    Best plugin type for background (thread) processing?
    r20python
    16 Posts 6 Posters 4.4k Views 2 Watching
    • P Offline
      pim
      I want to make thumbnails when my plugin starts.
      I also want to do this in parallel with running the plugin.
      So, I guess I must run the plugin in a thread, because when I use for example a command plugin, cinema 4d waits (of course) for the completion of the command plugin.
      What is the best plugin type to run a process in the background?
      I do not want to execute something when cinema 4d starts up, just when my plugin starts.
      So, I think I cannot use python_init.py
      I tried the c4d.threading.C4DThread example in the manual.
      The thumbnails are created, but meanwhile cinema 4d does not react.
      class CTCommand(c4d.plugins.CommandData):
          def Execute(self, doc):
              thread = UserThread()
              thread.Start()
              thread.Wait(False)     # I tried True and False
              return True   # End plugin
      class UserThread(c4d.threading.C4DThread):
          def ReadFolders(self, path):              #get all folders
              dirpath = os.walk(path)
              for f in dirpath:
                  self.CreateThumbnails(f[0])
          def CreateThumbnails(self, pathIn):      # create thumbnails per folder
              # use ScaleIt() to create a thumbnail and os functions to  store the thumbnail
          def Main(self):
              start_time = time.time()
              self.ReadFolders(DEFAULTFOLDER)
              print "Create Thumbnails took: ", time.time() - start_time, " to run"
          c4d.plugins.RegisterCommandPlugin(PLUGIN_ID_TGSTEXTUREMANAGER_CREATE_THUMBNAILS, PLUGINSTRING, 0, bmp, PLUGINSTRING, CTCommand())
      -Pim
      • P Offline
        PluginStudent
        As the name says, the Wait() function waits for the thread to finish. Thus, it blocks the execution.
        What you need is a thread that exist independently from your UI (a CommandData plugin is a UI plugin). You can start that thread in a CommandData plugin, but this plugin must not own the thread.
        When the thread has finished, it can send a custom core message. You can catch that core message in a MessageData plugin. Then you can read the thread's data safely from the main thread.
        The C4DThread Manual gives some good overviews.
        • P Offline
          pim
          Thanks.
          I change the Wait() state to False, but that did not help.
          I guess, like you say, I should not do it in a command plugin.
          I will messagadata plugin a try.
          • P Offline
            pim
            I tried a messagedata plugin and I noticed that the messagedata is not running in a thread.
            When messagedata is running, cinema 4d is not reacting.
            I will now add the threading class UserThread(c4d.threading.C4DThread) as in above code.
            • P Offline
              pim
              Adding threading did not help.
              Cinema 4d is still not reacting during the time the messagedata runs.
              Even changing to Wait(False) did not help.
              class MYMESSAGEDATA(c4d.plugins.MessageData):
                  def CoreMessage(self, id, bc):
                      if (id ==  PLUGIN_ID_MESSAGAPLUGIN):
                          print "Message received."
                          thread.Start()
              • P Offline
                PluginStudent
                Please read my post above and the C4DThread Manual carefully.
                You can start the thread in a CommandData plugin. But this plugin must not own the thread instance. The thread instance should be stored in the global scope.
                In the MessageData plugin, you should react to a core message sent from the thread. Nothing else; no creation or waiting.
                  heilei
                  The examples Maxon has in GitHub include "Py-TextureBaker", which seems to use threads. I'm currently going through that code (and trying to understand it...), because I'm facing the exact same challenge as OP: how to start something in a thread, and make that thread send messages to other plugins.
                  P 1 Reply Last reply Reply Quote 1
                  • lasselauchL Offline
                    lasselauch
                    Yeah, I'm looking into this as well...
                    Ideally I want to run different function with a decorator: @execute_on_own_thread which would be very convenient.
                    • P Offline
                      pim @heilei
                      @heilei said in Best plugin type for background (thread) processing?:
                      Py-TextureBaker
                      That is a very good working example.
                      I rebuild my plugin using py-texturebaker and now it is working!
                      After some studying, I think @PluginStudent is fully correct when referring to the global scope.
