    Force refresh Xpresso
    pythonr21
    13 Posts 3 Posters 3.9k Views 3 Watching
    • Passion3DP Offline
      Passion3D
      Hi
      I'll need that job too. To be able to refresh xpresso without having to provoke it with a mouse click.
        Sounds like a priority issue to me. Would it be possible to share a simple example scene or send it to use using [email protected] if it's confidential ?
        This kind of priority issue are often solved by moving the object in the hierarchy so every object update properly or by changing the priority of the xpresso tag.
        The Calculate menu could help sometimes and the autoredraw
        The "A" key works (or viewport menu, view->redraw)
        Using python to refresh xpresso, will than refresh the python that will refresh the xpresso creating an endless loop.
        • SwinnS Offline
          Swinn
          Hi Manuel, thanks for responding. I will send the file via email as it is confidential. I have spent much time reprioritizing, to no avail. Maybe after looking at the file you can help. Thanks.
          • SwinnS Offline
            Swinn
            The file and some screen captures has been sent.
            • SwinnS Offline
              Swinn
              Auto Redraw is set to 1000ms.
                sorry for the late reply, I've dive a bit in your scene.
                A better approche would be to create a 1 unit long spline in your scene and use a python effector to scale those spline to the right length.
                Modifying the cloner's cache is not the best to do things. That's exactly the way to go if you want to have a scene that refresh one frame later (or having to press the mouse button) (even if sometimes, i understand, it can work and is very usefull)
                That said, you can refresh an xpresso with python, you have just to retrieve the GVNodeMaster and use the Execute function. (that will call the Calculate function from c++)
                The problem is that it's seems buggy for the moment. I need to check it a bit further.
                I'll be back with more information πŸ™‚
                • SwinnS Offline
                  Swinn
                  Thanks for looking into this, Manuel. Much appreciated. I will wait to hear back from you.
                    i can confirm that the right command is Execute and i can confirm that currently it's useless and not working. We will update this function as soon as possible.
                    so based on this script
                    If you want to execute the xpresso again the code could be:
                        # Checks if selected object is valid
                        if op is None:
                            raise ValueError("op is none, please select one object.")
                        # Retrieves the xpresso Tag
                        xpressoTag = op.GetTag(c4d.Texpresso)
                        if xpressoTag is None:
                            raise ValueError("Make sure the selected object get an Xpresso Tag.")
                        # Retrieves the node master
                        gvNodeMaster = xpressoTag.GetNodeMaster()
                        if gvNodeMaster is None:
                            raise RuntimeError("Failed to retrieve the Node Master.")
                        # Make the node master to be executed again.
                        gvNodeMaster.Execute()
                    I will update this thread when the code will be fixed. I've moved this thread to c4d section and added some tags.
                    But in your case, updating the object in the cache, and executing twice the xpresso would not solve your problem. Because if you change the cache, the viewport have to be updated.
                    Manuel.
                    • SwinnS Offline
                      Swinn
                      This post is deleted!
                      • SwinnS Offline
                        Swinn
                        How would I implement the workaround with the Python effector?
                          i've answer this question by email, can we consider this thread as solve ?
                          Manuel.
                          • SwinnS Offline
                            Swinn
                            Yes, Thanks. πŸ™‚
