    Adding a icon to a treeview field.
    r20r21python
    9 Posts 3 Posters 2.4k Views 2 Watching
    • P Offline
      pim
      Is it possible to add a icon (thumbnail) to a treeview field?
      At this moment the Treeview field is just a (filename) string.
      For example:
        mp5gosu
        Yes, you can basically draw everything you want wih DrawCell()
        The DrawInfos frame is actually a UserArea, so you draw Bitmaps inside this like you do in normal UAs.
          I confirm that DrawCell is the way to go.
          • P Offline
            pim
            I thought that DrawCell is only for LV_USER fields and not for LV_TREE fields.
            See comment in example
                    Draw into a Cell, only called for column of type LV_USER
            I like to do something similar to the content browser.
              Hi @pim sorry for the delay,
              I will take as base the code provided in No multiple selection in Treeview not working?.
              My comment is actually a bit wrong since DrawCell is called for all of the following types LV_USER, LV_USERTREE, LV_CHECKBOXUSER (but I included only LV_USER on my comment because in my example I did use only LV_USER.
              So in the InitValues instead of layout.SetInt32(ID_NAME, c4d.LV_TREE) I used layout.SetInt32(ID_NAME, c4d.LV_USERTREE).
              And here the DrawCell Method.
                  def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor):
                      if col == ID_NAME:
                          geUserArea = drawinfo["frame"]
                          ICON_SIZE = drawinfo["height"]
                          TEXT_SPACER = 6
                          bgColor = c4d.COLOR_SB_TEXTHG1 if drawinfo["line"] % 2 else c4d.COLOR_SB_TEXTHG2
                          # Draw icon bmp, in our case a cube bitmap
                          cube = c4d.BaseObject(c4d.Ocube)
                          cubeIcon = cube.GetIconEx()
                          bmp = cubeIcon.GetGuiScalePart()
                          geUserArea.DrawSetPen(bgColor)
                          geUserArea.DrawBitmap(bmp, drawinfo["xpos"], drawinfo["ypos"], ICON_SIZE, ICON_SIZE, 0, 0, bmp.GetBw(), bmp.GetBh(), c4d.BMP_ALLOWALPHA)
                          # Draw name
                          name = str(obj)
                          fontHeight = geUserArea.DrawGetFontHeight()
                          fontWidth = geUserArea.DrawGetTextWidth(name)
                          x = drawinfo["xpos"] + ICON_SIZE + TEXT_SPACER
                          y = drawinfo["ypos"] + (ICON_SIZE - fontHeight) / 2
                          txtColor = c4d.COLOR_SB_TEXT_ACTIVE1 if obj.IsSelected else c4d.COLOR_SB_TEXT
                          geUserArea.DrawSetTextCol(txtColor, bgColor)
                          geUserArea.DrawText(name, x, y)
                      elif col == ID_OTHER:
                          name = obj.otherData
                          y = drawinfo["ypos"] + (drawinfo["height"] - fontHeight) / 2
                          drawinfo["frame"].DrawText(name, x, y)
              • P Offline
                pim
                Great, thank you.
                -Pim
                • P Offline
                  pim
                  Your example works great.
                  Now in my plugin I do not want a Checkbox or Other. Just the name.
                  When I change your example to below, nothing is shown, but I can see that Drawcell() is called.
                      def InitValues(self):
                          # Initialize the column layout for the TreeView.
                          layout = c4d.BaseContainer()
                          #layout.SetLong(ID_CHECKBOX, c4d.LV_CHECKBOX)
                          #layout.SetLong(ID_NAME, c4d.LV_TREE)
                          #layout.SetLong(ID_OTHER, c4d.LV_USER)
                          self._treegui.SetLayout(1, layout)
                          # Set the header titles.
                          self._treegui.SetHeaderText(ID_CHECKBOX, "Check")
                          self._treegui.SetHeaderText(ID_NAME, "Name")
                          self._treegui.SetHeaderText(ID_OTHER, "Other")
                          self._treegui.Refresh()
                          # Set TreeViewFunctions instance used by our CUSTOMGUI_TREEVIEW
                          self._treegui.SetRoot(self._treegui, self._listView, None)
                  Here before removing the checkbox and other.
                  Here after removing checkbox and name.
                  I tested it on R20.
