    Why ToolData Plugin Not Keeping the Input Data Values to the GUI Widgets SubDialog?
    pythonr21r19
    4 Posts 2 Posters 1.1k Views 2 Watching
    • A Offline
      Ashton_FCS_PluginDev
      Cinema 4D Version: R19/R21;
      Platform: Windows ;
      Language(s) : Python ;
      Hello Everyone!
      This my first time making a tool data plugin. Now the problem is in R21 I drag the object into the link box and it don't stay and when I change the tool data or the settings dont stay , and i did this with other c4d gui widgets , eg: combobox, it just reset to the default value you set in the GeDialog.InitValues(). Now in R19 I drag the object into the link box and it stay but when I change the tool data or the settings dont stay.
      You can see the short streamable videos below on what is happen inside C4D and take look at the code also. I hope there a easy fix for this problem and not a bug. lol
      Inside R21: Video
      Inside R19: Video
      Code:
      from c4d import plugins, gui, bitmaps, documents, storage, utils
      import os
      import sys
      PLUGIN_ID = 1054512
      def GetDataFromLinkBox(ui_ins, uiLinkID):
          DATA = ui_ins.FindCustomGui(uiLinkID, c4d.CUSTOMGUI_LINKBOX).GetLink()
          objDATA = DATA
          objName = DATA.GetName()
          objGUID = DATA.GetGUID()
          return objDATA, objName, objGUID
      class DemoDialog(gui.SubDialog):
          UIDATA_PARAMETERS = {}
          LinkBC = c4d.BaseContainer()
          IDUI_CUSTOMGRP_LINK1 = 1003
          def __init__(self, arg):
              # Checks if the argument passed is a dictionary
              if not isinstance(arg, dict):
                  raise TypeError("arg is not a dict.")
              self.UIDATA_PARAMETERS = arg
          def CreateLayout(self):
              ui = self
              ui.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "")
              ui.AddStaticText(0, c4d.BFH_RIGHT, 0, 12, "Object:", c4d.BORDER_WITH_TITLE_BOLD)
              ui.AddCustomGui(ui.IDUI_CUSTOMGRP_LINK1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_MASK, 240, 12, ui.LinkBC)
              ui.GroupEnd()
          def Command(self, id, msg):
              if id == self.IDUI_CUSTOMGRP_LINK1:
                 obj, objName, objID = GetDataFromLinkBox(ui_ins=self, uiLinkID=self.IDUI_CUSTOMGRP_LINK1)
                 self.UIDATA_PARAMETERS['grouplink'] = obj
                 self.UIDATA_PARAMETERS['grouplinkGUID'] = objID
                 print("Linked Object:{0} | ID:{1} | GUI-ID:{2}").format( objName, objID, id )
      class ToolDemo(plugins.ToolData):
          def __init__(self):
              self.UI_DATA = { 'grouplink':None, 'grouplinkGUID':None }
          def GetState(self, doc):
              if doc.GetMode()==c4d.Mpaint:
                  return 0
              return c4d.CMD_ENABLED
          def InitDefaultSettings(self, doc, data):
              pass
              # expects None as return value
          def InitTool(self, doc, data, bt):
          def KeyboardInput(self, doc, data, bd, win, msg):
          def MouseInput(self, doc, data, bd, win, msg):
          def GetCursorInfo(self, doc, data, bd, x, y, bc):
          def AllocSubDialog(self, bc):
              return DemoDialog(getattr(self, "UI_DATA", self.UI_DATA))
          bmp = bitmaps.BaseBitmap()
          fn = os.path.join(dir, "res", "tool_icon.tif")
          bmp.InitWith(fn)
          plugins.RegisterToolPlugin(id=PLUGIN_ID,
                                      str="MyPyToolDemo",
                                      info=0,
                                      icon=bmp,
                                      help="Tool",
                                      dat=ToolDemo())
      And I am just wondering is c4d.plugins.SculptBrushToolData is better system than c4d.plugins.ToolData. Cause it look like description .res.. UI is for the tool plugin is more easy, like Node Data, Object Data Tags etc....
