    Still not possible to find out what's visible in the Timeline?
    r21c++python
    19 Posts 4 Posters 3.9k Views 2 Watching
    • P Offline
      PluginStudent @Cairyn
      @Cairyn said in Still not possible to find out what's visible in the Timeline?:
      one that would return a list of all tracks in the scene.
      Things in Cinema are often stored as internal branches (GetBranchInfo()). So you can read all the branches of all things to get all the things.
      The "Active Object" examples does that to list the content of the scene, including the tracks.
      • CairynC Offline
        Cairyn
        Thank you, @PluginStudent . I have tried to translate the C++ code from the example into a basic Python script that just writes the GetBranchInfo tree to the console; sadly there is a mysterious crash/hang somewhere...
        from c4d import gui
        emCount = 0
        def showBranchInfo(depth, obj):
            global emCount
            # Validity check
            if obj == None: return
            # Object output
            emCount += 1
            print "  " * depth, "Count=", emCount, "(object)"
            if isinstance(obj, c4d.documents.BaseDocument):
                print "  " * depth, "DOC:", obj.GetDocumentName()
            elif not isinstance(obj, c4d.BaseList2D):
                print "  " * depth, "Not a BaseList2D: ", obj
                print "  " * depth, "OBJ:", obj.GetName()
            bis = obj.GetBranchInfo()
            if bis == None or len(bis) == 0:
            for bi in bis: # list of dict{‘head’, ‘name’, ‘id’, ‘flags’}
                if len(bi) == 0: return # ### Test
                listHead = bi['head']
                nodeName = bi['name']
                # List head output
                emCount += 1
                node = None
                print "  " * (depth+1), "Count=", emCount, "(list head)", nodeName
                if listHead == None:
                    print "  " * (depth+1), "No list head"
                elif not isinstance(listHead, c4d.GeListHead):
                    print "  " * (depth+1), "Not a GeListHead:", listHead
                    print "  " * (depth+1), nodeName, listHead
                    node = listHead.GetFirst()
                # Content of sublist branch
                locCount = 0
                if node == None:
                    print "  " * (depth+2), "Empty list"
                while node != None:
                    emCount += 1
                    print "  " * (depth+2), "El:", locCount, node
                    locCount += 1
                    if isinstance(node, c4d.BaseList2D):
                        showBranchInfo(depth + 3, node)
                        # no else case; node was already printed
                    node = node.GetNext()
            # missing here: recurse into children of "node" or "obj"
            print " "
            print "GetBranchInfo"
            print "============="
            showBranchInfo(1, doc)
        If I limit emCount or depth to certain values, this recursion works fine (as mentioned in the code it's not going down into the child lists of a BaseObject but that's a thing I can add later).
        If I just run the code with no limits, C4D hangs (and in one instance even crashed with an access violation) while doing... something. Even after two days of experimenting, I have not found the exact point where it fails. (Half of the code is already validation...) I guess I will need to set up a complete debugging environment to catch the culprit... before even returning to the original question...
        • P Offline
          PluginStudent
          Not sure if it is related to your crash, but I have never seen someone using isinstance() this way.
          In the C4D API, there is IsInstanceOf() to check for inheritance or type. See also Type.
          CairynC 2 Replies Last reply Reply Quote 0
          • CairynC Offline
            Cairyn @PluginStudent
            @PluginStudent isinstance is the plain Python class comparison. IsInstanceOf() does not work here because it compares against type constants, and there is (AFAIK) no such constant for BaseDocument or BaseList2D or GeListHead.
            EDIT: Oh, I'm stupid. I just saw that such a constant is used in the original example... okay, let's try that...
            • CairynC Offline
              @PluginStudent No, didn't work with IsInstanceOf either.
              For completeness: Tbasedocument and Tbaselist2d exist but are only documented in the C++ manual; missing in Python. Tgelisthead does not exist in either, so I still need to check the class against that with the Pythonic isinstance.
                Hi Just to let you know its seems there is currently a bug somewhere (still have to figure out) but to avoid any issue check if the returned GeListHead and then if you iterate over all its children that each c4dAtom returned is alive with C4DAtom.IsAlive before doing anything on it(e.g.s print them).
                That should fix your issue.
                • CairynC Offline
                  Cairyn @m_adam
                  @m_adam Thank you, unfortunately that didn't work either... I check the object, the list head, and the list nodes all for being alive, and I do not get any output that they aren't. The crashes continue.