                  Here the whole script.
                  import weakref
                  # Be sure to use a unique ID obtained from [URL-REMOVED]
                  PLUGIN_ID = 1000010 # TEST ID ONLY
                  # TreeView Column IDs.
                  ID_CHECKBOX = 1
                  ID_NAME = 2
                  ID_OTHER = 3
                  def TextureObjectIterator(lst):
                      for parentTex in lst:
                          yield parentTex
                          for childTex in TextureObjectIterator(parentTex.GetChildren()):
                              yield childTex
                  class TextureObject(object):
                      Class which represent a texture, aka an Item in our list
                      texturePath = "TexPath"
                      otherData = "OtherData"
                      _selected = False
                      _open = True
                      def __init__(self, texturePath):
                          self.texturePath = texturePath
                          self.otherData += texturePath
                          self.children = []
                          self._parent = None
                      @property
                      def IsSelected(self):
                          return self._selected
                      def Select(self):
                          self._selected = True
                      def Deselect(self):
                          self._selected = False
                      @property
                      def IsOpened(self):
                          return self._open
                      def Open(self):
                          self._open = True
                      def Close(self):
                          self._open = False
                      def AddChild(self, obj):
                          obj._parent = weakref.ref(self)
                          self.children.append(obj)
                      def GetChildren(self):
                          return self.children
                      def GetParent(self):
                          if self._parent:
                              return self._parent()
                          return None
                      def __repr__(self):
                          return str(self)
                      def __str__(self):
                          return self.texturePath
                  class ListView(c4d.gui.TreeViewFunctions):
                      def __init__(self):
                          self.listOfTexture = list() # Store all objects we need to display in this list
                          # Add some defaults values
                          t1 = TextureObject("T1")
                          t2 = TextureObject("T2")
                          t3 = TextureObject("T3")
                          t4 = TextureObject("T4")
                          self.listOfTexture.extend([t1, t2, t3, t4])
                      def IsResizeColAllowed(self, root, userdata, lColID):
                      def IsTristate(self, root, userdata):
                          return False
                      def GetColumnWidth(self, root, userdata, obj, col, area):
                          return 80  # All have the same initial width
                      def IsMoveColAllowed(self, root, userdata, lColID):
                          # The user is allowed to move all columns.
                          # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
                      def GetFirst(self, root, userdata):
                          Return the first element in the hierarchy, or None if there is no element.
                          rValue = None if not self.listOfTexture else self.listOfTexture[0]
                          return rValue
                      def GetDown(self, root, userdata, obj):
                          Return a child of a node, since we only want a list, we return None everytime
                          children = obj.GetChildren()
                          if children:
                              return children[0]
                          return None
                      def GetNext(self, root, userdata, obj):
                          Returns the next Object to display after arg:'obj'
                          rValue = None
                          # If does have a child it means it's a child.
                          objParent = obj.GetParent()
                          listToSearch = objParent.GetChildren() if objParent is not None else self.listOfTexture
                          currentObjIndex = listToSearch.index(obj)
                          nextIndex = currentObjIndex + 1
                          if nextIndex < len(listToSearch):
                              rValue = listToSearch[nextIndex]
                          return rValue
                      def GetPred(self, root, userdata, obj):
                          Returns the previous Object to display before arg:'obj'
                          rValue = None
                          predIndex = currentObjIndex - 1
                          if 0 <= predIndex < len(listToSearch):
                              rValue = listToSearch[predIndex]
                          return rValue
                      def GetId(self, root, userdata, obj):
                          Return a unique ID for the element in the TreeView.
                          return hash(obj)
                      def Select(self, root, userdata, obj, mode):
                          Called when the user selects an element.
                          if mode == c4d.SELECTION_NEW:
                              for tex in self.listOfTexture:
                                  tex.Deselect()
                              obj.Select()
                          elif mode == c4d.SELECTION_ADD:
                              obj.Select()
                          elif mode == c4d.SELECTION_SUB:
                              obj.Deselect()
                      def IsSelected(self, root, userdata, obj):
                          Returns: True if *obj* is selected, False if not.
                          return obj.IsSelected
                      def SetCheck(self, root, userdata, obj, column, checked, msg):
                          Called when the user clicks on a checkbox for an object in a
                          `c4d.LV_CHECKBOX` column.
                          if checked:
                              obj.Select()
                              obj.Deselect()
                      def IsChecked(self, root, userdata, obj, column):
                          Returns: (int): Status of the checkbox in the specified *column* for *obj*.
