    GeUserArea Tool Tips
    5 Posts 4 Posters 610 Views 2 Watching
    • ? Offline
      A Former User
      Is there a tool tip for GeUserArea similar to BitmapButtonCustomGui's BITMAPBUTTON_TOOLTIP? I'd like to use the same tool tip as the rest of the C4D interface.
      Thank you!
      • P Offline
        PluginStudent
        You can react to the message BFM_GETCURSORINFO. See GUI and Interaction Messages Manual
        • M Online
          Hi @blastframe as @PluginStudent pointed it, you should use BFM_GETCURSORINFO.
          Here an example.
          class UA(c4d.gui.GeUserArea):
              def __init__(self):
                  super(UA, self).__init__()
              def DrawMsg(self, x1, y1, x2, y2, msg) :
                  self.OffScreenOn()
                  self.SetClippingRegion(x1, y1, x2, y2)
                  self.DrawSetPen(c4d.Vector(1.0, 0, 0))
              def GetMinSize(self):
                  return 200, 200
              def Message(self, msg, result):
                  if msg.GetId() == c4d.BFM_GETCURSORINFO:
                      result.SetId(c4d.BFM_GETCURSORINFO)
                      result.SetInt32(c4d.RESULT_CURSOR, c4d.MOUSE_POINT_HAND)
                      result.SetString(c4d.RESULT_BUBBLEHELP_TITLE, "Bubblehelp Title")
                      result.SetString(c4d.RESULT_BUBBLEHELP, "This is an example GeUserArea")
                  return c4d.gui.GeUserArea.Message(self, msg, result)
          class ExampleDialog(c4d.gui.GeDialog):
              ID_UA = 10001
              def CreateLayout(self):
                  self.SetTitle("UserArea Example")
                  self.ua = UA()
                  self.AddUserArea(self.ID_UA, c4d.BFH_LEFT | c4d.BFV_TOP)
                  self.AttachUserArea(self.ua, self.ID_UA)
              global dlg
              dlg = ExampleDialog()
              dlg.Open(c4d.DLG_TYPE_ASYNC, xpos=-2, ypos=-2, defaultw=400, defaulth=400)
          • ? Offline
            A Former User
            @m_adam & @PluginStudent Thank you both! This was exactly what I needed. This forum is so so helpful.
            • J Offline
              JohnSmith
              This post is deleted!
