    Finding duplicate materials - Octane Render
    pythonr19
    17 Posts 7 Posters 4.5k Views 4 Watching
    • A Offline
      AndreAnjos
      Hi @PluginStudent ,
      Thank you very much for your help! 🙂
      I should have mentioned that it needs to work for any render engine. Currently we use Octane and I think the Compare() function may just be related to Cinema native materials (I may be wrong!), as from my previous tests it did not work.
      So I'm trying to go with data comparising, just in case.
      Let me know if you find another solution please!
      Thank you again! 😃
      • CairynC Offline
        Cairyn
        If you have two materials, and both use a certain shader, then these shader are (as you have noticed) still different objects at different memory addresses. Since C4D classes are mutable (other than, say, the Python integer class) Python cannot reuse the object. After all, the user may at any time change a parameter in the shader used by material 1, but not the equivalent shader used by material 2, resulting in 2 different shader instances.
        With all hierarchical structure based on dynamic objects, you need to perform the comparison recursively (deeply), or you will run into the issue that data identity is not necessarily object identity. If you're lucky, your classes contain a deep comparison function already; otherwise, you need to go into the objects-to-compare and continue on that level, all the way down.
        A 1 Reply Last reply Reply Quote 1
        • A Offline
          AndreAnjos @Cairyn
          Hi @Cairyn,
          Thank you very much for your thorough explanation! 😃
          That makes a lot a sense to me and seems to be the way to proceed with this.
          I will give it a go and see where it leads me.
          Have a good one and thanks again!
          • A Offline
            AndreAnjos
            Hi all,
            So I after a bit of tinkering and based on what @Cairyn explained, this is the outcome.
            Please do let me know if I can improve on something.
            My only doubt is regarding the PyCObject types and what to do with it. In the code below I'm just ignoring it as I can't do anything with it anyway in a Python data context (I think!) and it doesn't seem to create any unusal cases when comparing the materials values.
            def get_data(data, lst):
                Get the parameters from the materials container and return a list.
                for i in range(len(data) - 1):
                    index = data.GetIndexId(i)
                    try:
                        if isinstance(data[index], (c4d.BaseShader, c4d.BaseTime)):
                            sub_data = data[index].GetDataInstance()
                            get_data(sub_data, lst)
                            if type(data[index]).__name__ == 'PyCObject':
                                continue
                            lst.append(data[index])
                    except AttributeError:
                        continue
                return lst
            def compare_data(lst_a, lst_b):
                Compare the data between lists a and b. If data is the same, than material is a duplicate.
                zipped = zip(lst_a, lst_b)
                for params in zipped:
                    if params[0] != params[1]:
                        return False
                mat_lst = doc.GetMaterials()
                duplicate_materials = []
                for a, mat_a in enumerate(mat_lst):
                    data_a = get_data(mat_a, [])
                    for b, mat_b in enumerate(mat_lst):
                        if a != b:
                            data_b = get_data(mat_b, [])
                            data_difference = compare_data(data_a, data_b)
                            if data_difference:
                                duplicate_materials.append(mat_b)
                assert not duplicate_materials, "You have {0} materials duplicated! " \
                                                "See list below:\n\n{1}".format(len(duplicate_materials),
        ", ".join(mat.GetName() for mat in duplicate_materials))
            Hope this helps anyone else!
            Cheers! 😃
            • r_giganteR Offline
              r_gigante
              Thanks @AndreAnjos for coming up with the final code.
              Two notes:
              • first reading your initial question: was hard to understand what you meant with regard to "duplicated" materials and how you were defining the equality among twos. Standing on the solution you presented, basically two materials are identical only and only if the values of all their parameters are equal
              • second the get_data function expects two arguments, whilst, in your code, only one is given to both calls in the main.
              Finally, as pointed out by @PluginStudent, BaseMaterial::Compare() actually does exactly what you're trying to achieve, and any material implementing MaterialData can be checked via this method belonging to the BaseMaterial class to which they inherit from (independently from the rendering engine they belong and assuming they following up with the best practice of storing data in BaseContainers)
              The Compare actually does:
              • compares BaseChannels
              • compares BaseContainers
              • compares Ckeys found in CCurves belonging to CTrack.
              Only when these three checks give all positive results, the two materials are considered identical
              Best, R
              • A Offline
                AndreAnjos
                Hi @r_gigante,
                Thank you very much for pointing stuff out! 😃
                Apologies for this! Should have been more specific with my description.
                This has now been updated! Thanks for pointing it out.
                Great! Thank you for your explanation! Did not know if that would be the case since my tests were not coming with the results. So will give it another go!
                Thanks again! 🙂
                • A Offline
                  AndreAnjos
                  Hi @r_gigante
                  I must be really stupid here, but can't have the result you are saying with this function.
                  A simple test of having 2 supposedly duplicate materials and still returns False.
                      result = mat_lst[0].Compare(mat_lst[1])
                      print(result)
                  I must be missing something very obvious and I can't figure it out. 😆
                  Thanks for your help!
                  • A Offline
                    AndreAnjos
                    Also as an update!
                    I've been talking with a couple of artists here and after a few simple tests using the Delete Duplicate Materials in Cinema R19 and R21, does not work as well.
                    Is this a common issue?
                    Thanks!
                      r_gigante
                      Hi @AndreAnjos, looking at the code it seems I've spotted a bug but it's still under investigation. I'll let you know if that's the case and report back.
                      Cheers, R
                      • A Offline
                        AndreAnjos @r_gigante
                        Hi @r_gigante,
                        Any luck with this? It's no rush at all for us, just curious if you have an update 😃
                        Cheers!
                        Andre
                          r_gigante
                          Hi @AndreAnjos, no updates so far.
                          Cheers, R.
                          • A Offline
                            AndreAnjos
                            Hi @r_gigante,
                            Thanks for letting me know!
                            Andre
                            • T Offline
                              Thodos
                              Sooooo, I guess this bug was not adressed still?
                              Compare returns False even if I compare the same material or copied one.
                                Hi @Thodos in which version are you? And would it be possible for you to share a scene?
                                Thanks in advance,
                                • John_DoJ Offline
                                  John_Do
                                  Hi, sorry for bringing back up this topic but the Compare() method still gives weird results in 2024.5.1.
                                  • Comparing a material duplicated with Ctrl-Drag returns sometimes True, sometimes False
                                  • Comparing a material against a copy-pasted version (in the same scene) always returns False
                                  • Comparing two identical materials both copy-pasted together in one-go in another scene always returns False, even if True was returned in the original scene.
                                  Please note that I'm using Corona Materials here but results are the same with the Standard Material.