                          if obj.IsSelected:
                              return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                              return c4d.LV_CHECKBOX_ENABLED
                      def IsOpened(self, root, userdata, obj):
                          Returns: (bool): Status If it's opened = True (folded) or closed = False.
                          # If there is some children
                          return obj.IsOpened
                      def Open(self, root, userdata, obj, onoff):
                          Called when the user clicks on a folding state of an object to display/hide its children
                          if onoff:
                              obj.Open()
                              obj.Close()
                      def GetName(self, root, userdata, obj):
                          Returns the name to display for arg:'obj', only called for column of type LV_TREE
                          return str(obj) # Or obj.texturePath
                          if col == ID_NAME:
                              print "Drawcell obj: ", str(obj)
                              TEXT_SPACER = 6
                              #cube = c4d.BaseObject(c4d.Ocube)
                              #cubeIcon = cube.GetIconEx()
                              #bmp = cubeIcon.GetGuiScalePart()
                              bmp = c4d.bitmaps.InitResourceBitmap(c4d.RESOURCEIMAGE_ARROWUP)
                              # Draw name
                              name = str(obj)
                      def DoubleClick(self, root, userdata, obj, col, mouseinfo):
                          Called when the user double-clicks on an entry in the TreeView.
                          Returns:
                            (bool): True if the double-click was handled, False if the
                              default action should kick in. The default action will invoke
                              the rename procedure for the object, causing `SetName()` to be
                              called.
                          c4d.gui.MessageDialog("You clicked on " + str(obj))
                      def DeletePressed(self, root, userdata):
                          "Called when a delete event is received."
                          for tex in reversed(list(TextureObjectIterator(self.listOfTexture))):
                              if tex.IsSelected:
                                  listToRemove = objParent.GetChildren() if objParent is not None else self.listOfTexture
                                  listToRemove.remove(tex)
                  class TestDialog(c4d.gui.GeDialog):
                      _treegui = None # Our CustomGui TreeView
                      _listView = ListView() # Our Instance of c4d.gui.TreeViewFunctions
                      def CreateLayout(self):
                          # Create the TreeView GUI.
                          customgui = c4d.BaseContainer()
                          customgui.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
                          customgui.SetBool(c4d.TREEVIEW_HAS_HEADER, True) # True if the tree view may have a header line.
                          customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, False) # True if no lines should be drawn.
                          customgui.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True) # True if the user can move the columns.
                          customgui.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True) # True if the column width can be changed by the user.
                          customgui.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True) # True if all lines have the same height.
                          customgui.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True) # Alternate background per line.
                          customgui.SetBool(c4d.TREEVIEW_CURSORKEYS, True) # True if cursor keys should be processed.
                          customgui.SetBool(c4d.TREEVIEW_NOENTERRENAME, False) # Suppresses the rename popup when the user presses enter.
                          customgui.SetBool(c4d.TREEVIEW_NO_MULTISELECT, True)
                          self._treegui = self.AddCustomGui( 1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 300, 300, customgui)
                          if not self._treegui:
                              print "[ERROR]: Could not create TreeView"
                              return False
                          self.AddButton(1001, c4d.BFH_CENTER, name="Add")
                          self.AddButton(1002, c4d.BFH_CENTER, name="Add Child to selected")
                      def Command(self, id, msg):
                          # Click on button
                          if id == 1001:
                              # Add data to our DataStructure (ListView)
                              newID = len(self._listView.listOfTexture) + 1
                              tex = TextureObject("T{}".format(newID))
                              self._listView.listOfTexture.append(tex)
                              # Refresh the TreeView
                          elif id == 1002:
                              for parentTex in TextureObjectIterator(self._listView.listOfTexture):
                                  if not parentTex.IsSelected:
                                      continue
                                  newID = len(parentTex.GetChildren()) + 1
                                  tex = TextureObject("T{0}.{1}".format(str(parentTex), newID))
                                  parentTex.AddChild(tex)
                      global dialog
                      dialog = TestDialog()
                      dialog.Open(c4d.DLG_TYPE_ASYNC, defaulth=600, defaultw=600)
                    Hi @pim, if you only have user columns you need to define the actual height of these columns so the GeUserArea know which size she must take.
                    To do so you have to override TreeViewFunctions.GetLineHeight.
                    • P Offline
                      pim
                      Yes, that solved it.
                      Thanks.
