    Creating Xpresso Python Node Inputs
    s22sdkpython
    6 Posts 3 Posters 1.5k Views 3 Watching
    • ? Offline
      A Former User
      I'm having a hard time finding documentation about accessing the input ports for the Python Xpresso node, specifically the 'On' port. I know about op.GetInPorts(), but it isn't returning anything. How could I add any of these data types for that matter? Where would I find the IDs for them?
      pythonNode = gv.CreateNode(gv.GetRoot(), 1022471, insert=None, x=200, y=0) #Create python node
      onId = c4d.DescID(c4d.DescLevel(?????))
      pythonNode.AddPort(c4d.GV_PORT_INPUT, onId)
      Thank you!
      • I Offline
        iluxa7k
        Hello
        onId = c4d.DescID(c4d.DescLevel(3999,400006001,1022471))
        ? 1 Reply Last reply Reply Quote 1
        • ? Offline
          A Former User @iluxa7k
          @iluxa7k said in Creating 'On' Python Xpresso Node Input:
          Hi @iluxa7k , thank you for the reply! May I please ask, how did you find this DescID? How can I find the other ports'?
          • ? Offline
            A Former User
            For future people reading this post, I found answers in the C++ documentation for the GV_PYTHON_OPENEDITOR file reference.
            In this DescID: c4d.DescID(c4d.DescLevel(3999,400006001,1022471))
            3999 is the ID for the parameter (GV_PYTHON_ON)
            400006001 is the ID for the Data type (ID_GV_DATA_TYPE_BOOL)
            1022471 is the Python Tag Id
            onId = c4d.DescID(c4d.DescLevel(c4d.GV_PYTHON_ON,c4d.ID_GV_DATA_TYPE_BOOL,1022471))
            longId = c4d.DescID(c4d.DescLevel(c4d.IN_LONG,c4d.ID_GV_DATA_TYPE_INTEGER,1022471))
            linkId = c4d.DescID(c4d.DescLevel(c4d.IN_LINK,c4d.DTYPE_BASELISTLINK,1022471))
            xnode_python.AddPort(c4d.GV_PORT_INPUT, onId)
            xnode_python.AddPort(c4d.GV_PORT_INPUT, longId)
            xnode_python.AddPort(c4d.GV_PORT_INPUT, linkId)
            I do still have questions about how I'd find the DescIDs of this node's parameters through Python if anyone wants to chime in. Thank you.
              Hi unfortunately I didn't found a precise way (except looking into the C++ header file as you did) to find possible IDs.
              Another way could be to add ports you want to add to a node and then from this GvNode you can retrieve all GvPort and their ID. Find an example that iterates all input ports remove them and re-add them
                  if not op:
                  xpressoTag = op.GetTag(c4d.Texpresso)
                  if not xpressoTag:
                  gvMaster = xpressoTag.GetNodeMaster()
                  gvRoot = gvMaster.GetRoot()
                  gvNode = gvRoot.GetDown()
                  ports = gvNode.GetInPorts()
                  portDescIds = []
                  for port in ports:
                      print port.GetName(gvNode), port.GetMainID(), port.GetValueType()
                      portDescIds.append(c4d.DescID(c4d.DescLevel(port.GetMainID(), port.GetValueType(), port.GetNode().GetOperatorID())))
                      port.GetNode().RemovePort(port, True)
                  print portDescIds
                  for portDescId in portDescIds:
                      gvNode.AddPort(c4d.GV_PORT_INPUT, portDescId)
              # Execute main()
              • ? Offline
                A Former User @m_adam
                @m_adam That's a great solution, thank you!
