    Cannot write specific values to UVWTag
    Cinema 4D SDK
    r20 r21 c++ python
    • C4DSC
      C4DS
      I am trying to create precise UV coordinates, but am not able to store the wanted UV values.
      Say I create a single polygon object (primitive plane with subdivision 1x1, make editable). And want to map a texture bitmap of 1920x1080.
      I then use following script to modify the plane's UV to fit exactly to the top 72 pixels of my bitmap.
      The bottom UV coordinates should be 72 / 1080 = 0.06666666...
      from c4d import gui
      def readUV(uvwtag):
          for i in xrange(uvwtag.GetDataCount()):
              uvwdict = uvwtag.GetSlow(i)
              uvwA = uvwdict["a"]
              uvwB = uvwdict["b"]
              uvwC = uvwdict["c"]
              uvwD = uvwdict["d"]
              print "read UV", i, ":"
              print " A: %.15f %.15f" % (uvwA.x, uvwA.y)
              print " B: %.15f %.15f" % (uvwB.x, uvwB.y)
              print " C: %.15f %.15f" % (uvwC.x, uvwC.y)
              print " D: %.15f %.15f" % (uvwD.x, uvwD.y)
      # Main function
          # reads the UVs of the object
          if op == None:
              print "No active object!"
          if not op.CheckType(c4d.Opolygon):
              print "Active object is not Opolygon"
          # get the UVW tag of the object
          uvwtag = op.GetTag(c4d.Tuvw)
          if uvwtag == None:
              print "Active object has no UVW tag"
          readUV(uvwtag)
          # write UVs
          uvwA = c4d.Vector(0.0, 0.0, 0.0)
          uvwB = c4d.Vector(1.0, 0.0, 0.0)
          uvwC = c4d.Vector(1.0, 72.0 / 1080.0, 0.0)
          uvwD = c4d.Vector(0.0, 72.0 / 1080.0, 0.0)
          print "write UV"
          uvwtag.SetSlow(0, uvwA, uvwB, uvwC, uvwD)
          readUV(uvwtag)
      # Execute main()
      This is the result I get:
      read UV 0 :
       A: 0.000000000000000 1.000000000000000
       B: 0.000000000000000 0.000000000000000
       C: 1.000000000000000 0.000000000000000
       D: 1.000000000000000 1.000000000000000
      write UV
       A: 0.000000000000000 0.000000000000000
       B: 1.000000000000000 0.000000000000000
       C: 1.000000000000000 0.066666666666667
       D: 0.000000000000000 0.066666666666667
      read UV 0 :
       C: 1.000000000000000 0.066666662693024
       D: 0.000000000000000 0.066666662693024
      The values read after writing are close, but not what they are supposed to be. Why?
      I know the problem with floating point representation.
      But since the wanted value can be hold in a variable and printed out, I would expect this value to be able to be written into the UVWtag ... and read back. But apparently this is not the case.
      I had encountered this issue within a C++ plugin, and tried this simple script just to point out the issue.
      Is this a bug, a limitation, ... something else?
      I know that for most users a UV pixel coordinate of 71.999999 or 72.0 would not make a big difference, but for some users sending this information to a LED processor it apparently is.
      • ferdinandF
        This post is deleted!
        • r_giganteR
          r_gigante
          Hi @C4DS, thanks for reaching out us.
          With regard to your issue, I confirm that, by design, the values stored in UVWTag are rounded to 8 significant digits.
          Best, R
          C4DSC 2 Replies Last reply Reply Quote 0
          • C4DSC
            C4DS @r_gigante
            @r_gigante
            Bummer ... But thanks for confirming!
            • C4DSC
              C4DS @r_gigante
              @r_gigante
              Just a quick question about this. Is the truncation the result of using a Float32 type, or is there another technique used to limit to the 8 significant digits?
              • r_giganteR
                r_gigante
                It's actually due to a lower number of bits used to store the floating value.