                      @PluginStudent said in Best plugin type for background (thread) processing?:
                      I guess it is working because in the dialog the thread class is initiated.
                      textureBakerThread = None
                      and further in the code it is referenced with self.textureBakerThread.
                      I was using
                              thread.Start()
                      Everybody thanks for all the help.
                        Hi @pim this is very different, texture baker will execute a specific command in a thread (So you execute it only at a given time) while in your case if I understood correctly you want something that runs in the background.
                        So here a general example that runs a thread in background and updates a GeDialog according to some random event. This is a very generic solution, in your case, the proper way would be to handle the thread creation, not within the C4DPL_PROGRAM_STARTED but in the init method of the GeDialog and end the thread in the AskClose method of the GeDialog. But since I wanted to demonstrate something very generic I used C4DPL_PROGRAM_STARTED and C4DPL_ENDACTIVITY so the thread will exist as long as Cinema 4D start and exit.
                        import time, random, weakref
                        PLUGIN_ID_COMMAND_DATA = 1000000
                        # Store the global thread
                        GlobalThread = None
                        # Store a weakref of the GeDialog
                        GlobalDialog = None
                        # Background Thread is driven from Thread class to make it run in the background.
                        class BGThread(c4d.threading.C4DThread):
                            end = False
                            # Called by TestBreak to adds a custom condition to leave
                            def TestDBreak(self):
                                return bool(self.end)
                            def GenerateBitmap(self):
                                "Generate a basebitmap with a random color"
                                clipMap = c4d.bitmaps.GeClipMap()
                                clipMap.Init(100, 100)
                                clipMap.BeginDraw()
                                clipMap.SetColor(int(random.random() * 255 ), int(random.random() * 255 ), int(random.random() * 255 ))
                                clipMap.FillRect(0, 0, 100, 100)
                                clipMap.EndDraw()
                                # It's important to return a clone since the original basebtimap is owned by the GeClipMap.
                                # So if the GeClipMap is destructed (and it will be the case after the return statement), the BaseBtimap will also be destructed.
                                return clipMap.GetBitmap().GetClone()
                            # Starts the thread to start listing to the port.
                            def Main(self):
                                while True:
                                    # Checks if the thread needs to be closed e.g. a call of GlobalThread.End()
                                    if self.TestBreak():
                                    # Sleeps to not support
                                    time.sleep(0.1)
                                    # Retrieves the global variable and either check if there is no Dialog, or if the weakref is None
                                    global GlobalDialog
                                    if GlobalDialog is None or GlobalDialog() is None:
                                        continue
                                    dlg = GlobalDialog()
                                    if not dlg.IsOpen():
                                        continue
                                    # Simulates a random update
                                    randomEvent = bool(random.randint(1, 100) <= 10)
                                    if randomEvent:
                                        bmp = self.GenerateBitmap()
