    ParallelFor: TestBreak()
    Cinema 4D SDK
    c++ r20 r21
    • fwilleke80F
      fwilleke80
      I'm successfully using the Parallel stuff from the API.
      What I didn't understand yet is how to check for a user break within a ParallelFor worker lambda. I'm thinking the BreakContext has something to do with it, but I couldn't figure out yet how to do it.
      With the old C4DThreads, we could simply do it like this:
      // Check for user break every 64 iterations
      if (thread && !(x & 63))
      	if (thread->TestBreak())
      		break;
      How does this work with the new Parallel functions?
      Frank
      www.frankwilleke.de
      • ManuelM
        sorry for the late reply.
        you have to use the BreakContext in the template of the parrallelFor.
        And pass your thread to the lamba function as a reference. In the lambda function you call the Break function if needed.
        there are other context you can use
                maxon::Result<void> errReturn;
        	auto worker = [&escThread]
        	(maxon::Int32 y , maxon::ParallelFor::BreakContext& context) -> maxon::Result < void >
        		for (maxon::Int32 loop = 0; loop < 10000; loop++)
        			if (MAXON_UNLIKELY(escThread->TestBreak()))
        				context.Break(maxon::UnexpectedError(MAXON_SOURCE_LOCATION));
        			continue;
        		return maxon::OK;
        	errReturn = maxon::ParallelFor::Dynamic<maxon::ParallelFor::BreakContext>(0, 100000, worker, numThreads, maxon::PARALLELFOR_DEFAULTGRANULARITY );
        	if (errReturn == maxon::OK)
        		ApplicationOutput("we didn't got stoped");
        	else if (errReturn == maxon::FAILED)
        		ApplicationOutput("we've been stopped @", errReturn.GetError());
        Sorry i cant really provide a fully working example but that's the way to do it πŸ™‚
        • fwilleke80F
          fwilleke80
          Super cool, thank you for the example code!
          Greetings,
          Frank
          www.frankwilleke.de
          • fwilleke80F
            fwilleke80
            Oh wait, what's escThread in your example code? Where did that come from?
            www.frankwilleke.de
            • P
              PluginStudent
              I would guess that's the thread returned by GeGetEscTestThread(). See Thread Utility Manual.
              Or it is just the thread that provides the context for your call.
              • fwilleke80F
                fwilleke80
                That makes sense. Thanks again!
                Frank
                www.frankwilleke.de
                • ManuelM
                  as @PluginStudent said i was using GeGetEscTestThread and by the way, it's not really working πŸ˜ƒ
                  But that's the same question with your code.
                  You test the thread that have been provided to you or your own thread. For that you pass that thread as a reference to the lambda function.
