Cannot write specific values to UVWTag
I am trying to create precise UV coordinates, but am not able to store the wanted UV values.Say I create a single polygon object (primitive plane with subdivision 1x1, make editable). And want to map a texture bitmap of 1920x1080.
I then use following script to modify the plane's UV to fit exactly to the top 72 pixels of my bitmap.
The bottom UV coordinates should be 72 / 1080 = 0.06666666...import c4d from c4d import gui def readUV(uvwtag): for i in xrange(uvwtag.GetDataCount()): uvwdict = uvwtag.GetSlow(i) uvwA = uvwdict["a"] uvwB = uvwdict["b"] uvwC = uvwdict["c"] uvwD = uvwdict["d"] print "read UV", i, ":" print " A: %.15f %.15f" % (uvwA.x, uvwA.y) print " B: %.15f %.15f" % (uvwB.x, uvwB.y) print " C: %.15f %.15f" % (uvwC.x, uvwC.y) print " D: %.15f %.15f" % (uvwD.x, uvwD.y) return # Main function def main(): # reads the UVs of the object if op == None: print "No active object!" return if not op.CheckType(c4d.Opolygon): print "Active object is not Opolygon" return # get the UVW tag of the object uvwtag = op.GetTag(c4d.Tuvw) if uvwtag == None: print "Active object has no UVW tag" return readUV(uvwtag) # write UVs uvwA = c4d.Vector(0.0, 0.0, 0.0) uvwB = c4d.Vector(1.0, 0.0, 0.0) uvwC = c4d.Vector(1.0, 72.0 / 1080.0, 0.0) uvwD = c4d.Vector(0.0, 72.0 / 1080.0, 0.0) print "write UV" print " A: %.15f %.15f" % (uvwA.x, uvwA.y) print " B: %.15f %.15f" % (uvwB.x, uvwB.y) print " C: %.15f %.15f" % (uvwC.x, uvwC.y) print " D: %.15f %.15f" % (uvwD.x, uvwD.y) uvwtag.SetSlow(0, uvwA, uvwB, uvwC, uvwD) readUV(uvwtag) # Execute main() if __name__=='__main__': main()This is the result I get:
read UV 0 : A: 0.000000000000000 1.000000000000000 B: 0.000000000000000 0.000000000000000 C: 1.000000000000000 0.000000000000000 D: 1.000000000000000 1.000000000000000 write UV A: 0.000000000000000 0.000000000000000 B: 1.000000000000000 0.000000000000000 C: 1.000000000000000 0.066666666666667 D: 0.000000000000000 0.066666666666667 read UV 0 : A: 0.000000000000000 0.000000000000000 B: 1.000000000000000 0.000000000000000 C: 1.000000000000000 0.066666662693024 D: 0.000000000000000 0.066666662693024The values read after writing are close, but not what they are supposed to be. Why?
I know the problem with floating point representation.
But since the wanted value can be hold in a variable and printed out, I would expect this value to be able to be written into the UVWtag ... and read back. But apparently this is not the case.I had encountered this issue within a C++ plugin, and tried this simple script just to point out the issue.
Is this a bug, a limitation, ... something else?
I know that for most users a UV pixel coordinate of 71.999999 or 72.0 would not make a big difference, but for some users sending this information to a LED processor it apparently is. -
This post is deleted! -
Hi @C4DS, thanks for reaching out us.
With regard to your issue, I confirm that, by design, the values stored in UVWTag are rounded to 8 significant digits.
Best, R
@r_gigante
Bummer ... But thanks for confirming! -
@r_gigante
Just a quick question about this. Is the truncation the result of using a Float32 type, or is there another technique used to limit to the 8 significant digits? -
It's actually due to a lower number of bits used to store the floating value.
