    Force refresh Xpresso
    pythonr21
    13 Posts 3 Posters 3.9k Views 3 Watching
    • SwinnS Offline
      Swinn
      Hi Manuel, thanks for responding. I will send the file via email as it is confidential. I have spent much time reprioritizing, to no avail. Maybe after looking at the file you can help. Thanks.
      • SwinnS Offline
        Swinn
        The file and some screen captures has been sent.
        • SwinnS Offline
          Swinn
          Auto Redraw is set to 1000ms.
            sorry for the late reply, I've dive a bit in your scene.
            A better approche would be to create a 1 unit long spline in your scene and use a python effector to scale those spline to the right length.
            Modifying the cloner's cache is not the best to do things. That's exactly the way to go if you want to have a scene that refresh one frame later (or having to press the mouse button) (even if sometimes, i understand, it can work and is very usefull)
            That said, you can refresh an xpresso with python, you have just to retrieve the GVNodeMaster and use the Execute function. (that will call the Calculate function from c++)
            The problem is that it's seems buggy for the moment. I need to check it a bit further.
            I'll be back with more information πŸ™‚
            • SwinnS Offline
              Swinn
              Thanks for looking into this, Manuel. Much appreciated. I will wait to hear back from you.
                i can confirm that the right command is Execute and i can confirm that currently it's useless and not working. We will update this function as soon as possible.
                so based on this script
                If you want to execute the xpresso again the code could be:
                    # Checks if selected object is valid
                    if op is None:
                        raise ValueError("op is none, please select one object.")
                    # Retrieves the xpresso Tag
                    xpressoTag = op.GetTag(c4d.Texpresso)
                    if xpressoTag is None:
                        raise ValueError("Make sure the selected object get an Xpresso Tag.")
                    # Retrieves the node master
                    gvNodeMaster = xpressoTag.GetNodeMaster()
                    if gvNodeMaster is None:
                        raise RuntimeError("Failed to retrieve the Node Master.")
                    # Make the node master to be executed again.
                    gvNodeMaster.Execute()
                I will update this thread when the code will be fixed. I've moved this thread to c4d section and added some tags.
                But in your case, updating the object in the cache, and executing twice the xpresso would not solve your problem. Because if you change the cache, the viewport have to be updated.
                Manuel.
                • SwinnS Offline
                  Swinn
                  This post is deleted!
                  • SwinnS Offline
                    Swinn
                    How would I implement the workaround with the Python effector?
                      i've answer this question by email, can we consider this thread as solve ?
                      Manuel.
                      • SwinnS Offline
                        Swinn
                        Yes, Thanks. πŸ™‚
