I found I can't use BaseShader::BakeShaderIntoBaseBitmap() because it is a new feature in r21. Trying find a way around, I want to extract the bitmap of the layer shader. However, my code does not work.
      BaseBitmap* diffuseBitmap ;
      GeData gd;
      BaseShader* shader = bm->GetChannel(CHANNEL_DIFFUSION)->GetShader();
      if (shader->GetType() == Xlayer) {
          LayerShader* layerShader = static_cast<LayerShader*>(shader);
          LayerShaderLayer* layerShaderLayer = layerShader->GetFirstLayer();
          while (layerShaderLayer != NULL)
              if (layerShaderLayer->GetType() == LayerType::TypeShader)
      	    Bool res = layerShaderLayer->GetParameter(LAYER_S_PARAM_SHADER_LINK, gd);
      	    // diffuseBitmap = layerShaderLayer->GetPreview(); // this does not work, too!
      	    BaseLink *bl = gd.GetBaseLink(); // program stop here, and I can't see why
      	    BaseShader *thisShader = static_cast<BaseShader*>(bl->GetLinkAtom(bd));
      	    thisShader->InitRender(irs);
      	    diffuseBitmap = thisShader->GetBitmap();
      	    thisShader->FreeRender();
                  break;
      	layerShaderLayer = layerShaderLayer->GetNext();
      else
      ShowBitmap(diffuseBitmap); // can't see anything here when using 'layerShaderLayer->GetPreview()'
      diffuseBitmap->Save(fn, FILTER_JPG, nullptr, SAVEBIT::NONE); // fail when using 'GetPreview()'
      Could anyone kindly explain where I am doing wrong? Thanks a lot!
        what is wrong with BaseShader::Sample? BakeShaderIntoBaseBitmap is probably only a convenience wrapper around that method. For your program "stoping" (this is a quite broad description), have you ensured, that your BaseLink is actually populated and does not just return the null pointer?
        zipit
          hazzzel
          Thank you for your reply, the BaseShader::Sample() helps me solve this problem. (Except that when the layer shader use transform layer, scale transformation is not automatically handled.) Anyway, thanks a lot!
          • r_giganteR Offline
            r_gigante
            Hi @hazzzel thanks for reaching out us.
            With regard to your question, please consider that you might have to attach a VolumeData to the InitRenderStruct.
            For this scope please have a look at:
            • Sampling a Shader.
            • Creating a VolumeData about using Render::GetInitialVolumeData() or VolumeData::Alloc()
            • Post #8 in Sample a shader thread.
            Best, R.
