    How to add Layers Shader - C++
    c++r19sdk
    6 Posts 3 Posters 894 Views 2 Watching
    • mfersaouiM Offline
      mfersaoui
      How to add Layers Shader that contain two layers (Bitmap shader and Hue/Saturation/Lightness effects) with HSL -100 %.
      BaseMaterial *Mat = BaseMaterial::Alloc(Mmaterial);
      if (!Mat)
      	return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
      BaseContainer *Data = Mat->GetDataInstance();
      if (!Data)
      	return true;
      BaseShader* bsXlayer = BaseShader::Alloc(Xlayer);
      if (!bsXlayer)
      	return false;
      Data->SetLink(MATERIAL_ENVIRONMENT_SHADER, bsXlayer);
      Mat->InsertShader(bsXlayer);
      Thanks.
      • r_giganteR Offline
        r_gigante
        Hi mfersaoui, thanks for reaching out us.
        With regard to your question, whilst it's actually possible to query for the layers belonging to a certain Layer Shader, it's not possible to programmatically add new layers with the current API implementation.
        Here you can find an old discussion on the argument.
        Best, Riccardo
        mfersaouiM 2 Replies Last reply Reply Quote 0
          mfersaoui @r_gigante
          @r_gigante
          Hi Riccardo,
          Thank you, I will try to import my material from a scene file.
            @r_gigante
            I have another question, is it possible to edit the Blur Offset and Blur Scale of shader via c++?
            Thanks.
            • S Offline
              s_bach
              "Blur Offset" and "Blur Scale" are parameters of the BaseShader class, so you should be able to access these parameters like any other parameter; if in doubt, they should be available in the shader's BaseContainer. See xbase.h.
              mfersaouiM 1 Reply Last reply Reply Quote 0
                mfersaoui @s_bach
                @s_bach
                Thank you.