                  I have compiled the SDK, and the "Active Object Properties" dialog works fine even in places where the Python script hangs. So, it might be a Python-only issue.
                  So far, I think that these places are when the script encounters a "Tags" object (type 200001048). The first place I saw this was under ProjektHooks/PLKHUD/PSUNDOHEAD/PKHOP. When I skipped that branch explicitly, the next place of crash was under Modeling Objects Hooks/Modeling Objects Branch/Plane Manipulator and Pivot Manipulator (both branches contain a "Tags" element). Didn't continue after that.
                  However, trying to exclude these node types didn't help either. Apparently, the objects are so volatile that any way of touching them creates the crash already.
                  (Since the scene tags also hide under these nodes, I do not want to exclude them, anyway.)
                  Here's the code I tried last:
                  from c4d import gui
                  emCount = 0
                  handledList = []
                  def showBranchInfo(depth, obj, f):
                      global emCount, handledList, maxCount, dialogCount
                      try:
                          # Validity check
                          if obj in handledList:
                              print "Already handled! : ", obj
                              print >>f, "Already handled! : ", obj
                              f.flush()
                              handledList.append(obj)
                          if not obj.IsAlive():
                              print "Object not alive!"
                              print >>f, "Object not alive!"
                              f.flush()
                          if obj.GetType() == 200001048:
                              print "Object is 200001048!"
                              print >>f, "Object is 200001048!"
                              f.flush()
                      except:
                          print >>f, "ERROR in validity check"
                          f.flush()
                      try:
                          # Object output
                          emCount += 1
                          print >>f, "  " * depth, "Count=", emCount, "(object)"
                          f.flush()
                              print >>f, "  " * depth, "DOC:", obj.GetDocumentName()
                              f.flush()
                              # this is also a BaseList2D so we can continue
                              print >>f, "  " * depth, "Not a BaseList2D:", obj
                              f.flush()
                              print >>f, "  " * depth, "OBJ:", obj.GetName()
                              f.flush()
                      except:
                          print >>f, "ERROR in object output"
                          f.flush()
                      try:
                          child = obj.GetDown()
                          if child != None:
                              while child:
                                  showBranchInfo(depth + 1, child, f)
                                  child = child.GetNext()
                      except:
                          print >>f, "ERROR in subobject recursion"
                          f.flush()
                      try:
                          if bis == None:
                              print "ERROR: no branch info retrieved"
                              print >>f, "ERROR: no branch info retrieved"
                              f.flush()
                          # empty branch info is allowed, so no len() check!
                      except:
                          print >>f, "ERROR in GetBranchInfo"
                          f.flush()
                      try:
                              try:
                                  if len(bi) == 0:
                                      print "ERROR: no entries in dict list"
                                      print >>f, "ERROR: no entries in dict list"
                                      f.flush()
                                  # print bi['id']
                                  # print bi['flags']
                              except:
                                  print >>f, "ERROR in dict list check"
                                  f.flush()
                              try:
                                  # List head output
                                  emCount += 1
                                  node = None
                                  print >>f, "  " * (depth+1), "Count=", emCount, "(list head)", nodeName
                                  f.flush()
                                  # Crash irgendwo hier
                                      print >>f, "  " * (depth+1), "No list head"
                                      f.flush()
                                  elif not listHead.IsAlive():
                                      print "List head not alive!"
                                      print >>f, "List head not alive!"
                                      f.flush()
                                      print >>f, "  " * (depth+1), "Not a GeListHead:", listHead
                                      f.flush()
                                      print >>f, "  " * (depth+1), nodeName, listHead
                                      f.flush()
                              except:
                                  print >>f, "ERROR in list head output"
                                  f.flush()
                              try:
                                  locCount = 0
                                  if node == None:
                                      print >>f, "  " * (depth+2), "Empty list"
                                      f.flush()
                                  while node != None:
                                      if node.IsAlive():
                                          if node.GetType() != 200001048:
                                              emCount += 1
                                              print >>f, "  " * (depth+2), "El:", locCount, node
                                              f.flush()
                                              locCount += 1
                                                  showBranchInfo(depth + 3, node, f)
                                              print "List node is 200001048!"
                                              print >>f, "List node is 200001048!"
                                              f.flush()
                                          print "List node not alive!"
                                          print >>f, "List node not alive!"
