    Draw Methods doesn't work on GeUserArea
    r21python
    5 Posts 3 Posters 449 Views 1 Watching
    • B Offline
      bentraje
      I'm trying to attach a simple GeUserArea with just a bunch of Draw Methods (i.e. DrawText etc) but it appears blank when I execute the script. There are also no errors on the console.
      You can check the wip code here:
      from c4d import bitmaps, documents, gui, plugins, threading, utils
      class UserArea(c4d.gui.GeUserArea):
          color = c4d.Vector(1, 0, 0)
          def DrawMsg(self, x1, y1, x2, y2, msg):
              self.DrawText("Test Text Area", 10, 10)
              self.DrawSetPen(self.color)
              return super(UserArea, self).Message(msg, result)
      class MyDialog(c4d.gui.GeDialog):
          def CreateLayout(self):
              paramid = 10002
              self.AddUserArea(paramid, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 100, 100)
              self.AttachUserArea(UserArea(), paramid)
          def Command(self, id, msg):
          def CoreMessage(self, id, data):
          dlg = MyDialog()
          dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE)
      Thank you for looking at my problem
      • P Offline
        PluginStudent
        The user area has to be a member variable of the GeDialog class:
        class ExampleDialog(c4d.gui.GeDialog):
            # The GeUserArea need to be stored somewhere, we will need this instance to be attached to the current Layout
            geUserArea = ExampleGeUserArea()
        See geuserarea_basic_r13.py.
        • B Offline
          bentraje
          @PluginStudent
          Thanks for the response.
          The DrawSetPen and DrawRectangle works but for some reason the
          DrawGetTextWidth() doesn't.
          I also used the value from the DrawGetTextWidth() but I still get the same result (i.e. the Text is not being drawn)
          Here is the code so far:
                  self.DrawText("Test Text Area", 67, 67)
                  print self.DrawGetTextWidth("Test Text Area")
                  #self.DrawSetPen(self.color)
              ua = UserArea()
                  paramid = 10002
                  self.AddUserArea(paramid, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 200, 200)
                  self.AttachUserArea(self.ua, paramid)
              dlg = MyDialog()
            I haven't run your script, but you invoke DrawRectangle after DrawText, covering up any text you have drawn previously.
            zipit
            • B Offline
              bentraje
              @zipit
              Thanks for pointing it out. It now works as expected.
