    Bend Deformer Using C++
    c++r19sdk
    18 Posts 5 Posters 5.3k Views 3 Watching
    • mfersaouiM Offline
      mfersaoui @Cairyn
      @Cairyn
      Yes, the current code is only to generate the structure. in an another test I tried to create an algorithm to moving and rotate individually the lights objects inside the loop, and I realized that is too complex for me to reproduce the same bend deformation. so, I gave up the idea.
      I did not say it, but I'm using this inside GetVirtualObjects, I don't know if is allowed to add Python tag inside GVO.
      and then I will control the bend deformation from the via my GVO object Description Resource.
      Yes, I'm just searching how to animate the lights objects same as the Extrude object in the second screenshot.
      • CairynC Offline
        Cairyn @mfersaoui
        @mfersaoui If you're generating the objects on the fly, you wouldn't need a Python tag but could place the objects in their "bent" placement already, so that would not be a problem. Of course, if you can't replicate the bending algorithm the question is moot... but maybe Google knows the fitting formula?
          while Cinema's restriction of deformers to point data is certainly a shortcoming, I do not understand (because I might be overlooking something) why you do not write a bend function yourself.
          All the common deformers are just translation, rotation or scale operations modified by a linear interpolation along an axis of operation. The bend operation is just a rotation operation where the rotation angle is interpolated along the axis of operation.
          zipit
          mfersaouiM CairynC 2 Replies Last reply Reply Quote 0
            mfersaoui @ferdinand
            @zipit
            As I explained to @Cairyn I tried to create an algorithm to do that, but this is too complex for me and I haven't level to do that. I will search again in google maybe I will find something similar.
            • CairynC Offline
              Cairyn @ferdinand
              @zipit @mfersaoui not quite; the pivot of the rotation is also changing (only along one axis, but still...), and it's not a linear movement but some exponential one between 0 (approaching only) and infinity (when no bend). The infinity one may also be tricky numerically.
              I have an idea how to solve (my Google-fu seems weak on this) but haven't tried in praxis yet.
              • CairynC Offline
                Cairyn
                okay, calculate with me...
                The arc length L for an angle alpha on a circle with radius r is L = 2* pi * r * alpha / 360
                (assuming alpha is in degree). alpha is known; it is the bend angle.
                The arc length is also known - it's the distance of the bending point to the center of the bend
                (assuming we want to keep that length constant).
                The radius is actually the wanted value. So we transform
                L * 360 = 2 * pi * r * alpha
                (L * 360) / (2 * pi * alpha) = r
                Obviously, this is numerically bad since with alpha approaching 0, r is approaching infinity. But maybe we can solve this in the transformation and get rid of either alpha or r.
                The rotation of the target coordinate system (the object to place on the bend) is obviously alpha itself.
                The position p of the target needs to be moved according to sin and cos of alpha on the circle with radius r.
                Remember that all of this needs to be expressed in the coordinate systems of either the object, the world, or the bend deformer, which makes the calculation perhaps a bit awkward.
                • CairynC Offline
                  Cairyn
                  For simplification, we'll assume that world, bend, and object coordinates are all the same.
                  Now you can draw a circle with radius r and check where a point p is going. Let's just look at the point p = (L,0) - the farthest centered point of our object, or the center of the coordinate system of out object if you want to move a whole object.
                  Then p'.x is going to be r * sin(alpha), and p'.z will be r - r * cos(alpha), as per the definitions of sine and cosine.
                  And that's all there is! Okay, after you did the necessary coordinate transformations between the base coordinate systems and adapted the calculation for other points than p, but that's homework.
                  Here I made a little scene where a Python tag does the calculation. A flattened cube is bent by a bend deformer; a torus primitive is moved accordingly to stay flush with the left edge of the cube. Note that the calculation for the torus position and rotation is done solely through the Python tag, whose only input the bend deformer's angle is, so the Python tag is actually replicating the bend deformer functionality.
                  20200104_CenterOfBendDeformer.c4d
                  The main part is the code of the Python tag (I'm calculating with radians here so don't wonder why there is no pi; also the bend deformer in my scene is pointing to the negative x so we have additional minus signs:
                  from math import sin, cos
                      torus = op.GetObject()
                      source = torus.GetPred().GetDown()
                      strength = source[c4d.DEFORMOBJECT_STRENGTH]
                      originx = -400.0
                      originz = 0.0
                      if strength == 0.0:
                          targetx = originx
                          targetz = originz
                          roth = 0.0
                          alpha = strength
                          radius = originx / alpha
                          targetx = radius * sin(alpha)
                          targetz = -(radius - radius * cos(alpha))
                          roth = -alpha
                      torus[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_X] = targetx
                      torus[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Z] = targetz
                      torus[c4d.ID_BASEOBJECT_REL_ROTATION,c4d.VECTOR_X] = roth
                  Obviously this is a very simplified sample that works only for this scene, but you can adapt the calculation for yours.
                  mfersaouiM 2 Replies Last reply Reply Quote 1
                    mfersaoui @Cairyn
                    @Cairyn
                    Thank you so much for your help and for your detailed explanation, I started to testing your code in python to better understand and now I will try to adapt it to my project in c++. If I have a problem I return to this topic.
                    Thanks again.
                      mfersaoui @Cairyn
                      @Cairyn
                      Thanks to you, I have obtained the desired result.
                      In my project the "strength" and the "originx" values is not constant, also the total count of the lights object is not constant. So I made the necessary changes on your code.