                                          f.flush()
                              except:
                                  print >>f, "ERROR in sublist branch handling"
                                  f.flush()
                      except:
                          print >>f, "ERROR in dictionary loop"
                          f.flush()
                      try:
                          print >>f, "  " * depth, "Returning from depth:", depth
                          f.flush()
                      except:
                          print >>f, "ERROR in return"
                          f.flush()
                      print " "
                      f = open("L:/getbranchinfo.txt", "at")
                      showBranchInfo(1, doc, f)
                      f.close()
                  You can happily ignore the try/except blocks, as they never caught any error.
                  Considering that the code now consists of 80% error checking, this is a very frustrating exercise.
                  Interestingly, my initial example that uses GetCTracks() works fine (for what it does) and does not crash, even when handling (scene) tags. I suspect the issue ultimately lies in the GetBranchInfo() function somewhere.
                    creating a cube and call op.GetBranchInfo is enough to trigger a crash, since its a C++ crash, there is no room for python to catch it.
                    • CairynC Offline
                      Cairyn @m_adam
                      @m_adam oops... didn't expect that, since the Active Object Properties sample works fine (solely in C++).
                      • CairynC Offline
                        Cairyn
                        Okay, it's definitely the Tags node. I added some code to check for the name "Tags" in the list returned by GetBranchInfo() to skip that dictionary entry before even the list head is touched. That works, the recursion/iteration is running through without crash.
                        Of course, that makes the scene tags disappear from the list, so I also added in an else case that explicitly calls GetTags() on the original object, and continues the recursion with any returned tags.
                        For testing, I also added a collector list for the tracks (which were the original goal of this exercise...) and print the tracks at the end of the code. For a few test scenes, this apparently works; I have no idea about the overall soundness and completeness of this workaround though.
                        Here's the code for anyone who might face the same issue:
                        from c4d import gui
                        emCount = 0
                        handledList = []
                        tracks = []
                            global emCount, handledList, maxCount, dialogCount, tracks
                            # Validity check
                                f.flush()
                                f.flush()
                                f.flush()
                            # Object output
                            emCount += 1
                            f.flush()
                                f.flush()
                                f.flush()
                                f.flush()
                            # assemble the tracks of the object
                            addTracks = obj.GetCTracks() # returns a list
                            tracks.extend(addTracks)
                            # go through the children of the object if present
                            if child != None:
                                while child:
                            # check the branch info and go into all dependent branches
                                print "  " * (depth+1), "No branch info retrieved, or empty"
                                print >>f, "  " * (depth+1), "No branch info retrieved, or empty"
                                f.flush()
                                if len(bi) == 0:
                                    f.flush()
                                if nodeName != "Tags":
                                    # print bi['id']
                                    # print bi['flags']
                                    # List head output
                                    emCount += 1
                                    node = None
                                    f.flush()
                                        f.flush()
                                        f.flush()
                                        f.flush()
                                        f.flush()
                                    locCount = 0
                                    if node == None:
                                        f.flush()
                                    while node != None:
                                        if node.IsAlive():
                                                emCount += 1
                                                f.flush()
                                                locCount += 1
                                                f.flush()
                                            f.flush()
                                    print "Tags skipped!"
                                    print >>f, "Tags skipped!"
                                    f.flush()
                                    if isinstance(obj,c4d.BaseObject):
                                        taglist = obj.GetTags()
                                        print "  " * (depth+2), "Tag list, length=", len(taglist)
                                        print >>f, "  " * (depth+2), "Tag list, length=", len(taglist)
                                        f.flush()
                                        for tag in taglist:
                                            showBranchInfo(depth + 3, tag, f)
                            f.flush()
                            global tracks
                            print " "
                            for track in tracks:
                                print track
                                print >>f, track
                            f.close()
                        (also, unsolicited advertising because I really spend too much time with this)
                        https://www.patreon.com/cairyn
                        there you go!
                          Hi, I found the issue, unfortunately, nothing on your side you can do to fix it.
                          I marked this topic as solved, and will bump the topic once a fix is included in a public release.
                          Keep in mind this is a Python only issue.
                          • CairynC Offline
                            Cairyn @m_adam
                            @m_adam okay, good that it's found... I guess I can go with the code above for now that excludes tags explicitly and gathers them in a different recursion.
                            As per the original issue (there is no function in the API that returns the currently visible tracks in timeline n), I guess I would need to make a requirement/suggestion on Maxon's site? Or is something like this planned already?
                              The bug is fixed in R23.
                              Maxime
