    Get CustomGUI Data in python
    pythonc++r20sdk
    9 Posts 3 Posters 2.2k Views 1 Watching
    • N Offline
      neon
      Hello plugincafe!
      I have recently created a customgui using the example customgui plugin. The only major thing that I changed, appart from drawing, is that I save a single float value.
      I now need to implement this custom gui into a python plugin but I can't seem to find out how to retrieve my saved data from the gui element.
      Do I need to completely switch to a c++ plugin to do this, or is there a way in python.
      Kind Regards,
      Florian
        Hi if your data type is already a know python type you shouldn't have any issue and could use the BaseCustomGui.GetData / BaseCustomGui.SetData.
        So if we take the C++ example of the String Custom GUI.
        You can use it in Python like bellow:
        ID_CUSTOM_GUI = 1001
        ID_BUTTON_DO = 1002
        class myCustomGuiDlg(c4d.gui.GeDialog):
            def CreateLayout(self):
                self._customGui = self.AddCustomGui(ID_CUSTOM_GUI, 1034655, 'my value', c4d.BFH_SCALEFIT, 50, 10)
                self.AddButton(ID_BUTTON_DO,c4d.BFH_SCALEFIT,name = 'Get Data')
            def InitValues(self):
                self._customGui.SetData("Some custom text")
            def Command(self, id, msg):
                if id == ID_BUTTON_DO:
                    print self._customGui.GetData()
            dlg = myCustomGuiDlg()
            dlg.Open(c4d.DLG_TYPE_ASYNC)
        • N Offline
          neon
          Hello Maxime,
          thanks for you answer!
          I actually have my custom gui not in a GeDialog but inside a res file of an ObjectData. How would I be able to access the customgui from there?
          Best Regards,
          Florian
          • S Offline
            s_bach
            In an ObjectData plugin, you don't access GUIs. You access parameters. So what is the parameter type that is using your custom GUI? Can you show your *.res file?
            • N Offline
              neon
              Hello Sebastian,
              basically I have something like this
              MY_CUSTOMGUI CUSTOMGUIPARAM { }
              that is what I use.
              • S Offline
                s_bach
                Sorry, but this is not how it works. A NodeData's res file looks like this:
                STRING ID_RESULT_TEXT  { CUSTOMGUI MULTISTRING; ANIM OFF; }
                The first symbol is the data type (STRING), the second the parameter ID, The custom GUI can be found after the CUSTOMGUI keyword.
                So in your case, MY_CUSTOMGUI is NOT a custom GUI. It is a custom data type. Is that correct?
                • N Offline
                  neon
                  oh... yeah that is true.
                  I edited the customdata_customgui example to fit my needs. (mainly only the drawing).
                  So I guess I would have to change my customdata to a REAL customgui?
                  • S Offline
                    s_bach
                    Please make sure you understand the difference between a data type and a GUI. A data type stores data of some type. A GUI displays that data and allows interaction with that data in the UI. But it does not persistently store the data.
                    So if you want to have a parameter in your object that stores a float value, just use a REAL parameter. You can display that parameter in the UI using a custom GUI element. See for example customgui_string.cpp.
                    • N Offline
                      neon
                      Hello Sebastian,
                      I now understand what the difference is, thank you very much!
                      With the customdata_customgui example file I actually made both a GUI and a custom DataType. So I only needed to change my resource file and modifiy my data code a bit!
                      Best Regards,
                      Florian
