    How to use STRINGTABLE with a Python Command Plugin
    sdkpython
    7 Posts 3 Posters 999 Views 2 Watching
    • ? Offline
      A Former User
      I'm trying to add multi-language support in my plugin.
      I currently have the strings hardcoded in the GeDialog's CreateLayout method like this:
      self.AddStaticText(self.HELP_ID, c4d.BFV_BOTTOM | c4d.BFV_SCALE | c4d.BFH_LEFT, 0, 0, "Help")
      All of the strings are labels for UI menu commands and gadgets. I understand that the best practice is to put the UI strings into folders within a 'res' folder like so:
      res
      └ strings_en-US
          └ c4d_strings.str
      └ strings_fr-FR
          └ c4d_strings.str
      My issue is I don't know how to use the STRINGTABLE in the .str with my Python CommandPlugin. Here's an example of the c4d_strings.str content:
      c4d_strings.str (strings_en-US)
      STRINGTABLE
      	IDS_TEST "Test Plugin";
      	TITLEVIEW_ID "Test - View";
      	HELP_ID "Help";}
      c4d_strings.str (strings_fr-FR)
      STRINGTABLE
      	TITLEVIEW_ID "Test - Vue";
      	HELP_ID "Aide";
      Please forgive all of these questions:
      • What is the best practice for loading these STRINGTABLES and using them in the UI? I couldn't find an example using a CommandPlugin in the official Cinema 4D Python examples though I did see that the py-ies_meta_r12.py SceneSaverPlugin example uses a method called c4d.plugins.GeLoadString.
      • If GeLoadString is the way to go, would I set up my IDs in my GeDialog class and reference the corresponding ID in the STRINGTABLE with this method?
      • Would Cinema 4D then grab the correct string based on the user's language if my folder structure is set up appropriately?
      • Is there a similar method for automatically handling the localized date and time format?
      • As mine is not an Object plugin, I won't need a description folder, is that correct?
      • What should I do with the c4d_symbols.h file?
      Thank you so much!
      • P Offline
        PluginStudent
        GeLoadString() is the way to go. You actually find plenty of examples of GeLoadString() being used in the C++ code base (e.g. asynctest.cpp) and this doc: String Manual (Classic).
          Hi, @blastframe as @PluginStudent pointed you should use GeLoadString.
          To make GeLoadString working, you should use as you already did, the .str file but also the c4d_symbols.h so this way Cinema 4D can link the ID you provided in the str file to an actual int value.
          res
          └ c4d_symbols.h
          └ strings_en-US
              └ c4d_strings.str
          └ strings_fr-FR
              └ c4d_strings.str
          c4d_symbols.h
          enum
          	IDS_TEST = 10000,
          	TITLEVIEW_ID,  // This will have id 10000 + 1
          	HELP_ID, // This will have id 10000 + 2
          	// End of symbol definition
          	_DUMMY_ELEMENT_
          However, due to the nature of Python, the int value defined in the c4d_symbols.h is not ported to python so you have to redefine it in your python code as well.
          And here is how to use it in your pyp file. This needs the __res__ to be defined, this is done automatically, for more information see Issue with registering a ToolData.
          print c4d.plugins.GeLoadString(10000) # Will print the str value of IDS_TEST
          Finally, note that these Symbol IDs must be unique through all Cinema 4D so instead of IDS_TEST is would recommend you rename it with BLASTFRAME_IDS_TEST .
            Since this topic is older than a week I marked is as closed, but feel free to reopen it if you have further questions.
            Maxime
            • ? Offline
              A Former User @m_adam
              @m_adam Hi Maxime! I wanted to make sure I had all of my strings before implementing this. I am very grateful for your help. I will come back to this thread soon! Thank you!
              • ? Offline
                A Former User
                @m_adam I got it working with your help! Thank you so much. I have a couple more questions (more for advice really):
                1. Are there tools for creating C++ STRINGTABLES like the ones Cinema 4D uses?
                2. I am currently using a spreadsheet for editing my stringtables. Are there any tools I can use to export the non-ascii characters as unicode that Cinema 4D will understand?
                  Thank you!
                • P Offline
                  PluginStudent
                  I don't think there are any official "tools". But the docs describe how to handle unicode (Dialog Layout😞
                  The encoding is 7-bit ASCII with other characters encoded as \uHHHH. For example 'Natürlich' is written 'Nat\u00fcrlich'. Byte-order marks are not used.