                      Here is the final code:
                      AutoAlloc<BaseObject>	containertPtr(Onull);
                      AutoAlloc<BaseObject>	parentlighstPtr(Onull);
                      AutoAlloc<BaseObject>	recPtr(Osplinerectangle);
                      AutoAlloc<BaseObject>	bendPtr(Obend);
                      if (!containertPtr || !recPtr || !parentPtr || !bendPtr)
                      	return false;
                      // Set names
                      containertPtr->SetName("Container");
                      parentPtr->SetName("Lights");
                      recPtr->SetName("Rectangle");
                      // Variables
                      Int32 Count = 7;
                      Float	Xpos, Ypos,
                      		Width = 150.0,
                      		Height = 250.0,
                      		interval = 40.0;
                      Ypos = Height / 2;
                      // Rectangle object
                      recPtr->SetParameter(PRIM_RECTANGLE_WIDTH, Width, DESCFLAGS_SET_0);
                      recPtr->SetParameter(PRIM_RECTANGLE_HEIGHT, Height, DESCFLAGS_SET_0);
                      recPtr.Release()->InsertUnder(containertPtr);
                      // Bend object
                      Float fullWidthSize = (Width*Count) + interval*(Count - 1);
                      Float	bendStrength = 90.0;
                      bendPtr->SetParameter(DEFORMOBJECT_SIZE, Vector(Height, fullWidthSize / 2, 10.0), DESCFLAGS_SET_0);
                      bendPtr->SetParameter(DEFORMOBJECT_MODE, DEFORMOBJECT_MODE_UNLIMITED, DESCFLAGS_SET_0);
                      bendPtr->SetParameter(DEFORMOBJECT_STRENGTH, bendStrength, DESCFLAGS_SET_0);
                      bendPtr->SetParameter(DEFORMOBJECT_ANGLE, DegToRad(-90.0), DESCFLAGS_SET_0);
                      bendPtr->SetAbsRot(Vector(0, 0, DegToRad(-90.0)));
                      bendPtr->SetAbsPos(Vector(fullWidthSize / 4, Height / 2, 0.0));
                      Float strength, alpha, radius, originx, originz = 0.0, targetx, targetz, roth, step;
                      Float	centerx = fullWidthSize/2;
                      for (Int32 i = 0; i < Count; i++)
                      	AutoAlloc<BaseObject>	InstancePtr(Oinstance);
                      	AutoAlloc<BaseObject>	ExtrudePtr(Oextrude);
                      	AutoAlloc<BaseObject>	LightPtr(Olight);
                      	if (!InstancePtr || !ExtrudePtr || !LightPtr)
                      		return false;
                      	Xpos = (Width*i) + (interval*i) + (Width / 2);
                      	originx = centerx - Xpos;
                      	originx = originx*-1;
                      	step = centerx / originx;
                      	strength = bendStrength / step;
                      	if (strength == 0.0) {
                      		targetx = originx;
                      		targetz = originz;
                      		roth = 0.0;
                      	else {
                      		alpha = strength;
                      		radius = originx / alpha;
                      		targetx = radius * sin(alpha);
                      		targetz = -(radius - radius * cos(alpha));
                      		roth = -alpha;
                      	// Set names
                      	ExtrudePtr->SetName("Extrude_" + String::IntToString(i));
                      	InstancePtr->SetName("Instance_" + String::IntToString(i));
                      	LightPtr->SetName("Light_" + String::IntToString(i));
                      	// Light object
                      	LightPtr->SetParameter(LIGHT_TYPE, 8, DESCFLAGS_SET_0);
                      	LightPtr->SetParameter(LIGHT_AREADETAILS_SIZEX, Width*0.9, DESCFLAGS_SET_0);
                      	LightPtr->SetParameter(LIGHT_AREADETAILS_SIZEY, Height*0.9, DESCFLAGS_SET_0);
                      	LightPtr.Release()->InsertUnder(ExtrudePtr);
                      	// Instance object
                      	InstancePtr->SetParameter(INSTANCEOBJECT_LINK, recPtr, DESCFLAGS_SET_0);
                      	InstancePtr.Release()->InsertUnder(ExtrudePtr);
                      	// Extrude object
                      	ExtrudePtr->SetParameter(EXTRUDEOBJECT_MOVE, Vector(0, 0, 0), DESCFLAGS_SET_0);
                      	ExtrudePtr->SetParameter(EXTRUDEOBJECT_HIERARCHIC, true, DESCFLAGS_SET_0);
                      	ExtrudePtr->SetAbsPos(Vector(targetx, Ypos, targetz));
                      	ExtrudePtr->SetAbsRot(Vector(roth, 0, 0));
                      	ExtrudePtr.Release()->InsertUnder(parentPtr);
                      bendPtr.Release()->InsertUnder(parentPtr);
                      parentPtr.Release()->InsertUnder(containertPtr);
                      • W Offline
                        wuzelwazel
                        I'm not sure why my suggested solution didn't work. Did you apply the Bend to a Matrix object and then Clone onto that Matrix (Cloner in Object mode targeting the Matrix)? The Bend should modify the Matrix positions/rotations and the Cloner should pick up those modified positions for it's children (the lights).
                        Rolling your own bend algorithm definitely has its advantages over this, but I was surprised to hear that you got exactly the same result.
                        mfersaouiM 1 Reply Last reply Reply Quote 0
                          mfersaoui @wuzelwazel
                          @wuzelwazel
                          My bad, I misunderstood. I just retest and it's working well using Matrix and Cloner object.
                          Thanks you so much for your help and for reminding me.
                            Not that much to add it here I think everything was already said.
                            But I just would like to remind you to use the Q&A functionality
                              mfersaoui @m_adam
                              @m_adam
                              Sorry, but I haven't the ability to mark this post as solved. I don't see the button "Mark this post as the correct answer".
                                Yes because I've done it 🙂