                                        # I use a try/Except block, because we are in a threaded environment, so even if I check previously if the dialog exists
                                        # it's not 100% thread-safe, since the user may have closed the UI between the previous stuff.
                                        try:
                                            GlobalDialog().UpdatePicture(bmp)
                                        except:
                                            pass
                        # The Dialog class
                        class DialogWithBitmap(c4d.gui.GeDialog):
                            def __init__(self):
                                global GlobalDialog
                                GlobalDialog = weakref.ref(self)
                                self.bmp = None
                                self.customUiBmp = None
                            # Define our Layout
                            def CreateLayout(self):
                                w = c4d.gui.SizePix(100)
                                h = c4d.gui.SizePix(100)
                                bcBitmapButton = c4d.BaseContainer()
                                bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True
                                bcBitmapButton[c4d.BITMAPBUTTON_BORDER] = c4d.BORDER_IN
                                self.customUiBmp = self.AddCustomGui(1000, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton)
                            def UpdatePicture(self, bmp):
                                # Called from the thread
                                self.bmp = bmp
                                # Sanity checks if the dialog is opened or eitehr the customUI is not defined
                                if self.IsOpen() and self.customUiBmp is not None:
                                    self.customUiBmp.SetImage(self.bmp)
                                    if c4d.threading.GeIsMainThread():
                                        self.customUiBmp.Redraw()
                                        # If we are not on the main thread, redraw is not allowed, so add a special event with a unique ID
                                        c4d.SpecialEventAdd(PLUGIN_ID_COMMAND_DATA, 0, 0)
                            def CoreMessage(self, id, msg):
                                if id == PLUGIN_ID_COMMAND_DATA:
                        # The CommandData plugin which host the Dialog object alive
                        class CommandDataDlg(c4d.plugins.CommandData):
                            dialog = None
                                if self.dialog is None:
                                    self.dialog = DialogWithBitmap()
                                return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID_COMMAND_DATA, xpos=-1, ypos=-1, defaultw=200, defaulth=150)
                            def RestoreLayout(self, sec_ref):
                                return self.dialog.Restore(pluginid=PLUGIN_ID_COMMAND_DATA, secret=sec_ref)
                        # Handle our thread here
                        def PluginMessage(id, data):
                            global GlobalThread
                            # At the start of Cinema 4D We lunch our thread
                            if id == c4d.C4DPL_PROGRAM_STARTED:
                                GlobalThread = BGThread()
                                GlobalThread.Start()
                            # At the end we clean our Thread + BC used to pass data
                            elif id == c4d.C4DPL_ENDACTIVITY:
                                if GlobalThread:
                                    GlobalThread.end = True
                                    GlobalThread.End()
                        # Main function
                            c4d.plugins.RegisterCommandPlugin(PLUGIN_ID_COMMAND_DATA, "GeDialog Example", 0, None, "GeDialog Example", CommandDataDlg())
                        # Execute main()
                        However your suggestion @lasselauch is very nice, so I will take care of it when I will come back from vacation.
                        Note that due to the nature of Python, there is no real Multi-threading so don't expect performance boost, ( in reality you will only have a decreasing of performance, its better to use async stuff). The scope of thread in python is like the one in Example where you have something multiple things to do at the same time without the need to block everything, like GUI.
                        I'm going to leave on vacation and should come back Monday, I will try to clean up the previous code and make it as an example and also an example about your decorator idea @lasselauch.
                          lasselauch
                          Nice, thanks for the example @m_adam ! Have a great vacation and looking forward to the decorator example!
                          BTW – This example might come in handy if we want to integrate animated images, kinda a like a gif but based on an image-sequence... hmmm, I have to think about this! 🙂
                          Thanks & Cheers,
                          Lasse
                          • P Offline
                            pim @m_adam
                            @m_adam said in Best plugin type for background (thread) processing?:
                            Thanks for the example.
                            Could you also clarify a bit more for me, how to improve performance (async stuff)?
                              mp5gosu
                              @m_adam I have a question about the following portion of your code:
                                      if GlobalThread:
                                          GlobalThread.end = True # 1
                                          GlobalThread.End() # 2
                              Aren't 1 & 2 not redundant in this case?
                              TestDBreak() tests for self.end which is satisfied in the above example and therefore TestBreak() also returns True, so the thread exists.
                              Why the additional call to End()?
                              What am I missing here?
                              Robert
                                m_adam @pim
                                Hi @mp5gosu
                                Correct, it was just to demonstrate a possible usage.
                                The next code would not have the same sense since .end will be checked only the next TestDBreak is called, while End(False) will force the thread to be ended right now.
                                GlobalThread.End(False) # 2
                                @lasselauch Here an implementation example of an execute_on_own_thread decorator.
                                import functools
                                import time
                                import random
                                global globalThreadStorage
                                globalThreadStorage = []
                                    def __init__(self, func, *args, **kwargs):
                                        self.func = func
                                        self.args = args
                                        self.kwargs = kwargs
                                    def Main(self):
                                        self.func(*self.args, **self.kwargs)
                                class CleanupThread(c4d.threading.C4DThread):
                                    def Main(self):
                                        while True:
                                            time.sleep(3)
                                            c4d.threading.GeThreadLock()
                                            # If there is only 1 thread in the global list and its self, leave since there is nothing else to clean.
                                            if len(globalThreadStorage) == 1 and globalThreadStorage[0] == self:
                                                c4d.threading.GeThreadUnlock()
