    How to adress the mograph cloner offset in the attached python code please :)
    3 Posts 3 Posters 569 Views 1 Watching
    • O Offline
      Ofcourse88
          global traveled
          global lastPos
          obj = op.GetObject()
          objMat = obj.GetMg()
          frame = doc.GetTime().GetFrame(doc.GetFps())
          forwardVec = objMat.MulV(c4d.Vector(1.0, 0.0, 0.0))
          sign = 1.0
          try: lastPos
          except NameError:
              lastPos = obj.GetMg().off
          try: traveled
          except NameError:
              traveled = 0
          if frame == 0:
              traveled = 0
              lastPos = objMat.off
              currentPos = objMat.off
              # calculate actual movement
              distVec = currentPos - lastPos
              dotProd = distVec.Dot(forwardVec)
              if dotProd > 0: sign = -1.0
              projVec = forwardVec * dotProd
              dist = projVec.GetLength()
              lastPos = currentPos
              traveled = traveled + sign * dist
          # find the material
          mat = obj.GetTag(c4d.Ttexture)
          mat[c4d.TEXTURETAG_OFFSETX] = traveled / 500.0
          # the factor depends on the texture and the obje
      Hello, how to adress the Mograph cloner offset (cloner is set to object (spline) and i want just to edit the part in the code
      and make it work, but i am affraid i will need to edit more, for example to find the object. I am noob about python or any language, so could you help me someone please 🙂
        Hi @Ofcourse88 welcome in the plugincafe community
        I didn't understand what's your problem, can you try to explain what you exactly want to do, and in which context are you (script editor, Python generator, python tag?)
        If you want to change the Mograph Cloner offset parameter value, then doing
        op[c4d.MG_SPLINE_OFFSET] = 0.5
        Will set the currently selected cloner to 0.5.
        To know parameter id, you can use the console for more information see Console - Drag and Drop.
        • CairynC Offline
          Cairyn
          I just answered this on CGSociety, as the thread was started there:
          https://forums.cgsociety.org/t/help-with-the-simple-but-advanced-rig-at-the-same-time-with-xpresso-or-python-i-am-talking-about-tank-belts/2058564/12
