    How can i set custom Databases paths in prefs with python?
    pythonr21
    8 Posts 2 Posters 2.1k Views 1 Watching
    • B Offline
      bonsak
      Hi
      I have a python startup plugin that sets texture paths in Prefs>File Assets! with SetGlobalTexturePaths(...) for all workstations and render slaves. Is there a similar method for setting custom paths for node material Asset Databases (below the File Assets field) ?
      Any help appreciated.
      -b
      • S Offline
        s_bach
        these paths are accessed with a preference plugin. You can access that plugin:
        plugin = c4d.plugins.FindPlugin(1040566)
        paths = plugin[c4d.PREF_DATABASE_PATHS]
        # print paths
        print(paths)
        # add a path
        paths = paths + "\n" + "X:\someting"
        plugin[c4d.PREF_DATABASE_PATHS] = paths
        • B Offline
          bonsak
          Thanks! Ill try that.
          Regards
          Bonsak
          • B Offline
            bonsak
            So im trying to get this to work inside our startup plugin. I can set new database paths but i cant read the existing ones. So im constantly overwriting the paths field.
            import os, sys
            def PluginMessage(id, data):
            	if id == c4d.C4DPL_PROGRAM_STARTED:
            		try:
            			# Get plugin object
            			# Print plugin object
            			print('Plugin {}').format(plugin)
            			# Get existing paths
            			dbPaths = plugin[c4d.PREF_DATABASE_PATHS]
            			# Print existing paths
            			print('Existing DB paths {}').format(dbPaths)
            			# Set new paths
            			dbPaths = dbPaths + "\n" + "S:/_3D_Central/Maxon/Racecar-Assets-Redshift"
            			plugin[c4d.PREF_DATABASE_PATHS] = dbPaths
            			# Print new paths
            			print('New DB paths {}').format(dbPaths)
            		except KeyError:
            			sys.exit(1)
            print('Existing DB paths {}').format(dbPaths) doesnt print anyting even though there are entries in the Databases field.
            Am i doing something wrong?
            Regards
            Bonsak
            • S Offline
              s_bach
              this particular preferences plugin only loads its data when needed. To trigger that, you can call GetDescription() which will internally load the data.
              plugin.GetDescription(c4d.DESCFLAGS_DESC_0)
              • B Offline
                bonsak
                Thanks! Works like a charm!
                -b
                B 1 Reply Last reply Reply Quote 0
                • B Offline
                  bonsak @bonsak
                  Hi
                  I managed to delete my original plugin πŸ™‚ So now im recreating it. But when i run this plugin now with the findplugin argument, it returns None. As stated higher up in the thread im trying to set custom database paths in prefs on startup.
                  import os, sys
                  		# try:
                  		# Get plugin object
                  		print('Plugin ', plugin)
                  Regards
                  Bonsak
                  • B Offline
                    bonsak
                    Ok. I figured it out. The ID was wrong. It was supposed to be 465001634
                    -b