                                            # Removes all threads that are finished, so the garbage collector can delete them.
                                            for thread in reversed(globalThreadStorage):
                                                if not thread.IsRunning():
                                                    thread.End(False)
                                                    globalThreadStorage.remove(thread)
                                # Creates the decorator with argument
                                def execute_on_own_thread(wait=False):
                                    # The decorated function
                                    def decorated(func):
                                        @functools.wraps(func)
                                        # The wrapper
                                        def wrapper(*args, **kwargs):
                                            thread = BGThread(func, *args, **kwargs)
                                            thread.Start()
                                            # If we don't wait for the thread to be finalized, that means the created thread should live even after
                                            # this function is executed. So we store a thread reference in a global list and we also initialize
                                            # the cleanup thread, which as its name suggest will have the role to delete other thread.
                                            if not wait:
                                                # Adds the thread that encapsulates the function to the global list
                                                globalThreadStorage.append(thread)
                                                # Checks if there is already a cleanup thread, and if not create it
                                                cleanupThreadPresent = False
                                                for thread in globalThreadStorage:
                                                    if isinstance(thread, CleanupThread):
                                                        cleanupThreadPresent = True
                                                        break
                                                if not cleanupThreadPresent:
                                                    cleanupThread = CleanupThread()
                                                    cleanupThread.Start()
                                                    globalThreadStorage.append(cleanupThread)
                                            if wait:
                                                thread.End(wait)
                                                del thread
                                        return wrapper
                                    return decorated
                                @execute_on_own_thread(False)
                                def randomAction(a):
                                    rTime = random.random() * 5
                                    time.sleep(rTime)
                                    print(a, rTime)
                                    for x in xrange(10):
                                        randomAction(x)
                                    print("main done")
                                # Execute main()
                                @pim Here a safer and appropriate version for a GeDialog background thread, this does not rely on a global variable but only live as long as the dialog object lives while my previous example was something genric.
                                    def __init__(self, dlg):
                                        self.dlg = weakref.ref(dlg)
                                        # Generate a basebitmap with a random color"
                                        clipMap.BeginDraw()
                                        clipMap.SetColor(int(random.random() * 255), int(random.random() * 255), int(random.random() * 255))
                                        clipMap.EndDraw()
                                    def Main(self):
                                        while True:
                                            # Creates a global try/except block since at any time the dlg can be destructed.
                                            try:
                                                # Sleeps to not bother too much the CPU
                                                time.sleep(0.1)
                                                if not self.dlg().IsOpen():
                                                    continue
                                                if randomEvent:
                                                    self.dlg().UpdatePicture(bmp)
                                            # Catch the case self.dlg() return None, because the dlg object is destructed.
                                            # This should not happen because in the dialog.__del__ method, this thread is ended.
                                            # This also why a weakref is used, cause if the thread store directly a ref to the GeDialog,
                                            # Due to Python refcounting, the Dialog will never be deleted, so __end__ will never be called.
                                            except AttributeError:
                                # The Dialog class
                                    def __init__(self):
                                        self.thread = BGThread(self)
                                        self.thread.Start()
                                        self.bmp = None
                                    def __del__(self):
                                        self.thread.End()
                                    # Define our Layout
                                        self.customUiBmp = self.AddCustomGui(1000, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT | c4d.BFV_TOP, w, h,
        bcBitmapButton)
                                        self.bmp = bmp
                                    dialog = None
                                # Main function
        CommandDataDlg())
                                # Execute main()
                                Regarding async, I can only forward you to Async IO in Python: A Complete Walkthrough. The main idea is Python does not support MultiThreading, this is the nature of the GIL so only one instruction can be executed in the Python VM machine at a given time. So as an example I write to a file a very very long string of few Gb, The python call is pretty short, what takes the most time is the write into the file (hardware limitation) so instead to wait until the file is written with async stuff you tell, to the python VM it can execute some stuff during this lost time of waiting for hardware (this is a very rough explanation). However, note this is not well supported in Python2.7 but this is in Python3.
                                  lasselauch
                                  Whoooooooooooop, whoooooooooooop!
                                  Thank you so much, @m_adam !!!
                                    Since this topic is older than a week I marked is as closed, but feel free to reopen it if you have further questions.
                                    Maxime
                                    • B bentraje referenced this topic on
