    Changing Display Filter Does Not Work When Rendering?
    r21python
    4 Posts 3 Posters 562 Views 2 Watching
    • B Offline
      bentraje
      I have the following code that
      1. Stores Display Filter
      2. Turns them off
      3. Render
      4. Restore Display Filter.
      The problem is when I render (#3) them the #2 is not in effect.
      You can check the illustration of the problem here:
      https://www.dropbox.com/s/r8cpy1lwgkmi1yj/c4d266_display_filter_not_working_rendering_python.mp4?dl=0
      A "correct" render would be there should be no axis handles in the renders.
      You can check the working code below:
      from c4d import gui
      # Main function
              obj_list = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN | c4d.GETACTIVEOBJECTFLAGS_SELECTIONORDER)
              bd = doc.GetActiveBaseDraw()
              displayFilter = bd.GetDisplayFilter()
              # Store Render Data
              rd_saved = doc.GetActiveRenderData().GetClone()
              rd = doc.GetActiveRenderData()
              stored_bounds       = bd[c4d.BASEDRAW_DISPLAYFILTER_BOUNDS]
              stored_multi_axis   = bd[c4d.BASEDRAW_DISPLAYFILTER_MULTIAXIS]
              stored_obj_handle   = bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHANDLES]
              stored_obj_highli   = bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHIGHLIGHTING]
              stored_world_axis   = bd[c4d.BASEDRAW_DISPLAYFILTER_WORLDAXIS]
              # Modify Render Data
              rd[c4d.RDATA_RENDERENGINE]  = c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE
              rd[c4d.RDATA_XRES] = 400
              rd[c4d.RDATA_YRES] = 400
              rd[c4d.VP_PREVIEWHARDWARE_ANTIALIASING] = 3
              # Creates a Multi Pass Bitmaps that will store the render result
              bmp = c4d.bitmaps.MultipassBitmap(int(rd[c4d.RDATA_XRES]), int(rd[c4d.RDATA_YRES]), c4d.COLORMODE_RGB)
              # Adds an alpha channel
              bmp.AddChannel(True, True)
              # Renders the document
              if c4d.documents.RenderDocument(doc, rd.GetData(), bmp, c4d.RENDERFLAGS_EXTERNAL) != c4d.RENDERRESULT_OK:
                  raise RuntimeError("Failed to render the temporary document.")
              bd[c4d.BASEDRAW_DISPLAYFILTER_BOUNDS]             = False
              bd[c4d.BASEDRAW_DISPLAYFILTER_MULTIAXIS]          = False
              bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHANDLES]      = False
              bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHIGHLIGHTING] = False
              bd[c4d.BASEDRAW_DISPLAYFILTER_WORLDAXIS]          = False
              bd.Message(c4d.MSG_CHANGE)
              # Save Image
              c4d.bitmaps.ShowBitmap(bmp)
              # Restore Render Data
              rd_saved.CopyTo(rd, c4d.COPYFLAGS_NONE)
              bd[c4d.BASEDRAW_DISPLAYFILTER_BOUNDS]             = stored_bounds
              bd[c4d.BASEDRAW_DISPLAYFILTER_MULTIAXIS]          = stored_multi_axis
              bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHANDLES]      = stored_obj_handle
              bd[c4d.BASEDRAW_DISPLAYFILTER_OBJECTHIGHLIGHTING] = stored_obj_highli
              bd[c4d.BASEDRAW_DISPLAYFILTER_WORLDAXIS]          = stored_world_axis
      # Execute main()
        you render your document before you make the changes to display filter settings of the active base draw. Because of that they do not take effect in the render πŸ˜‰
        PS: You could also just clone and restore the data container of the BaseDraw instead of having this long list of stored_ variables.
        zipit
        • B Offline
          bentraje
          @zipit
          My bad. Thanks for the catch.
          Have a great day!
            thanks for the answer πŸ™‚
            by the way you could also clone the renderdata, modify the clone and send it to as a parameter to the function RenderDocument. That way, you don't have to "restore" them.
            Just in case, don't forget that data may not be saved in the BaseContainer.