      Any help would be very much appreciated.
      cheers, Ashton
        you have to store a link to your gadget and add an InitValues function to your dialog like so
        in the create layout:
        self.link = ui.AddCustomGui(ui.IDUI_CUSTOMGRP_LINK1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_MASK, 240, 12, ui.LinkBC)
        and add that function
           def InitValues(self):
                self.link.SetLink(self.UIDATA_PARAMETERS['grouplink'])
        • A Offline
          Ashton_FCS_PluginDev @Manuel
          @m_magalhaes Thank you! and it makes sense.๐Ÿ‘ Heres a update of the code and Demo Video. And hope it helps anyone who might need this or was wondering how a simple Tool Data GUI works.
          You see I just add the AddComboBox, AddEditText for testing also. ๐Ÿ˜Š ๐Ÿ‘
          Code in .pyp file:
          #  // Imports for Cinema 4D //
          import os
          import sys
          PLUGIN_ID = 1054512
              objDATA = DATA
          def SetDataFromLinkBox(ui_ins, uiLinkID, Data):
              LinkWidget = ui_ins.FindCustomGui(uiLinkID, c4d.CUSTOMGUI_LINKBOX)
              LinkWidget.SetLink(Data)
              # Main Properties
              IDUI_GRG_OBJ_GUID = 1004
              MODE_MENU = 1005
              MODE_MENU_LIST = {
                                  "Mode 1":{'id':1, 'icon':"&i12298&"}, # (12298) # Model Icon Id (Eg:"&i12298&Model")
                                  "Mode 2":{'id':2, 'icon':"&i12139&"}, # (12139) # Points Icon Id
                                  "Mode 3":{'id':3, 'icon':"&i12187&"}  # (12187) # Polygons Icon Id
                  """ Window GUI elements layout that display to the User. """
                  ui = self
                  ui.GroupBegin(0, c4d.BFH_MASK, 2, 2, "", c4d.BFV_GRIDGROUP_EQUALCOLS)
                  ui.AddStaticText(0, c4d.BFH_RIGHT, 0, 12, "Object GUID:", c4d.BORDER_WITH_TITLE_BOLD)
                  ui.AddEditText(ui.IDUI_GRG_OBJ_GUID, c4d.BFH_MASK, 240, 12)
                  ui.AddStaticText(0, c4d.BFH_RIGHT, 0, 12, "Modes:", c4d.BORDER_WITH_TITLE_BOLD)
                  ui.AddComboBox(ui.MODE_MENU, c4d.BFH_SCALEFIT, 100, 15, False)
                  for eachMode in sorted(ui.MODE_MENU_LIST):
                      itemMode = ui.MODE_MENU_LIST.get(str(eachMode))
                      ui.AddChild(ui.MODE_MENU, itemMode['id'],  itemMode['icon']+str(eachMode))
                  ui.GroupEnd()
                  """ Called when the dialog is initialized by the GUI / GUI's startup values basically. """
                  SetDataFromLinkBox(ui_ins=self, uiLinkID=self.IDUI_CUSTOMGRP_LINK1, Data=self.UIDATA_PARAMETERS['grouplink'])
                  self.SetString(self.IDUI_GRG_OBJ_GUID, self.UIDATA_PARAMETERS['grouplinkGUID'])
                  self.SetLong(self.MODE_MENU, self.UIDATA_PARAMETERS['modeSelect'])
                  """ Excuting Commands for UI Widget Elements Functions. """
                      self.SetString(self.IDUI_GRG_OBJ_GUID, str(objID))
                  if id == self.MODE_MENU:
                      for i in self.MODE_MENU_LIST:
                          getModeID = self.MODE_MENU_LIST.get(str(i))
                          if self.GetLong(self.MODE_MENU) == getModeID["id"]:
                              self.UIDATA_PARAMETERS['modeSelect']=getModeID["id"]
          class PyToolDemo(plugins.ToolData):
              def __init__(self):
                                   'grouplinkGUID':None,
                                   'modeSelect':2 }
                      return 0
                  pass
              bmp.InitWith(fn)
                                          str="MyPyToolDemo",
                                          info=0,
                                          icon=bmp,
                                          help="Your Data Staying ToolData UI",
                                          dat=PyToolDemo())
            thanks a lot for sharing your code ๐Ÿ™‚
            Don't forget to change the state of this thread to solved. (if it is)
