    Exclude Objects from Environment
    Cinema 4D SDK
    • S
      SolarPH
      Is it possible for objects to be excluded from the environment's effect? For example, if the Fog option is enabled, the fog won't affect several objects that are meant to be not affected.
      I have 2 planes with custom sun and moon textures which is really annoying right now because it always gets affected by the fog, and also I don't want to cover the sky with fog either, so I need to exclude them from the fog effect of the Environment object...
      I hope there was a solution for this problem...
      • P
        PluginStudent
        Instead of using a plane, you could place your sun and moon texture on a Sky object.
        Then you can disable "Affect Background" on the environment object.
        But how is this a programming related question?
        • ManuelM
          this is a programming forum, if you want to ask question related to "how to use cinema4D" there are more appropriate forum out there. (in different languages)
